Old 08-05-2005, 07:37 PM   #8371
JAG Racing's Avatar
Send a message via AIM to JAG Racing
Originally Posted by KLANDERMAN
HARK- Whats going on??? Long time no see... I've been busy here in Guatemala checking out the petroleum fields, so haven't had time to use my car. Fortunately I ordered the LW chassis and I will be installing it tomorrow. I also painted a new body for the car, check it out...
That color combo really stands out - nice!
JAG Racing is offline   Reply With Quote
Old 08-05-2005, 07:43 PM   #8372
Greenbox's Avatar
hes even got a big scar when they were heating up the landing gear axle(part of the process even saw how they do it on the science channel ). That musta hurt ... When he made machined moldings he really never actually molded something out of htem yet(guess he wants to be an inventor but he is too busy).Anyways, Gonna get the mugen 2 speed shoes anyway and try it hope fully they wont be as brittle as the stock r40 ones...Cant wait to get a magnesium chassi for the r40...that'll be a first.
Greenbox is offline   Reply With Quote
Old 08-05-2005, 08:54 PM   #8373
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Just assembled the centax. I had to remove some material as well from the mugen grey clutch, near the insides of the holes. After that it moved much more smoothly.
After assembley I noticed overall everything seemed to be somewhat thicker making me need to use less shims. I guess thats a given since its brand new disc vs used or maybe the mugen is just thicker?
Then after giving the gears a spin I hear an odd scratching noise when I point the screw down towards the ground. As well sometimes when just spinning upright.
Heres the video:
click here
I tried a different thrust bearing, still was there. Everything is brand new otherwise. One thing I did notice is the crankshaft does not come through as far, its not enough to past the outer flange bearing. Normally it would stick out a little.
Artificial-I is offline   Reply With Quote
Old 08-05-2005, 09:14 PM   #8374
regg151's Avatar
Send a message via ICQ to regg151 Send a message via AIM to regg151 Send a message via Yahoo to regg151
AI I'm not 100% but it just may be that the clutch shoe has a few high spots. after watching the vid it's the first thing that comes to mind. anyone else got any idea?
_______________________________________________________________________
Inferno GT Hyper 21 8 Port Ipanema Tires
Spektrum DX3R
Team CFX Racing, RCNB Race Team, CFX Paintworks.com
regg151 is offline   Reply With Quote
Old 08-05-2005, 09:17 PM   #8375
Moderator
Yeah thats what I thought. But at first I had a lot more space, as I was using one less washer and it would still do it pretty much the same way , now its even closer and sounds the same.
Im pretty sure the sound is coming from inside the area where the thrust bearing is...but its not that so im kinda baffled cause not much else should be rubbing? Maybe Ill start swapping around the bearings.
Old 08-05-2005, 09:31 PM   #8376
AMGRacer's Avatar
From the video it seems fairly normal. I assume the bearings are new and the thrust bearing is as well?
Did you tap all 4 pins into the flywheel before assembling? They are often uneven from the factory. I use some loctite press fit on mine, I tap all 4 out first then reassemble it.
Do you use inner shims to stop the clutchbell rubbing on the clutch shoes?
AMGRacer is offline   Reply With Quote
Old 08-05-2005, 10:03 PM   #8377
does any one know the purpose of part number 73480-4. it goes behing the stering servo. im so lost as to what this part does
thanks
thisisagame24 is offline   Reply With Quote
Old 08-05-2005, 10:08 PM   #8378
Moderator
Yup all brand new and I swapped in my old tb and still the same sound. Its louder in person.
I shaved them down and flat sanded them on the ground to make them somewhat clean and even.
Old 08-05-2005, 10:26 PM   #8379
nsxshogun's Avatar
Send a message via AIM to nsxshogun
Damn AI go get some sun. Your arms are pale as hell
nsxshogun is offline   Reply With Quote
Old 08-05-2005, 10:36 PM   #8380
Moderator
LOL, not such a great cam and its weird lighting in here along with the computer screen throwing blue on me. I turned on all the lights around me to make it easy to see, so it looks like im glowing white.
But yeah Iam kinda light, especially under my arm and biceps. The only tan I get is my farmers tan from rc racing.
Iam basically just like kenshin in my avatar light skin and I do have some red in my hair. Except you can only see it in certain light , otherwise I have brown hair.
Old 08-05-2005, 10:37 PM   #8381
nsxshogun's Avatar
LOL!!!!!
Old 08-05-2005, 10:48 PM   #8382
Moderator
Here is kenshin.
Here is kenshin , kicking arse. Any questions. LOL (btw its a great anime)
Old 08-06-2005, 05:11 AM   #8383
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
thanks
its supposed to be a transponder holder.....i use it to hold my charging lead...I mount the transponder(personal) on the top deck....
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 08-06-2005, 11:17 AM   #8384
thanks
Old 08-06-2005, 12:11 PM   #8385
Moderator
I found a one piece engine mount for a pretty good price. Ill let you guys know if its worth the buy. Otherwise the hara mounts are im sure 3-4 times more.
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
