Old 05-16-2005, 11:53 AM   #6736
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Well just finished building my Cabinent O RC. MY RC Room is coming together.
Ill post pics once im finished. Most everything I own is tagged with HPI something too. But yeah in one cabinent. First level. I have my starter box , r40 sitting on top with a body on it.
Fuel gallon , Fuel Bottle , Couple of sets of ellegis. Batteries and other misc goods, temp gauge.
Next level, My racer2 sitting on top of an integy droop gauge and blocks. With a bunch of unopened HG parts sitting behind it for background. No tires on it and a orange silvia body sitting on top of it.
Next level a XXX Kinwald Edition Buggy in purple , with purple body clips and a purple battery pack.
On top of the cabinent a AD truck.
So far so good that helped organize my kits up quite a bit.
Artificial-I is offline   Reply With Quote
Old 05-16-2005, 12:32 PM   #6737
Rapid Roy's Avatar
Originally posted by regg151
ok I was running 38 front/ 40 rear jaco nitro shoes.
still running the stock springs
3mm front / 4mm rear
graphite towers front & rear
stock rear sway bar
front sway bar set 90* vertical
4 gear diff rear w/lt grease
only changes I did was to put in the 4gear rear diff and change the front sway bar to 90* vertical instead of horizontal. I never had a problem with the rear before now.
the track surface is high bite never had a problem running 40 in the rear.
body was a hpi ford mondeo.
The change in the wear of the rear tires is caused by switching to the 4 gear rear diff. The rear end is more planted now since the inside wheel isn't lifting and spinning. This causes the outside rear tire to bit much harder which is making the rear tires wear faster. This is a good thing. It means you are pretty hooked up.
Rapid Roy is offline   Reply With Quote
Old 05-16-2005, 01:56 PM   #6738
regg151's Avatar
Send a message via ICQ to regg151 Send a message via AIM to regg151 Send a message via Yahoo to regg151
I figured it would help with rear traction but it actually made it worse. I expect the rears to wear faster then the fronts but why was the rear end wanting to slide out so often didn't take much if I even tapped the throttle it would break loose and want spin out regardless if it was at the end of the sweeper or a 180* turn the rear was very loose under power.
_______________________________________________________________________
Inferno GT Hyper 21 8 Port Ipanema Tires
Spektrum DX3R
Team CFX Racing, RCNB Race Team, CFX Paintworks.com
regg151 is offline   Reply With Quote
Old 05-16-2005, 02:08 PM   #6739
performula's Avatar
stock rear sway bar
Worse case scenario you might be able to run the same shore tires front and rear, but nearly all the time, the rear tires should be a softer shore. I run a harder compound in the rear for practice and parking lot runs.
performula is offline   Reply With Quote
Old 05-16-2005, 03:10 PM   #6740
regg151's Avatar
same here I was running the 40's in the rear just for practice. but even still I was surprised by how much the rear end broke loose on the high traction surface. I've run 42 shore front and rear and never had this problem on this track.
Spektrum DX3R
Old 05-16-2005, 03:34 PM   #6741
AMGRacer's Avatar
Originally posted by fastharry
nope...I was talking about the lightweight mounts that came with the 2004...wher can I find the one piece?...
I am just interested in feedback. Sometimes I think I talk myself into believing things about certain hopups, but I could swear that my motor revs cleaner and stronger on the top end with the 1 piece mount. RC Champ can supply it, it is an Atsushi Hara item. I really love mine, see above I swear it makes a difference.
AMGRacer is offline   Reply With Quote
Old 05-16-2005, 03:34 PM   #6742
Rapid Roy's Avatar
You might need to go back to the 2 gear diff in the rear if you are loosing that much rear traction. The 4 gear is for higher bite conditions. You might also try just grease in the rear diff. The 4 gear diff has more mechanical friction so its stiffer from the get go.
Old 05-16-2005, 03:38 PM   #6743
AMGRacer's Avatar
If you are running the 4 gear diff with light grease then the rear diff should not be making the car spin out by itself. You may be "diffing out" or you may have the rear too stiff in general. If you went from a 2 gear to 4 gear rear diff and it made it worse it seems the in general your rear end is lacking grip as the change to the number of gears is a fairly subtle adjustment.
Old 05-16-2005, 03:39 PM   #6744
Rapid Roy's Avatar
You might also try removing or softening your rear roll bar.
Old 05-16-2005, 03:40 PM   #6745
AMGRacer's Avatar
If you were on a high grip surface then you easily should be able to run the 4 gear rear diff along with 30K weight rear diff oil. This is my usual setup. Seems something is wrong or imbalanced in your car.
Old 05-16-2005, 03:43 PM   #6746
AMGRacer's Avatar
I would normally agree Roy, but if the surface is truely high traction this is going the wrong way. The rear end will begin to overroll.
My rear setup for the 2006 worlds track, which is fairly high grip, is 40 shore rear tires, 30K 4 gear diff, 3mm droop, 5mm ride height, gold springs, 3 x 0.8mm hole pistons, 50wt shock oil, black swaybar set on the outer linkage hole, shocks layed down. Thats a fairly typical rear setting (look at Haras setups) for any track you would consider "high grip".
Old 05-16-2005, 03:48 PM   #6747
Rapid Roy's Avatar
My understanding on the purpose of the one peice engine mount is to allow the motor to rev easier since base is supported more stiffly. I have not tried that mount so I couldn't tell you for sure.
Old 05-16-2005, 03:50 PM   #6748
AMGRacer's Avatar
Yep thats my understanding as well. But I wonder whether I am deluding myself as well
Old 05-16-2005, 03:51 PM   #6749
Rapid Roy's Avatar
You have a good point. I was going on the assumption that his grip wasn't as good as he was thinking it was. If the traction really is good, it could also be too soft springs causing the chassis to bottom.
Old 05-16-2005, 04:05 PM   #6750
regg151's Avatar
rapid roy- the track is extremly high bite it's a permanent location even thou the layout changes almost every week.
I'm running just the 4 gears and the moly greese that came with the kit.
as you mentioned it could be that the chassie was bottoming out i'm running the kit springs with 30wt oil.
I'm also wondering if I just have too much power getting to the wheels too early?? Nahhh
Spektrum DX3R
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
