Old 06-17-2005, 04:46 AM   #7411
AMGRacer's Avatar
Originally Posted by R40LV
I got a question...... I run a permanent track and is very well prepared with sugar water and VHT. I am just wondering what a good starting point is for cutting down your foam tires.
It is difficult to answer that question 100%. I would start around 60mm myself and work from there. My R40 loves between 60-58mm at my local track.
AMGRacer is offline   Reply With Quote
Old 06-17-2005, 05:46 AM   #7412
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Originally Posted by jihernandez
that's wierd I though I needed to lean out HSN?
Am using 5-port Sirio engine and my HSN setting now is at 5 turns out which is still a bit rich. hmmmmmm.
Leaning a motor will always increase heat. Because you are taking away the cooling agent , aka the fuel.
When you richen , increase the amount of fuel in the mixture. You cool the engine more by allowing more liquid to enter the chamber at the time of combustion.
The best way to run a motor is to find the optimum tuning point and richen a little to allow the most power and proper cooling. You should also watch your exhaust. If smoke isnt coming out on throttle then your possibly running to hot.
Hope that makes sense. I will post a guide to what you are supposed to do when you are faced with different temperatures , humidities and so on.
Artificial-I is offline   Reply With Quote
Old 06-17-2005, 06:01 AM   #7413
WeatherB's Avatar
Nitro eats tires like crazy... I'm only able to run two races with my nitro on a set of tires while on my electric I can run four or so.
I let the track wear down the tires for me. There is no point in losing those 4mm when the first race is usually just a practice or warm up. I run the practice and warm up on full size tires then true them down to the lowest tire's diameter.
WeatherB is offline   Reply With Quote
Old 06-17-2005, 06:04 AM   #7414
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Tire wearing also depends on car setup, shore, and how you run them. I've had runs for over 30minutes where the foams hardly worn down. That constant high speed runs back and forth and putting down 5-6tanks of fuel. I run 40 Shore GRPs and let them dry out in the air so they last longer. Traction is still great.
Welp, gonna get my R40 and MRX4 to the track on fathers day unless my friend has different plans. Regg are you gonna be there?
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 06-17-2005, 07:37 AM   #7415
regg151's Avatar
Send a message via ICQ to regg151 Send a message via AIM to regg151 Send a message via Yahoo to regg151
at the moment I have plans to take the run up to prospeed providing everything works out.
_______________________________________________________________________
Inferno GT Hyper 21 8 Port Ipanema Tires
Spektrum DX3R
Team CFX Racing, RCNB Race Team, CFX Paintworks.com
regg151 is offline   Reply With Quote
Old 06-17-2005, 08:14 AM   #7416
WeatherB's Avatar
Also depends on the track... I run on a parking lot surface which is very agressive.
Old 06-17-2005, 08:40 AM   #7417
nsxshogun's Avatar
Send a message via AIM to nsxshogun
Got some pics of the lola click the link for them.
nsxshogun is offline   Reply With Quote
Old 06-17-2005, 11:19 AM   #7418
R40Victim's Avatar
My R40 Lola:
http://www.hobbycentralrc.com/SNITZ/...?TOPIC_ID=1118
R40Victim is offline   Reply With Quote
Old 06-17-2005, 11:25 AM   #7419
Suspended
Default R40 pics.
here are my R40 pic.. sorry the pic look so dark...
HPI R40 Nitro Car Forum-18062005.jpg   HPI R40 Nitro Car Forum-18062005-001-.jpg
NaNa is offline   Reply With Quote
Old 06-17-2005, 11:44 AM   #7420
Moderator
Nana. Looks like we have the same motor. Do you know exactly what model number or engine name you have? Also whats your specifications if you know it.
As from what I can tell mine is a 5 port turbo , with the words race and s5 at top. But when looking up info the s5 is designated to be a non-turbo. So I wonder if a turbo model is the t5 race model.
I believe the model number is rs12t5s1
I know our engines are very hard to find and to also find any info on them. Do you have the box still, what does it say on the side. Also do you have the manual and could you show me a picture of your middle speed needle cause im sure mine has been touched from the factory.
Id be really appreciative, your the only person after months of searching that Ive ever seen with it. Funny enough you just so happen to have an r40 and post here....Thanks.
Old 06-17-2005, 11:46 AM   #7421
nsxshogun's Avatar
Is that the new rear sway bar?
I like that lola specially the face in the googles thing.
Old 06-17-2005, 11:52 AM   #7422
Moderator
Originally Posted by R40Victim
HAHAHAHAHAHAAHA. Thats the funniest thing ive ever seen.
If you look at it one way he looks like hes sitting in a black bathtub filled with milk and isnt too happy. Another way it looks like a baby all swaddled up in its blanket in a crib with a silly face.
I think with a different picture that would have looked really cool. But its def funny that face.
Old 06-17-2005, 11:52 AM   #7423
WeatherB's Avatar
You have the T5S1 (or S2) I think... Turbo 5 port
Old 06-17-2005, 12:18 PM   #7424
R40Victim's Avatar
The theory was humor, I thought he made it a little too big. But he was going for the "wearing the helmet" look, that's why it's just my eyes and nose. Next time we're putting a sedan body together, we're putting the whole face on, and adding family and friends and pets as well(my girl will be ridding shotgun, with the inlaws in the back seat, all with the scared crappless looks). It's an Escudo...should look pretty funny. I got it because it looked like an exadurated rice rocket from high school land...
Old 06-17-2005, 02:06 PM   #7425
onnetz's Avatar
I spent most of last night tearing down and reassembling my r40.. This was the first time I had done this and have gone through about a gallon of fuel..
The first thing I noticed was how heavy the axle and bones are.. its like holding a piece of lead... anyone tried the 3racing axle and bones? I found them at rcmart and they look pretty good.. The shocks were only slightly low on oil and the front diff had been leaking leaving me nice gooey mess.. this I was aware of and have cleaned a few times already.. this time I took the diff apart and cleaned it up, refilled it, and it seems to not be leaking anymore but only time will tell. all the bearings are like new again after some motor spray and wd-40..
now I just have to wait for the rain to go away to dirty it up again....
onnetz is offline   Reply With Quote
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
