Old 07-08-2005, 12:23 PM   #7846
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Originally Posted by KLANDERMAN
Thanks, where can I get them???
I heard it might be better to stick with the hpi spring and mugen grey pad. The stronger spring can wear out your thrust bearing.
Artificial-I is offline   Reply With Quote
Old 07-08-2005, 01:28 PM   #7847
JAG Racing's Avatar
Send a message via AIM to JAG Racing
I meant to ask FastHarry about that. My thrust bearings are holding up just fine BUT the outer flanged clutchbell bearing is another issue.
FastHarry - Was it the thrust bearing or the outer clutchbell bearing?
If you are worried about the silver spring, then just get the gold one, its firmer than the HPI black spring.
Klan - Just do a web search for "Mugen Grey". If you can't find a spring, check my E*Bay store, I have one. <JAG Racing Hobbies>
JAG Racing is offline   Reply With Quote
Old 07-08-2005, 01:30 PM   #7848
Moderator
Yeah I guess im also convinced cause thad also suggested that setup.
Old 07-08-2005, 01:33 PM   #7849
Hesky's Avatar
Originally Posted by JAG Racing
Get the Mugen Grey clutch show and the gold or sliver Mugen spring. Your car will absolutely launch... silver is stiffer than gold. Also - try the RED delta clutch for even more bite.
H0765 gray clutch shoe and H0764 hard clutch spring, are those the items John?
Mugen also make an optional red clutch shoe (H0769) and an optional light weight centrifugal shoe (H0766) and an even harder clutch spring! I guess thats the silver one
Hesky is offline   Reply With Quote
Old 07-08-2005, 01:54 PM   #7850
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
clutch bell...
fastharry™ is offline   Reply With Quote
Old 07-08-2005, 02:28 PM   #7851
Moderator
Where can you get the mugen grey for cheap?
Old 07-08-2005, 03:16 PM   #7852
Hesky's Avatar
google threw up a few places that sell them for just over 5 dollars, the red ones are 3 times more though. Are they more durable or do they give better bite, anyone know?
Old 07-08-2005, 03:40 PM   #7853
here is a place that i found that has pretty good prices for the mugen clutch parts
http://www.hobbieguyrc.com/catalog/m...6_products.htm
R40LV is offline   Reply With Quote
Old 07-08-2005, 04:00 PM   #7854
JAG Racing's Avatar
The "red" is typically for 8th scale so it is more durable and yes, provides more bite... maybe a little too much for our .12 engines. I have tried it though and many other 1/10 racers do as well. Try it for yourself.
Old 07-08-2005, 04:02 PM   #7855
JAG Racing's Avatar
Originally Posted by fastharry
clutch bell...
I was afraid you'd say that. I have gone through a couple lately also. In that case I am going to do one of two things: either change over to a mugen clutch bell ( b/c it uses a larger outer bearing ) OR bo back to the Mugen gold spring ( not as stiff as the sliver ).
Old 07-08-2005, 04:29 PM   #7856
fastharry™'s Avatar
here's another place to get RC Mugen stuff...plus twister tires.....Lee is a great guy..
http://gasrccar.com/
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
Old 07-08-2005, 04:43 PM   #7857
AMGRacer's Avatar
I have used the Red and Grey pads, and the silver, gold and bronze (Kyosho) springs. I have 12 hours on my latest clutch setup with no failures. The secret is limiting the amount of endplay.
I use the Red pad in qualifying. It bites like nothing else but you need to run a high engagement point with it or you bog the engine. Also your fuel economy suffers using the Red pad. I like the Kyosho bronze spring, .6 mm pad to clutchbell clearance, 1.5mm on the adjuster nut and .1mm endfloat.
The Mugen Grey is milder and still has some slippage in it. It is less sensitive to having the clutch set "just right". I use the bronze spring on it (similar to mugen silver), .6mm pad to clutchbell, 1.0mm adjuster and .1mm endfloat.
AMGRacer is offline   Reply With Quote
Old 07-08-2005, 04:45 PM   #7858
AMGRacer's Avatar
Yeah my latest non HPI setup which I just picked up to try is this (have not run it yet)
Bought a complete MTX3 clutch setup which includes everything. Only using the HPI flywheel. I bought the aluminium JP Racing Mugen clutchbell, the lightweight Mugen flyweights and a new Red Delta clutchpad.
FYI the JP Racing clutchbell weighs only 4 grams!!
Old 07-08-2005, 04:50 PM   #7859
Moderator
Damn im jealous. Those mtx's seem to have killer clutch setups. Very snappy...but maybe thats the chassis itself.
Old 07-08-2005, 04:54 PM   #7860
JAG Racing's Avatar
I have a JP clutchbell coming in the mail also!! BTW, I talked with Mike Swauger (Team Mugen driver) and he tells me that while it works great, it also requires more maintanence. He has to "clean-up" the contact surface after each race day as the clutch shoe puts a glaze on the clutchbell. But hey, since I have my easy access clutchbell mod now, that's not a problem.
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
