Old 07-06-2005, 07:02 PM   #7786
nsxshogun's Avatar
Send a message via AIM to nsxshogun
Fast harry youre a life saver thats whats wrong. It only happens on my LW 2 speed though. I may have to sand the inside of the housing where the shoe's sit. Or go back to the stock 2 speed.
nsxshogun is offline   Reply With Quote
Old 07-06-2005, 08:07 PM   #7787
On those spacers on the rear hinge pins for the lower a-arms. What do you guys normally run back there.....the manual says to put all 6mm towards the back of the car... i find that to be a little overkill.....just need some insight on what people are running.
R40LV is offline   Reply With Quote
Old 07-06-2005, 08:12 PM   #7788
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
I'm a legend in my own mind..
glad I could help........
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 07-06-2005, 10:12 PM   #7789
JAG Racing's Avatar
Send a message via AIM to JAG Racing
I am running the same (all spacers to the rear for a shorter wheelbase)... adjusting the wheelbase is more of a "fine tune" adjustment. Typically, longer wheelbase is better on "open" tracks while the shorter wheelbase is good for "tight" tracks where you want the car "rotate" around the corner better. I havent played much with this adjustment.
JAG Racing is offline   Reply With Quote
Old 07-06-2005, 11:04 PM   #7790
JAG Racing's Avatar
Originally Posted by AMGRacer
Frankly I dont know. I dunno why my car is light, I just built the 2004 spec as I have said. I cant think of what would be making it any lighter............. I do know that the HPI battery pack is MUCH lighter than others like it, mine weighs 42g. I still use the battery box, and I have a spektrum receiver.
AMG - Do you have a part number for this? I am placing an order from Tower and want to purchase this. What is the current capacity? Is it a 4-cell?
Old 07-07-2005, 02:51 AM   #7791
AMGRacer's Avatar
Foward it is very quiet but will not roll backwards. The mesh is good and I know the one way bearing isn't seized. Its something up with the clutch I just can't figure it out. Also I can't seem to set my middle belt tension right. With a new belt where should I set the tensioniser. I know my belts used to last for ever with the tensioniser set all the way down. But now I can't keep a belt for beans The car would throw it after a while. Also the new belt I brought must have been the wrong one because when I put it on without the tensioniser it was very loose for a new belt. I had belts on my impluse that I never used a tensionser on and it stayed tight. Dang I really need some help .
The teeth of the pulleys will fill up with junk which you need to remove periodically. If you dont they belts can jump right off.
AMGRacer is offline   Reply With Quote
Old 07-07-2005, 02:56 AM   #7792
AMGRacer's Avatar
Hey man its a 5 cell 800mah pack. The thing to remember is not all packs are rated equal. I have a "Venom Racing 1100mah" pack that I cant get more than 700mah into and my HPI pack (which uses high quality sanyo cells and very good internal wiring) I get 780mah into. Its part number 33410.
Old 07-07-2005, 06:42 AM   #7793
Jea3's Avatar
Your using that, instead of the flat pack?
Or did I miss something on a new R40?
Heck, I'm still using the smaller gas tank, that came on the first R40's shipped.
Valkariarc.com | HobbytownRacing.com | SuperiorHobbies.com
Jea3 is offline   Reply With Quote
Old 07-07-2005, 07:07 AM   #7794
Hesky's Avatar
yeah I was wondering that, onnetz or some1 recommended me to get a hump pack battery pack but only flat packs fit on mine, maybe the r40 used both styles at one point. I got a cheap pack of 1200mah nimh cells by Venom Racing, charge to 1300mah on my protrak. 1a linear with a delta peak voltage of 0.06 work well for me.
oh yeah, AI what does this spring do?....
Does it help prevent the pads from dragging or sumit?
Cheers
Hesky is offline   Reply With Quote
Old 07-07-2005, 07:14 AM   #7795
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
smaller gas tank?? How can you tell if you have the "right" sized one?? I bought my R40 used
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 07-07-2005, 07:55 AM   #7796
fastharry™'s Avatar
the bigger tank(which is a full 75cc tank) has a raised lip above the middle seam....
Old 07-07-2005, 08:03 AM   #7797
nsxshogun's Avatar
I ll try to clean them in a little bit. But what about my belts being so loose. Are you guy's new belts loose? I think the hobby shop guy gave me the wrong belt or something.
Old 07-07-2005, 08:26 AM   #7798
Jea3's Avatar
With my wife being a nurse helps measure volumes. This tank holds 71cc of fuel. This car runs out of fuel with 20 - 35 seconds to go. I hope that the extra 4cc's makes run time.
My belts seem like a great fit to me.
Hump pack will not fit in my R40. I'm using a promatch 1100mah flat pack in the car.
700mah - 1300mah, don't really matter if your racer. If your series enough, you should peak those batteries each time you get ready to race. At least I do..
Old 07-07-2005, 09:00 AM   #7799
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Yeah thats the lightweight hpi pack I want to try that as well. Isnt it the same thing as 5 AAA cells. Did anyone try that yet I forgot.
Will these fit in our cars?
Artificial-I is offline   Reply With Quote
Old 07-07-2005, 09:04 AM   #7800
Moderator
Cheers
The brake action for some reason on my car is sticky. With that it always applys pressure. So it never gets stuck braking. I hear some R40's get this problem.
A TRS probably also would work but at that time the car didnt have one. I now have one for racing, since its required but I always use TRS's was just too lazy to buy it. Plus it kinda drains your battery faster.
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
