Old 07-28-2005, 09:15 PM   #8266
Speedbug's Avatar
What you have to remember is that these servos are designed for smaller scale aircraft where the accuracy and repeatability is not so critical because the deflection surfaces that control a plane work different to the throttle and brake in a car. Don't want to go into aerodynamics hear though. Nylon gears will always have more give than carbonite or metal geared servos. But as always it's a trade off with weight. What you have to do is consider all the factors that you want such as speed, torque, reliability and accuracy then choose the right tool for the job or as close to as possible. The metal geared servos will also last alot longer under these conditions.
Speedbug is offline   Reply With Quote
Old 07-29-2005, 07:35 AM   #8267
Hesky's Avatar
I'd love a discussion about aerodynamics anyway there is certainly no doubting the durability and and rigidity of metal gears, but you have to wonder if its application is necessary in a small servo like this, especially when it uses feedback potentiometers where accurate positioning is non existent anyway. the servos gearing is unlikely to come under any abuse, if for example it was used on the steering. Just the general design and weedy spec of the servo will give it poor repeatability in a slightly demanding application, but probably acceptable though. I guess what can you expect from a $10 servo.
but like you say consider all the factors and choose accordingly.
Hesky is offline   Reply With Quote
Old 07-29-2005, 07:59 AM   #8268
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Post
Well guys no more hitec servos for me. On my 8th it constantly shuts down and thats with it being attached or not attached to the failsafe and then to the RX. I sure don't want to try it in the R40 and have it wisk away from me at 60MPH with only steering to rely on so new servos here I come . I'm also in the process of trying to get a better radio as well however I'm not gonna go 2 balistic. The racing is almost over anyway and soon when it gets cold thats it.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 07-29-2005, 08:09 AM   #8269
JLock's Avatar
For you guys wanting to use the HS81 and HS225 mini servos just to shave a few grams off your cars, you are crazy. Those servos were not designed for what you plan on putting them through. Just let me not be on a track racing any of you that are using mini servos for throttle when it fails and your car becomes a runaway. I like to shave some weight off my car, but not at the expense of destroying it (costing you more than it would have to just keep the extra grams a regular servo, build to handle the stress, adds).
Texas 5
It's not what you know; it's what you can prove.
The only thing that is for sure is that nothing is for sure!!!
The needs of the many outweigh the needs of the few, or the one.
There are 2 things in life that are infinite: the universe and stupidity.
JLock is offline   Reply With Quote
Old 07-29-2005, 08:10 AM   #8270
Hesky's Avatar
yeah you really dont want a servo like that controlling you throttle! I had a KO Propo that used to alway and i mean alway conk out when the throttle was wide open!!
Old 07-29-2005, 08:14 AM   #8271
JLock's Avatar
I have been using Hitec servos in my cars for years. I have had a few go out, but at some point in time, all servos will eventually fail. Recently, I have started to use the higher ending servos and ones with metal gears for both throttle and steering. Try the Airtronics servos, they are very good but a bit pricier than the Hitecs. I have a Airtronics 94742 (discontinued) high speed on that has been in 3 different nitro cars for steering with not a hitch.
Texas 5
Old 07-29-2005, 08:50 AM   #8272
Hesky's Avatar
To be honest I never really used hitec servos in my pro cars, alway preferred ko's but i've been playing around with there new karbonite and titanium programmable digital servos and I'm well impressed! my fave for steering is the karbonite 6965HB its pretty light but stupid fast. Cool thing about the digital servos is they have a programmable failsafe point, so if somethin goes wrong my throttle servo applies the brake automatically and brings the car to a halt.
Old 07-29-2005, 09:26 AM   #8273
HarKonnenD's Avatar
Yeah I figured that I'd go Futaba or Airtronics servos. For now I'm still using my 3PDFX, but will switch to synth or spektrum in the future. Most definately I don't want that Hitec on my MRX4 and it not responding for no reason.
Old 07-29-2005, 02:59 PM   #8274
rc_king1's Avatar
Can anyone tell me the weight of the stock diff fluid (for front of car) that comes with the standard r40 kit? Thank you in advance.
rc_king1 is offline   Reply With Quote
Old 07-29-2005, 03:55 PM   #8275
It must be 50000W for front diff, in manuel it advises to use grease for rear diff.
ontheroad is offline   Reply With Quote
Old 07-29-2005, 04:40 PM   #8276
5000W in the front:
http://www.hpiracing.com/graphics/in...0/R40-P05o.jpg
I used 3000W in the rear.
rossb is offline   Reply With Quote
Old 07-29-2005, 05:19 PM   #8277
Greenbox's Avatar
its really 50,000 wt its a typo and its been solved....there are some posts about it a while back.
Greenbox is offline   Reply With Quote
Old 07-29-2005, 05:23 PM   #8278
Greenbox's Avatar
did u see the new mtx-4 seems it has some design concepts and parts that can be worked on the r40...Specially it has the same type of rear camber/rollercenter setup...Seems to be able to put some parts in the r40 from it . Anyways yea.....whats up and hows everyones r40 doing???
Old 07-30-2005, 12:51 AM   #8279
Hey JAG Racing, do ya have a guess on when those Touring Car Caps will be ready?? I'm tired of running foams and CS-27s.
WingZero is offline   Reply With Quote
Old 07-30-2005, 09:10 AM   #8280
JAG Racing's Avatar
Send a message via AIM to JAG Racing
WingZero - The capped tires have been out for some time... Here is a link.
http://www.bsr-racing.com/cap/ ... looks like BSR is revising the information on the touring capped tires.
What surface are you running on?
Try the 1:10 scale Pro-Lite capped REDS (all 4) or REDS (rear) and GREENS(front). They will run you ~ $50-$60 for a whole set but you'll be amazed at how long they last and the traction they provide. They are 28mm wide.
I think the last time I ran CS-27 with HPI blue inserts the cost was about $40 or so -- the BSR are more expensive but you'll never go back!
JAG Racing is offline   Reply With Quote
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
