Old 08-16-2005, 09:21 AM   #8506
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Originally Posted by BatJam1
Tire choice is variable Depending on track temprature for that given day and insert depends on smoothness of track suface,also depends on if your doing a 5 min qualifier or an 1/2 hour to an hour Main.
Hey Artificial your car looks great is that the upgraded chassis.?
Thanks. Its the 2004 edition, with the lightweight hpi super chassis. Thats included with the kit.
Artificial-I is offline   Reply With Quote
Old 08-16-2005, 09:26 AM   #8507
Moderator
Originally Posted by Greenbox
Artificial nice bent stinger Mine pipe looks jus like that as well. I hate them boards...curbs and other cars...
Yeah lovely isnt it. I figured out how to fix that inward bend. You must pull it out with the pipe as hot as possible.
I get needle nose pliers I stick it into the stinger and grab and pull. I also use some paper towells to help keep things from getting messed...but thats not too important to me if its scratched.
Otherwise any sort of pulling or pushing on it normally makes that kind of inward bend worse. At first my stinger was getting bent...now its pushed in like you see.
I was smacking walls last time pretty badly. I had it looking a bit better but at the start of the race when I fixed it after that I pretty much returned it back to its former self. Gotta dial the new car and get used to it.
Old 08-16-2005, 10:06 AM   #8508
tranced's Avatar
it also makes ur rear wobble more under speed
ditch the stock stuff, get what the woven towers were meant to use
Originally Posted by Artificial-I
I need to trim a body for it, all of my bodies were trimmed for a racer2, fits the standard r40 perfect. But I might do it. I have a pro4 so I just need to borrow the mounts.
One thing I like about it though it semi acts as a rear bumper and kinda protects the upper portion of the shocks more.
tranced is offline   Reply With Quote
Old 08-16-2005, 10:39 AM   #8509
JAG Racing's Avatar
Send a message via AIM to JAG Racing
The CF rear body mounts definately look better but I goota be honest and say they are more likely to break than the stock narrow body mount design. I recently got tangled up and tumbled my car and sure enough the CF snapped. The stock rear body mount would not have been damaged. Just something to think about.
On another topic - pinion gears .. I have had recent experience using 20T/29T and 54T/60T spurs. MY second spur gear was stripped during the main and I think it is becuase of the variable pitch gearing. While most people think that you can use ANY pinion/spur gear combos; I think that I took it a little too far in going to a 8 tooth difference on the pinions with only a 6 tooth difference on the spurs. Have any of you ever run a similar gearing? I think the old rule of thumb should be used whenever gear selection is needed. My opinion and I don't have extensive data to back up my claim - but just be cautious.
JAG Racing is offline   Reply With Quote
Old 08-16-2005, 11:04 AM   #8510
tranced's Avatar
the body posts arent CF, they're off the pro4 parts tree and arent even composite. same plastics found on the bumper brace
Old 08-16-2005, 11:13 AM   #8511
Rapid Roy's Avatar
I think he is saying that he snapped his shock tower.
Rapid Roy is offline   Reply With Quote
Old 08-16-2005, 11:14 AM   #8512
Is HPI still coming out with a Hara Edition R40? I heard its going to be out the end of this month.
snowboardgeek1 is offline   Reply With Quote
Old 08-16-2005, 11:23 AM   #8513
JAG Racing's Avatar
Thanks - Yes the CF shock tower. And I still go back with the "wide CF" body post mount cause it looks cool! Let's see what the odds are of breaking it again anytime soon.
Old 08-16-2005, 02:37 PM   #8514
Moderator
Yeah I also figured it would make things more suspect to snapping the cf tower. I think for racing on my shorter p-lot track Its ok to use the standard mount.
As well gives me a little extra added protection.
Old 08-16-2005, 07:08 PM   #8515
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
gotta love snapping a CF shock tower...I snapped one on saturday with a wicked hit tumbling off the track...snapped the damn tower at the first setting mark...
so back on went the aluminum shock tower and crappy body posts...and we were back in business....
After I fixed the leaky front diff, the car was on rails and flying.....
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 08-16-2005, 07:20 PM   #8516
Moderator
I wonder if gpms tower would last longer. It looks worth a try. Only problem is the settings...they seem to have quite a few odd holes on those things.
Old 08-16-2005, 07:53 PM   #8517
JAG Racing's Avatar
A friend tells me the V-one RRR has a similar problem -- one solution is to purchase two and glue them together..
Old 08-16-2005, 09:04 PM   #8518
Moderator
I was thinking about that too. But, I figure it would change how the shocks set on the rear though.
Old 08-16-2005, 09:16 PM   #8519
JAG Racing's Avatar
You are right - You will need to add a 2mm spacer at the bottom shock mount to make the difference up.
Old 08-17-2005, 12:39 AM   #8520
dnitro's Avatar
Originally Posted by Hesky
Cheers John thats loads of help! its just like you say, I cant see rubber tires been more cost effective than foam tires, unless very hard compounds are chosen so they last significantly longer to justify there costs, but I'm not up for that myself. really cant figure out why my club decided to run rubber in favour of foams I guess I'm just gonna have to make the most out of it and get my car setup for rubbers, and be prepared to blow 40 bucks on tyres every week just for club meets, sooner that than skate around the track with crappy hard tires, bumping into stuff!
yeah your spot on!
Medial Pro tires come either separate or pre-glued. The inserts are built in the tires. Of the many tires I've tried, they work the best. I normally purchased the pre-glued set ($19/pair at my lhs) and they have a very long tread life. There are different compounds to choose from. Here is the link.
http://www.gsracing.com/web/page.asp...ducts&catid=19
TM G4S
IDM Evo3
dnitro is offline   Reply With Quote
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
