Old 10-31-2003, 04:07 PM   #736
Regional Moderator
Darkseid's Avatar
Originally posted by treky11
Omar,
That mount is actually for a regular transponder. A personal would need an adapter to be able to mount it there.
The transponder mount appears to be meant for both the regualar and personal transponder. It has the hole in the middle for the regular one, and the three screw holes for the personal.
Why would you need an adapter?
TLR 22...Tamiya F104...
Old 11-04-2003, 07:48 PM   #737
Omar's Avatar
thats what i thought also
Omar is offline   Reply With Quote
Old 11-04-2003, 07:52 PM   #738
rodrigo1508's Avatar
when is hpi going to launch all of the hop ups I bought this car because it won the nats and now I discover that those cars were full of hop ups. If not hpi any other brand
rodrigo1508 is offline   Reply With Quote
Old 11-05-2003, 02:30 AM   #739
Pembalap's Avatar
Hi all,
I just got the R40 kit, and I'm waiting for the engine to finish the R40. I believe that the car is awesome, in term of design. I still have to wait for the engine to test the performance of the R40.
By the way, anybody ever use the Hudy set-up tools on this car? I put my car on the Hudy set-up, and I found out that the left and rear camber is not the same for the front end. I believe the there is about 0.5 degree difference. So, as a fine tune, you might want to measure the camber using a camber gauge...
A.W...from the other side of the the world
Pembalap is offline   Reply With Quote
Old 11-05-2003, 06:30 AM   #740
From my understanding, it wasn't full of hop ups. I think Hara's car only had the hollow shafts which are already out, and the graphite shock towers and a different chassis. I already have the shafts on my car and the only other thing I plan on buying is the shock towers. The car handles too good to add stuff that is not needed.
C0NTENDER is offline   Reply With Quote
Old 11-05-2003, 07:31 AM   #741
treky11's Avatar
Here is what was on Hara's car when it won:
HPI Equipment used:
#823 HPI R40 kit
#75026 Front One-Way Diff
#72170 Aluminum Threaded Shocks
#51063 Shock Springs (rear)
HPI Pro Foam Tires
HPI Titanium Screws
HPI Titanium Turnbuckles
Super Chassis (coming soon)
Front and Rear Graphite Shock Tower (coming soon)
Hollow Gear Shafts (coming soon)
That is directly from HPI's site. They also used a smaller battery, and cut some holes in the top tray.
treky11 is offline   Reply With Quote
Old 11-05-2003, 07:34 AM   #742
Thanks I was getting a little frustrated thinking that now I had to buy a bunch of stuff to make it a good car. As you can tell I havent raced this car yet.
Old 11-05-2003, 08:21 AM   #743
Send a message via ICQ to dgill Send a message via AIM to dgill Send a message via MSN to dgill
Go out and race it and you will see the car is awesome in its stock form, all those hop-ups arent needed for most racers.
dgill is offline   Reply With Quote
Old 11-05-2003, 08:54 AM   #744
Regional Moderator
Darkseid's Avatar
So whats this "Super Chassis" all about? What does it have compared to the kit stock chassis?
Old 11-05-2003, 09:10 AM   #745
treky11's Avatar
I am sure the super chassis is thicker and has more cutouts just like all of HPI's past super chassis.
You can see it in pics on the HPI site.
Old 11-05-2003, 10:34 AM   #746
I would go out and race it but I am still waiting for my engine
Old 11-05-2003, 11:26 AM   #747
The Sleeper's Avatar
Like it has already been mentioned, run the R40 in its' stock form and don't worry about hop-ups. I have a feeling you will be surprised how well it handles. I was and so was several other people.
The Sleeper is offline   Reply With Quote
Old 11-05-2003, 01:49 PM   #748
Regional Moderator
Darkseid's Avatar
Thanks Treky11
Old 11-05-2003, 02:56 PM   #749
Frank McKinney's Avatar
There are additional cutouts on the top side of the chassis also, which you can't see in the picture. It's much stiffer than the stock chassis and about 22g lighter. 7075S aluminum.
Another thing to lose weight is to use 5 700mAh or 800mAh Ni-MH AAA batteries instead of a standard receiver pack. I believe this saves you about 40g. Stack them 3 on the bottom and 2 on the top, solder wire and plugs to it and Goop it or tape it to the receiver tray.
Using a personal transponder will also save you several more grams, I'm not sure of the exact weight difference however.
Hara used the AAA pack and personal to save some weight on his car.
<joke>You can also remove every other fin on your engine head, acid-dip your body and tuned pipe/header, and use a see-through paint job to lose more weight</joke>
Minimal signature to save screen space! Big sigs suX0r
Frank McKinney is offline   Reply With Quote
Old 11-05-2003, 03:09 PM   #750
I'm going to say it again, I saw a difference once I added the hollow shafts. Now everyone will see a difference, but I saw the difference in my lap times and I felt the difference in performance.
You can also change some screws to change your weight if your really concerned about weight. Some screws can be changed to titanium while some can be changed to alum. you will be surprised at the difference in weight screws make.
I'm weighing in at 1765g w/o fuel and w/o a body.
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
