Old 04-25-2005, 08:14 AM   #6166
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
Originally posted by Hp1RaCeR
hey guys, i was wondering if any of you guys got a nice stup for the HPI rs4 generation 1. I got back into electric now that summer in nyc is here i wanna get back into nitro. Anyone know of any tracks in nyc area eather?
we race in Nanuet NY on tues nites.........parking lot track(100 x 125)....road rail,lights,stand....and this year,transponders(personal)..and computer.....start around 7 PM.....ends...when we get tired(on some nights last year,we ran till 1 am)...........
we still haven't figured out how many play vs race nights we are gonna have....its still not quite warm at night,and the guys haven't showed up full force.....I won't be ready for 2 weeks either.....
touring ONLY.....we might run electric also.....also,we might have a stock HPI class.....running ONLY hpi cars(NO R40s) with the new wide tires and wheels fron HPI...and ONLY non racing bodies(lambo's,pantera etc)...sort of like a stock class with cool bodies...
all that,and you get to meet fastharry..(and see how slow i really
am...
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 04-25-2005, 08:55 AM   #6167
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Originally posted by fastharry
[B...
am...
)... [/B]
LOL! Hey man, you guys don't race in the day? Only nites?
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 04-25-2005, 12:07 PM   #6168
HarKonnenD's Avatar
2nd tank on this engine and it's revving almost as fast as my MT12!!?!? . This is the break in method it recommends. It's running fast, but is still rich. Regardless, this engine is a MONSTER! Don't think I'll ever put the MT12 back in.
Old 04-25-2005, 05:12 PM   #6169
Greenbox's Avatar
well almost done rebuilding my r40 i hate rebuilding shocks its so messy when u make a mistake. I got some silicon oil on the floor and tracked with my socks all the floors even the carpet where like an ice rink Well if there any tips to build shocks plz give....Cause i could use a lil help. I thought the ones in the instructions were fine.... I put some associated green slime form\ the o-rings for a better seal too. As for the starter box...mine works perfectly. Once i noticed the car had to be alligned more to the right its just bump and go. No more burn't rubber on the bottom of my chassi
Greenbox is offline   Reply With Quote
Old 04-25-2005, 05:17 PM   #6170
gfd2726's Avatar
Send a message via AIM to gfd2726
Originally posted by performula
What body did Hara use for his races in 2004? I know it was a Mazda 6, but who was the manufacturer?
My guess maybe Mazda 6 body from protoform?
gfd2726 is offline   Reply With Quote
Old 04-25-2005, 05:24 PM   #6171
nsxshogun's Avatar
Send a message via AIM to nsxshogun
I thought it was the aero 2 stratus from hpi.
nsxshogun is offline   Reply With Quote
Old 04-25-2005, 08:20 PM   #6172
onnetz's Avatar
Default 2speed
I've got everything running fine now except for the 2speed..
I went by the book(as helpful as it is) and still no shifting..
right now I have the screws at four turns out..
should the second gear spin freely forward and backward? (this is before installing the engine.. )
I know the first gear has the one way bearing..
looking at the directions it looks like the set screws holding the balls in should be sunk all the way in.. mine wont go that far..
If I do it binds up the balls..
thanks for any help you have to offer.....
onnetz is offline   Reply With Quote
Old 04-25-2005, 08:23 PM   #6173
J.Gonzalez's Avatar
Trader Rating: 16 (100%+)
Default r40 for sale
check it out in the for sale section
J.Gonzalez is offline   Reply With Quote
Old 04-25-2005, 08:45 PM   #6174
JAG Racing's Avatar
Send a message via AIM to JAG Racing
Default Re: 2speed
Adjust the set screws so that as they are tightened down, they force the two shoe halves apart by only a slight bit ( per manual ).
Then try this..
(1) pull off 1st spur gear and inspect the the clutch shoes can easliy be removed from the second gear housing. If the shoes can slip in and out you are OK. If the shoes won't come out , the adjustment screws need to be tightened more ( probably not your situation though ).
(2) install and start the engine
(3) hold the R40 by the roll bar handle and hit full throttle for about 2 -3 seconds. As the transmission shifts, you will feel the car "rock" in your hand. If its not rocking, then turn off engine and adjust the two clutch adjustment screws CCW 1/4 turn each.
(4) restart engine and hit throttle to see of it shifts.
repeat step (3) until you feel the car shift. This is only a crude method. Eventually you will need to fine-tune the shift point under car acceleration ( on the track ).
JAG Racing is offline   Reply With Quote
Old 04-25-2005, 08:48 PM   #6175
Dstan's Avatar
Send a message via Yahoo to Dstan
Default Re: 2 speed
If you hold the rear tires while using the gas, you can also feel them shift this way.
Dstan
Dstan is offline   Reply With Quote
Old 04-25-2005, 08:54 PM   #6176
JAG Racing's Avatar
Default Re: Re: 2 speed
Dstan
Sounds painful
Old 04-25-2005, 08:56 PM   #6177
nsxshogun's Avatar
The rear wheels wont move if you hold them.
Old 04-25-2005, 09:09 PM   #6178
KLANDERMAN's Avatar
LOL ...you probably have to tighten the screws more, assuming you assembled the clutch correctly. Your car is probably starting off in the 2nd gear as your screws are too loose!
KLANDERMAN is offline   Reply With Quote
Old 04-25-2005, 09:11 PM   #6179
onnetz's Avatar
Default Re: Re: 2speed
I think this is the part I messed up on..
I dont have the set screws tight enough to force the shoes apart.
thanks for the help...
Old 04-25-2005, 09:15 PM   #6180
onnetz's Avatar
I tried 7 on down to 4 turns out and no change..
i'm sure its not running in 2nd gear, it tops out too fast......
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
