Old 05-31-2005, 07:34 PM   #7066
WeatherB's Avatar
It's weird since my kit is brand new too. The bearings were very loose. I should try buying an aftermarket plate just to see if it is better. I don't think that the teflon tape will last too long.
WeatherB is offline   Reply With Quote
Old 05-31-2005, 08:46 PM   #7067
regg151's Avatar
Send a message via ICQ to regg151 Send a message via AIM to regg151 Send a message via Yahoo to regg151
Originally Posted by WeatherB
Here is what I did:
1. The two ball bearings that go into that purple aluminum piece were loose and caused the majority of the slop. I removed them and added some teflon tape around them until there was no more slop
2. The small of the two plastic pieces that go into the rods (the rods that are screwed into the bulkhead) needs a few washers on top to fill in the extra gap.
1 I also noticed the slop in the bearings I just received a carbon fiber replacement seems to do the trick there part is by 3racing
2 looking at the car from the front is this the left post or the right post.
another thing I ntoticed if you dont get everything set just right when reinstalling the bulkhead cover it causes sever binding in the steering.
_______________________________________________________________________
Inferno GT Hyper 21 8 Port Ipanema Tires
Spektrum DX3R
Team CFX Racing, RCNB Race Team, CFX Paintworks.com
regg151 is offline   Reply With Quote
Old 05-31-2005, 08:53 PM   #7068
AMGRacer's Avatar
I have a graphite drag plate that I used for a while, and it had more slop than my alloy drag plate. It looks like these plates are stamped not machined so this would explain the difference between plates. A good quality graphite plate will be CNC machined and in theory should have almost 0 slop.
AMGRacer is offline   Reply With Quote
Old 05-31-2005, 10:53 PM   #7069
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Good to hear I got that and was going to make a report on that once installed. Good to know it did fix that problem so, thats also why I got the part. To see if fitment can be made better.
Also the teflon tape will last forever basically. The bearing wont be rubbing against it. It stays still on the outer wall and the interior moves only. And with the tape it will for sure do that now so no sliding around.
But it seems the 3racing graphite plate is the way to go otherwise.
Artificial-I is offline   Reply With Quote
Old 05-31-2005, 10:56 PM   #7070
Moderator
Originally Posted by AMGRacer
Ahhhhhhhhhh now is see why. My bearings fit into my plate with no slop. Must be a machining tolerance thing..................
Yeah mine are sloppy joe style. I will try my 3racing piece tommorrow then and let you know if it doesnt have different tolerances.
LOL this would be funny if it comes down to searching for the "perfect machined" steering plate. I think Ill just stick to my teflon tape if it comes to that.
Old 06-01-2005, 12:56 AM   #7071
Rapid Roy's Avatar
Here is what I did:
Wow, the bearings in both of my r40 are almost too tight. I was a little afraid they might get distorted with the force of driving them in.
Rapid Roy is offline   Reply With Quote
Old 06-01-2005, 03:20 AM   #7072
silver_spo0n's Avatar
Exclamation just got my r40
2nd hand and pretty used up, but i think it still runs
this is my 1st nitro car, i have absolutely no idea what to do with it.
where should i start?
i need some pointers.. thanx!
silver_spo0n is offline   Reply With Quote
Old 06-01-2005, 04:32 AM   #7073
WeatherB's Avatar
Looking from the front it would be the right one (left one being the one connected to the servo).
I think I will add some drops of CA and glue the bearing to the plate while I am installing the other bearings today.
Old 06-01-2005, 05:30 AM   #7074
Moderator
Thats another way, but youll never be able to clean those bearings good again. Also if you bend your plate or something youll have a hard time getting them out.
Im probably going to put together a page of all my findings so people can easily reference it.
Old 06-01-2005, 05:31 AM   #7075
Moderator
Well im glad we figured out why a lot of people have or dont have slop. This is good stuff.
Old 06-01-2005, 06:13 AM   #7076
WeatherB's Avatar
I think I will take that chance... Bearings aren't too expensive anyway.
Old 06-01-2005, 07:13 AM   #7077
Hey Everyone,
I am new to this forum.... and am looking at getting an R40... I am not new to the RC scene. I am just wondering what are the best hop-ups to get for this car. I already have the lightweight chassis and front one-way on the way.....what do you all think woud be good upgrades also.
R40LV is offline   Reply With Quote
Old 06-01-2005, 07:42 AM   #7078
regg151's Avatar
interesting on mine the right post is fine dosen't move at all it's the left post (connected to the servo) that moves about 2mm up and down on the shaft with everything bolted down.
I'm using the GPM alloy servo saver.
Spektrum DX3R
Old 06-01-2005, 07:46 AM   #7079
regg151's Avatar
Originally Posted by R40LV
Hey Everyone,
get both LW shafts and the LW 2 speed as well as the graphite shock towers those are IMHO the best upgrades to get.
I'd suggest reading thru this thread as you'll find some very usefull information that will answer questions you wouldn't even think to ask, I know it's a lot of reading but it's worth it for all the knowlage contained in this thread.
Spektrum DX3R
Old 06-01-2005, 08:00 AM   #7080
WeatherB's Avatar
On mine it is the opposite, the one with the servo attached doesnt move.
You don't really need any hopups for this car! The carbon stuff is mostly eye-candy but does save some weight.
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
