Old 05-16-2005, 04:05 PM   #6751
AMGRacer's Avatar
Originally posted by Rapid Roy
You have a good point. I was going on the assumption that his grip wasn't as good as he was thinking it was. If the traction really is good, it could also be too soft springs causing the chassis to bottom.
Yep you are spot on. I dont know his track so I am guessing as well
AMGRacer is offline   Reply With Quote
Old 05-16-2005, 06:18 PM   #6752
Send a message via AIM to Midak
Reg, if you are talking about FBF, I tired the gold springs out there with the same 4 spider diff and it worked well for me.
Midak is offline   Reply With Quote
Old 05-16-2005, 06:27 PM   #6753
regg151's Avatar
Send a message via ICQ to regg151 Send a message via AIM to regg151 Send a message via Yahoo to regg151
yes indeed I'm talking about FBF I'm going to have to give that a shot.
_______________________________________________________________________
Inferno GT Hyper 21 8 Port Ipanema Tires
Spektrum DX3R
Team CFX Racing, RCNB Race Team, CFX Paintworks.com
regg151 is offline   Reply With Quote
Old 05-16-2005, 06:28 PM   #6754
AMGRacer's Avatar
So the grip is pretty high there?
Old 05-16-2005, 06:31 PM   #6755
regg151's Avatar
so far it's the highest grip surface i've found so far. it's fairly consistant all around from the years of nitro and foam residue.
Spektrum DX3R
Old 05-16-2005, 06:46 PM   #6756
AMGRacer's Avatar
That being the case you may need to use the golds as suggested. If you car is bottoming out at the rear due to too much grip it may act like yours. Reason I say that is that you mention it does it on throttle, ie when weight transfers backwards.
Old 05-16-2005, 08:21 PM   #6757
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Some random shots of my R40.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 05-16-2005, 08:22 PM   #6758
HarKonnenD's Avatar
Those are my 2yr old GRP foams. Still got plenty of foams on it to burn.
Old 05-16-2005, 08:25 PM   #6759
HarKonnenD's Avatar
These are the dish rims.
Old 05-16-2005, 08:31 PM   #6760
HarKonnenD's Avatar
more shots.
Old 05-16-2005, 08:32 PM   #6761
HarKonnenD's Avatar
Another shot. Those are 30mm rear. It's 37 shore all around.
Old 05-16-2005, 08:33 PM   #6762
HarKonnenD's Avatar
body on.
Old 05-16-2005, 08:49 PM   #6763
ogreasurada's Avatar
That's one of the coolest R40 I ever seen.
ogreasurada is offline   Reply With Quote
Old 05-16-2005, 08:52 PM   #6764
HarKonnenD's Avatar
Basically I realized the Lola isn't working the way it should. See lola's regularly work as when the shocks compress, it pulls the body down with it. By just using a regular lola body and no floating mount when you do get more downforce the shocks compress. Gonna find one that will fit on it and try it out.
Old 05-16-2005, 09:07 PM   #6765
JAG Racing's Avatar
Send a message via AIM to JAG Racing
Huh?? The benefit of the Lola vs a normal sedan body is simply the increase in downforce due to the aerodynamic affects. More downforce means better tire contact to the ground which can equal to better traction. Lolas are known for providing great steering response - what are you expecting out of the Lola? . I don't understand your point when you say"...when the shocks compress, it pulls the body down..". I think you have it backwards; as the body is forced down by wind resistance this force is what is compressing the springs. Keep in mind that this force is increased at "high" speeds. Why do you say it is bad if your springs are being compressed slightly? By the way, do you know how much the springs are compressing as you are going at full speed?
I have never heard of anyone complaining about the handling of a Lola body. Matter of fact, try to run a Lola body in Sedan class and see how many people complain that you have a unfair advantage.
My .02
P.S. -- Nice Paint Job
JAG Racing is offline   Reply With Quote
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
