Old 04-22-2005, 05:56 PM   #6121
KLANDERMAN's Avatar
Originally posted by onnetz
Hey guys,
I'm just finishing up building my r40 but am having trouble with the wiring.. I cant seem to find enough room for it all in the battery box..
how did you wire everything?
thanks..
hey dude this might help...
KLANDERMAN is offline   Reply With Quote
Old 04-22-2005, 05:59 PM   #6122
onnetz's Avatar
yeah that does help.. I was trying to run all the wires through the battery box to the rx..
onnetz is offline   Reply With Quote
Old 04-22-2005, 06:04 PM   #6123
KLANDERMAN's Avatar
here is another one
Old 04-22-2005, 06:05 PM   #6124
KLANDERMAN's Avatar
Originally posted by SasonRC
Here is the info on spektrum.
Link
SasonRC- thanks for the link!!! very interesting info...
Old 04-22-2005, 07:49 PM   #6125
Dstan's Avatar
Send a message via Yahoo to Dstan
Default Top Heavy
When you pick your car up, does the nose go down? My front end seems to be heavier then the back, not balanced. Any suggestions, help? Or is this normal?
Dan
Dstan is offline   Reply With Quote
Old 04-22-2005, 09:47 PM   #6126
performula's Avatar
Well I finally got my kit together, just need to get my charger back from warranty to charge up my Receiver Packs. I do have a two questions about the stock set-up.
I have gone over the whole car to make sure I have the correct shims/washers at each designated area for the suspension settings. I have opted to leave out the allen screws that limit down travel. Everything looks good a feels good; however, why is there so much rear negative camber? with my old RPM camber gauge the reading came out to 3.5 degrees on both sides.
The other question is that when I roll the car back and forth it does not seem to track straight back and forth. With the wheels straight after rolling the car forth and back 4-5 times the car will move to the left at least six inches. Kind of zig zags. Is this normal for any car since nothing is perfect? I know things are not perfect, but I like things symmetrical.
performula is offline   Reply With Quote
Old 04-22-2005, 09:50 PM   #6127
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Originally posted by Rapid Roy
If you check out pictures of Hara's car, he has his receiver mounted on the servo too. Couldn't throw the weight of too much concidering he won the ROAR nationals 2 years straight.
Regarding the starter box. The single motor 12v battery setup is stronger by far then the 2 stick pack double motor. Trust me, I have both types. I know people who have replaced the duel motors with 19turn mod motors and 3300mah stick packs for starting power close to the single motor with gel cel, but thats somwhere around $80 to $100 in hop ups.
The one advantage to the duel stick pack/motor box is the light weight.
One last thing. If you think a bump (airplane) starter is easier then using the starter box, then your starter box isn't set up properly. You need to adjust the pins on the top of the box so it holds your car securely with the flywheel in the proper position over the starter wheel. Then you just press down to start. I had to work with mine for a bit before I got it just right. Just take your time, its worth it. I have the OFNA one and needed to remove one of the springs so I didn't have to press down so hard to get the flywheel to engage.
I also have the Ofna dual box setup. The box start's the car the car up easily actually, but when it gets stuck at TDC I have turn it over manually. The dual motor box is said to have the same torque as the single motor, which is true, but it has LESS RPM. I'm using a 12v batt. I've finished messing with twin packs since 1-2yrs ago; they don't last long enough. As for the pegs, the flywheel is too high for the rubber wheel to come in contact so it doesn't work.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 04-22-2005, 10:04 PM   #6128
HarKonnenD's Avatar
Yeah, it was hard to see, but after zooming in on the picture I saw Hara's RX mounted to the THR servo. I'll try that out and see how it looks.
Old 04-22-2005, 10:07 PM   #6129
HarKonnenD's Avatar
Anyone notice their R40 tracking straight with ZERO toe in and little or no camber as opposed to -1 or more toe in with more camber? I tried it and it accelerates in a straight line much better and corners without spinning out.
Old 04-22-2005, 11:24 PM   #6130
k_brian's Avatar
Default Juz Finishing fixing.
Finally finish fixing up the R40.
This is some pictures of it.
k_brian is offline   Reply With Quote
Old 04-22-2005, 11:25 PM   #6131
k_brian's Avatar
here is one more
Old 04-22-2005, 11:27 PM   #6132
k_brian's Avatar
Hark i tape it on the servo. Tis is how it look like.
Old 04-23-2005, 06:26 AM   #6133
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Whats a good starter box to get? I was looking through tower and there was a few things.
Anyone got a suggestion from there or elsewhere.
http://www2.towerhobbies.com/cgi-bin...93p?&C=PCC&P=7
Whats a good budget one and whats the all out best?
Artificial-I is offline   Reply With Quote
Old 04-23-2005, 07:15 AM   #6134
k_brian's Avatar
Get a starter box by which your chassis is lying flat on it. Reason is when you try starting your engine with those starter box with the rear jack up might bend your chassis when it is hot.
Old 04-23-2005, 10:00 AM   #6135
regg151's Avatar
Send a message via ICQ to regg151 Send a message via AIM to regg151 Send a message via Yahoo to regg151
this is a great box
http://www2.towerhobbies.com/cgi-bin...?&I=LXAXU5&P=7
you can always add the power panel later on.
_______________________________________________________________________
Inferno GT Hyper 21 8 Port Ipanema Tires
Spektrum DX3R
Team CFX Racing, RCNB Race Team, CFX Paintworks.com
regg151 is offline   Reply With Quote
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
