Old 05-20-2005, 01:55 PM   #6871
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Awesome site!
AI- Did you order all your stuff from 3racing? I think I can try to have my LHS order it for me. Still giving this real car a chance, but soon forget about it. Most likely will sell some stuff to make way for the R40 parts.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 05-20-2005, 02:29 PM   #6872
performula's Avatar
Originally posted by Artificial-I
Here we go.
I also already have the cf front shock tower on the car and the side / mid cf brace.
As well the rear shock tower should be here....*knock at door*. Ok its now here....lol. That was freaky. Right when I typed should be here...I get a knock at the door.
Thats a good bit of weight savings im hoping.
Also the gpm front sway bar and gpm steering kit is better than 3racing. So just letting people know.
How are the GPM products?
performula is offline   Reply With Quote
Old 05-20-2005, 04:03 PM   #6873
Rapid Roy's Avatar
Here we go.
Those pinions you got are for the standard 2 speed. I'm pretty sure that the LW ones are all bronze.
Rapid Roy is offline   Reply With Quote
Old 05-20-2005, 04:42 PM   #6874
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Yeah I just wanted the stock gears. The ones that are on the car are all chewed and different.
I would have gotten the hardened ones...but dont really see the point at almost double the cost. Just buy two stockers...im sure the stock ones are lighter. Maybe not....
Maybe I should have gotten something else but Im not sure whats good right now so I figured stock would be ok.
Artificial-I is offline   Reply With Quote
Old 05-20-2005, 04:49 PM   #6875
Moderator
Originally posted by HarKonnenD
Awesome site!
I got it from rcmart. From what everyone said they are cheaper than 3racing direct. Just some have had trouble with orders.
I also used their 6.99 3-6 day delivery service vs the 2-3 week one. Came in pretty quickly and for 3 dollars more I can deal with it.
But shipping total was 6.99 or whatever and it was pretty quick and they havent gotten my order wrong yet.
The GPM products are good. I would say just by looking at things that 3racing is better. But the gpm I used to have on my rs4 where they seemed a little bit more popular then.
They had the best steering kit then and now it seems they still have a good one along with the front sway bar kit has the bars included.
The rest I would say 3racing is good except there steering kit is probably the worst Ive ever seen. Just 2 little things on it were wrong and it makes the kit completely worthless. Your car will perform worse with it. So I highly suggest against that kit.
But yeah looking at the gpm part to the 3racing. The gpm looks very plain. While 3racing has lots of wild cuts and designs and angles to all there parts. Looks very nice.
Fitment so far has been excellent from 3racing except for that steering kit. Thats been the worst part Ive ever seen from a company so far. Im just going to chalk it up to whoever took a look at the stock part didnt really analyze why what was what. I believe he was trying to make it put less pressure on the brace...for smoother movement. But it allows the brace to wobble around. Making for the worse slop ever.
Old 05-21-2005, 01:39 PM   #6876
HarKonnenD's Avatar
Jag-About the lola thing, the setups still aren't the same. Really need the Lola mount in order for it to work the REAL way. Mounting the lola to body posts, vs mounting one the way have are totally different (regarding mouting). We need to conduct a test though to see if it really works the same way, because IMO I dont think it does.
Klander- Think the only upgrades Ill get for now is the two items I ordered at the LHS and the LW chassis. Anything else I really don't need.
Old 05-21-2005, 01:46 PM   #6877
JAG Racing's Avatar
Send a message via AIM to JAG Racing
I hear you, but if you just run a sedan body vs the Lola (even with the improper mounting system) which provides more downforce? That is my point, it isnt the ideal mount but the body alone provides more downforce making it a faster body.
JAG Racing is offline   Reply With Quote
Old 05-21-2005, 01:50 PM   #6878
HarKonnenD's Avatar
Ahhh IC. Still for some reason though at high speeds with the skyline body the car felt pretty stable. I need to make time to do more experiments. Gonna test it with the new gear and my 26mm GRPs again. I just liked how the mounts press onto the hubs rather than pressing onto the shocks. HMm, maybe monday I can go give both of them a try as well as running without the restrictor.
Old 05-21-2005, 02:26 PM   #6879
JAG Racing's Avatar
The Lola will "shine" on medium-to-high-speed sweepers so if you want to compare make sure you compare under these conditions. Almost any body with a reaer wing is stable at high-speeds. The Lola provides much downforce at medium speeds such as infield cornering and sweepers. Set up a medium-high speed chican and see which one is quicker through this type of layout.. Let us know!
Old 05-21-2005, 03:14 PM   #6880
onnetz's Avatar
I think what he was getting at is that if you have the lw 2speed then those pinions wont work...
onnetz is offline   Reply With Quote
Old 05-21-2005, 05:20 PM   #6881
gfd2726's Avatar
Send a message via AIM to gfd2726
HI,
Can anybody tell me where I can find some 1/10 lola body that will fit in a R40? What other parts needed in order to fit a lola body? Thanks!
gfd2726 is offline   Reply With Quote
Old 05-21-2005, 06:02 PM   #6882
KLANDERMAN's Avatar
hey dude try www.rcmart.com they have the kyosho 1/10 lola body.
good luck!!!
KLANDERMAN is offline   Reply With Quote
Old 05-21-2005, 07:12 PM   #6883
Moderator
I have the 3racing 2speed housings I believe. Yeah im not sure about the hpi lw 2speed. Whats the deal on that. Is it better than the 3racing stuff or is it something totally different.
Old 05-21-2005, 07:44 PM   #6884
regg151's Avatar
Send a message via ICQ to regg151 Send a message via AIM to regg151 Send a message via Yahoo to regg151
It's something totally different, the gears are smaller on the LW 2speed not to mention the loose of rotating mass.
_______________________________________________________________________
Inferno GT Hyper 21 8 Port Ipanema Tires
Spektrum DX3R
Team CFX Racing, RCNB Race Team, CFX Paintworks.com
regg151 is offline   Reply With Quote
Old 05-21-2005, 08:19 PM   #6885
HarKonnenD's Avatar
Yeah. Pretty much you can slap a taller pinion on the LW 2speed if needed. Once you go LW you never go back.
Jag-Sry to carry it on again, but I've been studying the true lola mounts and that even had me going to the LHS to see it. Again, it seems as when the wheels/shocks are pushed upward, the linkage pushes the body up for more downforce. After watching several clips I noticed it. As for running at high speeds, I'm really sure how it reacts. I guess naturally the air would be pushing it downward, but at the same time if the suspension compresses, the linkage pushes the body up. Hmmm.. Probably running an 8th in a wind tunnel on one of them belt driven ramps will work though. I'm gonna now try to make my own lola mount and use the linkage. I probably will be able to finish it by tomorrow otherwise maybe monday. So after dialing the car into the lot, gonna test it with the skyline body, the lola body, and lola with custom floating mount.
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
