Old 05-20-2005, 11:08 AM   #6856
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Does anyone know how much the 3racing chassis weighs?
Artificial-I is offline   Reply With Quote
Old 05-20-2005, 11:08 AM   #6857
Send a message via AIM to Midak
Originally posted by HarKonnenD
Sounds good. I've heard about the one in hartsdale, but I'd have to talk the bus there and it's quite a ride. I have $$, but no way of going right now. I live in Port Chester. As for Steering I have no problem with it. Just saying that with my setup it won't do what you don't want it to, which is a good thing.
Oh, I oculd have sworn I saw you post that you shop at Bruckner.
Midak is offline   Reply With Quote
Old 05-20-2005, 11:10 AM   #6858
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
What's the webpage to the 3Racing chassis? I wanna compare prices since Tower's pretty high and won't be in for a while. I'd like to deck out the R40 a bit, while I try to sell some of my other stuff. Here's what I have to sell
MGT (less body, tyranny)
TL01 super RTR( bunch of elec crap, etc).
MT12 (nothing for it to really go in. RB is more powerful and reliable anyway )
HB buggy (Not really sure if I'd sell it all, because if I do, then I'll get the AD2 and some other engine to race at Barn Stormers. Doing the R40 and running the 8th buggy will be too much with a real car, so I'm knocking the buggy off. I don't drive it much anyway.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 05-20-2005, 11:11 AM   #6859
HarKonnenD's Avatar
Oh naw, that's my friend Bill. He got his chassis for $64. Tower is $10 more. I'll keep browsing around.
Old 05-20-2005, 11:18 AM   #6860
KLANDERMAN's Avatar
awesome tip HARK, right now I have my car set up to race with the lola body, it is handling way better than anything I have tried before, but I will try the offset tip next week...
BTW this is the track I'll be racing at this weekend...
KLANDERMAN is offline   Reply With Quote
Old 05-20-2005, 11:20 AM   #6861
KLANDERMAN's Avatar
It is at El Salvador, which is around 2 1/2 hours away, but what I like is the fact that is on top of a hill and you can see San salvador, the city... lol
Old 05-20-2005, 11:22 AM   #6862
ogreasurada's Avatar
http://www.3racing.com.hk/options.js...Hpi&carkit=R40
ogreasurada is offline   Reply With Quote
Old 05-20-2005, 11:30 AM   #6863
Moderator
They have the 3racing chassis listed @:
Weight 123.00 g
Net Weight 115.00 g
So I have no clue what weight it really is. Sounds heavier right?
Old 05-20-2005, 11:34 AM   #6864
KLANDERMAN's Avatar
hey you guys my stock chassis was 120 grams, get LW, it weighs only 90 grams!!!
Old 05-20-2005, 11:35 AM   #6865
Net weight is only the product, weight is with the packaging i believe.
Old 05-20-2005, 12:18 PM   #6866
JAG Racing's Avatar
Send a message via AIM to JAG Racing
Default weight delta
I measured 22 grams lighter going from stock chassis to HPI LW Chassis.
JAG Racing is offline   Reply With Quote
Old 05-20-2005, 12:32 PM   #6867
JAG Racing's Avatar
Default Lower gearing option
Now that many of us are running the LW 2-speed which uses the 0.8 gears here is a simple way to improve your gearing for improved acceleration. On the main drive shaft (shaft that has the 2-speed on it) replace the 19T (two of them) with 18T pulleys.
By changing both,the "overdrive" ratio remains the same but the main shaft/rear axle ratio is changed from a 0.413 ratio to 0.391 ratio.
Example : 0.391 ratio meaning that the main drive shaft rotates 2.55 times for evey one revolution of the rear axle. (inverse of 0.391 = 2.55). Compare this to 0.413 (main drive shaft rotates 2.32 times for every one revolution of the rear axle). Thus the .391 provides more engine RPM for same speed.
-----------------19T------- 18T-------------
axle ratio ------ 0.413----- 0.391----------
I'll try it out to see how significant improvement this is. It might just be easier to run a lower profile tire instead.
Old 05-20-2005, 01:01 PM   #6868
Moderator
Well my last parts are coming in. Just got another shipment from rcmart. This is the motherload.
The car will be done after this, but with the hara coming im not sure what I might do with all these option parts.
Ill post pics in a moment.
Old 05-20-2005, 01:50 PM   #6869
Moderator
Here we go.
I also already have the cf front shock tower on the car and the side / mid cf brace.
As well the rear shock tower should be here....*knock at door*. Ok its now here....lol. That was freaky. Right when I typed should be here...I get a knock at the door.
Thats a good bit of weight savings im hoping.
Also the gpm front sway bar and gpm steering kit is better than 3racing. So just letting people know.
Old 05-20-2005, 01:51 PM   #6870
HarKonnenD's Avatar
SWEET!!!! Thats the SAME track I saw when I was first learing the hobby!! Sick!
Jag-Great idea man. I thought of using the 20T pinion for first instead. If I remember correctly the stock LW pinion was 21 or 22, but I'll check.
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
