HPI R40 Nitro Car Forum >
Old 10-16-2003, 04:14 PM
  #676
fastharry™'s Avatar
Location: Louisville, KY!.. USA!! ....Home of http://www.fastharry.com
Originally posted by Fisher890
Ok.........
Well I'm done with my research everyone tells me to buy the MTX 3 so I'm going with the R40. Just seems easier to tune and I'm not as much as a perfectionist about small details. After I hit the wall several times I doubt either one of them will run very well anyways so... anything other then the front oneway to buy before I start building it Sat? Lubes ,oils, Loctite, Special tools? Any other hop ups I can't go without before I put it all together?Anything I need to lookout for over tightening or unclear instructions? I'd hate to repeat any mistakes that I might make that everyone else knows about. all input will be greatly appricated! Thx
I'll tell you one thing...I wacked the boards a few times with my R40..and never had to trim the steering......(l or R)......My tc3,every few times, wouldneed to be re trimmed..
fastharry™ is offline
Old 10-16-2003, 05:03 PM
  #677
treky11's Avatar
Craig - wait till next season to get the tires. Fresher foam or rubber is always better. Plus some of the manufacturers are coming out with some new stuff so you might get something better or different come the start of next season.
treky11 is offline
Old 10-16-2003, 05:08 PM
  #678
Fisher890's Avatar
Hey harry
I saw those lightweight motor mounts you posted. Did you get those or was that just something you saw? How much lighter are they and do they help with engine cooling?Or are they just purple.......?
Fisher890 is offline
Old 10-16-2003, 06:11 PM
  #679
CraigH's Avatar
Thats true.. Thanks
CraigH is offline
Old 10-16-2003, 07:30 PM
  #680
fastharry™'s Avatar
Hey harry
they are on HPI's japanese web site.....I'm sure they are lighter....
I will get them,if they are available in the US....
OH ..wait a second...no ,more having to give the foreign teams an advantage......
I'll get them quicker than you can say.......UPS.
Old 10-17-2003, 12:56 AM
  #681
The Sleeper's Avatar
Fisher,
when I put my R40 together, I installed the thrust bearing for the centax clutch backwards. What happened was I didn't noticed the washers were different, one has a bigger hole than the other. The big hole goes in first toward the engine. I can't remember if the instructions are clear about that.
The Sleeper is offline
Old 10-17-2003, 12:54 PM
  #682
Fisher890's Avatar
Great info thx sleeper! I start building in T- 23hrs 30 mins.........
Old 10-17-2003, 11:51 PM
  #683
luketob's Avatar
Hi all,
What should i check when the car push to the right when throttle is applied. I rebuilt the rear diff and it runs better for couple laps and start pushing the same direction again after a while. What other possibilities could i check?
Cheers...
luketob is offline
Old 10-18-2003, 12:23 AM
  #684
Tires would be my first guess. Those suckers have a way of making a car pull, especially if one is smaller or of different shore.
The next thing I would check is the shocks. They too can make a car act weird especially if one has leaked the oil out.
Good Luck
Old 10-18-2003, 01:04 PM
  #685
Omar's Avatar
Trader Rating: 15 (100%+)
has anyone had problems with the front diff leaking. my started to leak but i fixed it with a new diff case.
Omar is offline
Old 10-18-2003, 09:52 PM
  #686
Registered User
OB42TC3's Avatar
Default R40 weight
So how much does the R40 weigh w/body, no fuel, foam tires? anyone got any idea?
OB42TC3 is offline
Old 10-19-2003, 09:32 AM
  #687
Omar's Avatar
1725g. with half a tank isn't to bad considering the R40 tanks is 72cc.
Omar is offline
Old 10-20-2003, 07:02 AM
  #688
JLock's Avatar
Your R40 must be milled out to the max. My R40 with body, empty tank, 600mah NiCd receiver pack and foam tires came in a a whopping 1825g. However, if the tank is not 75cc, I can still get 6 to 6.5 min per tank.
JLock is offline
Old 10-20-2003, 07:46 AM
  #689
I am looking at nitro cars and was wondering how well the plastic is holding up over time on the R40? I ran RS4s in the past and over time they would get pretty loose. Thanks for any opinions and comments.
Doug Gaut is offline
Old 10-20-2003, 07:54 AM
  #690
Does anyone know of any direct replacement parts from other companys for the R40, such as pivot balls, pulleys, etc?
And I'm weighing in at 1814g with a full tank of gas.
C0NTENDER is offline
