Old 07-15-2005, 08:26 PM   #7981
Jaco doesnt make 59mm tires, to accomplish this you will need a tire truer to trim the tires down to this size..... most foam tires are 64mm when you buy them new.
R40LV is offline   Reply With Quote
Old 07-15-2005, 08:54 PM   #7982
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
Originally Posted by AMGRacer
How much runtime we talking here? And does it come good after a resting period?
I'm talking throughout the night.....the harder I run it,the more it changes.....that was with the 2 gear diff filled with 50,000.....I figured the 4 gear would be a mechanical friction,not subject to heat,breakdown,etc...
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 07-15-2005, 09:02 PM   #7983
fastharry™'s Avatar
Btw...the CVEC pipe was absolutley unreal.....a VERY linear powerband....and enough low end to stay with 2 710's with RODY 5 port motors.....(Don't forget,I'm running a std RB 3port non turbo)......the guy with one of the 710's told me a couple of weeks ago,if I had a little more low end grunt,I'd be RIGHT THERE with him in the low speed "s" sections of our track...
I was right there with him tues...all from a pipe change....In fact,in 10 years of running touring,with everything from OS,RB,Dynamite,Associated GT,HPI std metal,and the RD logics turbo II pipes.....this was the only pipe where I actually noticed a very noticable change in power....
Old 07-15-2005, 09:09 PM   #7984
Greenbox's Avatar
ack i hate leaky diffs. I got a solid rear axle up in front and it performs great without the mess. As for my custom air filter elbow... it works fine fits snug and no air leaks... i dont think... Anyway got a few runs in today but my steering was alittle on the bad side. I was thinking of getting a hudy set up board to dial in my car but... i am not sure if it is able to measure the steering rate and endpoints... cause my left is set to 65 and my right is set to 105 and they are identical. If i set the left to 100 its turns wayy to much. so i just wanted to know if i get a set up board of that expense it will do what i want it to do... My car runs a lil bit to the right but no too much. that new bumber i installed saved me big time twice with that bad curb that popped out of nowhere. Its a bit thicker and its wider and longer. Absorbs impacts and looks great too. Anyways i'd like to show pics but my files are waay tooo big ... i was going to show the custom elbow....looks cool its clear u can see the fuel splash around in the carb and the bumper i got...oh well guess i gotta get a photobucket account.
Greenbox is offline   Reply With Quote
Old 07-15-2005, 09:15 PM   #7985
Greenbox's Avatar
oh yeah and the setup tools i am using is a ruler some pencils a paper and my eyes the cvec pipe sounds like a good pipe to have on hand so i can tune my engine more.
How far doesnt it usually take to hit 2nd gear for u guys at full throttle? I dont really get there in the street cause i dont want it to go more than 2 houses away from me.. especially while i am running in the dark with no body..which reminds me . i need a new one. or i can use that ford gt 200mm i had for my electric just a lil adjusting here and there and it could work...
Old 07-15-2005, 09:16 PM   #7986
Default Engine question
I am an rc road newby and have just purchased an r40 along with a friend of mine and my brother. My buddy and I both bought what I thought were Nova Rossie motors but I think they are trinity rossie's. The engine doesn't seem to fit the in the car very well and I wondering if I should have bought something else. So my question is what would be a decent engine for this car for someone new to road racing and at what approximate price and where to buy. We do have experience with RC as we run monster trucks and I also have a Hyper 7 buggy.
canlogic is offline   Reply With Quote
Old 07-15-2005, 09:35 PM   #7987
Send a message via AIM to goldenboy
just lettin you all know that my r40 is for sale. it has almost every upgrade out there, and a novarossi s3. PM me if your interested.
goldenboy is offline   Reply With Quote
Old 07-16-2005, 10:00 AM   #7988
What is the proper way to set droop? Do I need a setup board or can I do it with normal tools? I set mine to the specs listed in the manual and when I put the car on the ground the droop screws on the top of the front stabilizer bar are within (approximately) a millimeter of touching the front bulkhead. If I push the front suspension down I start to feel resistance when the chassis is about a millimeter or two from the ground. If I continue to push down I can make the chassis hit the ground.
rossb is offline   Reply With Quote
Old 07-16-2005, 11:17 AM   #7989
Too properly set the droop on the car accurately, you will need to purchase a set of Droop Gauges..... there are a bunch of them out there.... HUDY, INTEGY and also some are available overseas.
Old 07-16-2005, 12:49 PM   #7990
Greenbox's Avatar
c u bought a rossi... Nova rossi's and rossi's are two different manufacturers. trinity just imports them they dont make them. From what i have heard rossi's arent the best of engines and people had problems with them. did u try sliding the engine through the side where the belt is? the r40 made engine fit a bit tight so sliding it through the right side was the easiest option.
also as for the graphite arms i think hara used them in 2004 because if u take a look at the pic of his car the arms are a tad bit lighter and have a more grey feel to them. Even looks stiffer than stock
Old 07-16-2005, 01:00 PM   #7991
Greenbox's Avatar
didnt the r40 come wiht a gauge? or was it for ride height. I lost it while i was building but fortunatly i still have an old pic.
Old 07-16-2005, 03:38 PM   #7992
thats the ride height gauge.....
Old 07-16-2005, 07:29 PM   #7993
Greenbox's Avatar
oh yea i was thinking of those 2 in1 ride height and droop gauges
Old 07-17-2005, 12:47 AM   #7994
Jea3's Avatar
CVEC makes some nice ride height and droop gauges...
CVEC-RACING.COM
Valkariarc.com | HobbytownRacing.com | SuperiorHobbies.com
Jea3 is offline   Reply With Quote
Old 07-17-2005, 02:43 PM   #7995
Hesky's Avatar
Hi, need a little advice, the 87093 bolt that hold the flywheel onto the sg type crank engines, how tight should it be? should I also use a bit of thread lock. I'm askin this cuz my flywheel position shifted and I couldn't get my engine out of tdc, took the clutch to bits and the blooming nut was loose!!
Cheers
Hesky is offline   Reply With Quote
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
