Old 08-02-2005, 02:44 PM   #8326
regg151's Avatar
Send a message via ICQ to regg151 Send a message via AIM to regg151 Send a message via Yahoo to regg151
yes the open belt design is prone to small rocks and other debris, but that is why HPI recomends only running the car on a groomed track or blown/swept parking lot.
_______________________________________________________________________
Inferno GT Hyper 21 8 Port Ipanema Tires
Spektrum DX3R
Team CFX Racing, RCNB Race Team, CFX Paintworks.com
regg151 is offline   Reply With Quote
Old 08-02-2005, 04:31 PM   #8327
But there is always possibility of having small stones if the track is surrounded by grass areas. What about closing the openings under the belt with a sticker or a harder thin plastic?
ontheroad is offline   Reply With Quote
Old 08-02-2005, 05:20 PM   #8328
Hesky's Avatar
I think stones get flicked up by the tires and deflect off the body shell and fall into the chassis, doesn't matter how clean and groomed the track is I always manage to get a stone jammed in the most annoying and damaging places. its always a stone that has been flicked on the track by a novice that has pulled it off the grass banking.
Hesky is offline   Reply With Quote
Old 08-02-2005, 06:03 PM   #8329
Rapid Roy's Avatar
This problem was beat to death on the old HPI forums. Hesky is correct, the rocks get thrown up by the tires. Usually the holes in the chassis allow the rocks to fall back through. Usually the cars stops suddenly when a big enough rock gets into the belts. When this happens, stop. Don't gun the throttle to try and force it forwards. Walk to the car and gently roll it backwards a few inches, then foward. You might have to go back and forth a few times. If its really stuck you might need a probe or small screwdriver to dislidge the rock. I stopped shreading belts when I stayed away from parking lots with decaying asphalt. If your local track uses a lot with a surface like that, your only solution is to keep 2 or 3 extra belts and extra pulley gears with you. I also try to check my all my gears between heats because sometimes crud or pebbles get lodged in between the teeth of the gears.
Rapid Roy is offline   Reply With Quote
Old 08-02-2005, 06:04 PM   #8330
R40Victim's Avatar
I ended up CA gluing a piece of lexan to the underside of my Pro 4, under the Spur. Not sure how you would do it, but you could shield it basically the same way...shoe goo perhaps...
R40Victim is offline   Reply With Quote
Old 08-02-2005, 06:19 PM   #8331
just wondering if anyone has changed from the stock cluth....the 4 piece with a spring holding them to like a one piece clutch?
thisisagame24 is offline   Reply With Quote
Old 08-02-2005, 06:26 PM   #8332
Rapid Roy's Avatar
Those are the clutch weights, not the clutch shoe. The clutch shoe is one piece. I have heard of people running without the spring. You might need a harder clutch spring because the weights will push harder on the shoe causing the clutch to engage earlier.
Old 08-02-2005, 06:30 PM   #8333
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Originally Posted by Artificial-I
Which reminds me I have my solid rear axle on the way. Im thinking on testing it out. Not sure though still trying to get used to driving the one-way. Which seems to work for me , even with a tight track layout.
One cool thing I notice with the one-way if you leave like a real light light throttle on , rather than fully getting off it to take a turn. Your car will just curve through the turn like it was off gas but keeps it speed up.
Wow that was fast its already here. 1 day shipping. LOL. Guess Ill be able to test this thing out this month.
Artificial-I is offline   Reply With Quote
Old 08-03-2005, 12:18 AM   #8334
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Hey Regg are you gearing up for Ohio today? I'll be at floyd doing some runs with the R40 and the 8th.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 08-03-2005, 01:42 AM   #8335
AMGRacer's Avatar
Originally Posted by ontheroad
Because i heard that the rear belt of r40 wears quickly.
I don't know it is true but i only heard.
I dunno about quickly. But at the state champs last weekend I ripped all of the teeth off my rear belt. It was around 6 months old so thats not too bad. The grip was insanely high and I had my clutch set very high so I suspect that was something to do with it.
AMGRacer is offline   Reply With Quote
Old 08-03-2005, 02:49 AM   #8336
Yeah this idea seems smart. But is there any openings other than the lower chassis?
Old 08-03-2005, 07:22 AM   #8337
Hesky's Avatar
Just ran my car on track to try out the mugen grey shoe and slightly harder than stock gold spring, it makes a night and day difference!!! I can only imagine it will improve further when it seats itself into the clutch bell face! I really cant see how people can get a half decent clutch setup with the stock black hpi shoe!!
Starting to realise how vicious this d5r motor is, as before when it got into the powerband the clutch would slip, now it lights up the foam tires and makes it almost uncontrollable!
I'm thinking the red shoes with the silver spring and jp clutch bell i have will be overkill!
hey john just a note, I tried to slip the mugen shoe on the kit flywheel, but as expected it didnt fit. I was about to ream the shoe but just b4 I tried it on a spare new r40 flywheel and the mugen shoes slip straight on with no interference.
Old 08-03-2005, 07:38 AM   #8338
regg151's Avatar
have fun at floyyd my R40 is down for the moment waiting on a new motor, my MT12 is having issues. OHIO??? You lost me on that one.
Spektrum DX3R
Old 08-03-2005, 07:44 AM   #8339
JAG Racing's Avatar
Send a message via AIM to JAG Racing
Huh? OK - I'll stop by the hobby shop tonight and pull some new parts off the shelf and see if maybe I have a "defective" HPI flywheel. - Thanks for the heads-up Hesky.
JAG Racing is offline   Reply With Quote
Old 08-03-2005, 03:56 PM   #8340
Moderator
Had another spending spree. Got the hpi universal pinion wrench. I figured I had no other way of really getting it on there and its what reccomended so...went ahead and dropped the money on it.
Then got some twister tires on the way. I want to test these against my jaco nitro shoes. Then im going to test the new 2stage "wraps" from jaco. Im going to paypal my lhs the funds and pick that stuff up tommorrow.
Im also planning on getting a bunch more sets of foams so Ill let you know what I think of them and whats the best price and so forth cause that kinda stuff is important to me.
Also finalizing the weight list. I weighed quite a few things , also found a few lw items that im going to keep to myself (gotta stay ahead a little). But yeah you guys would be jealous of this one I found. Drops 4 grams off the car , costed 5 dollars and its connected to the drivetrain and suspension.
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
