Old 04-21-2005, 10:22 PM   #6076
JAG Racing's Avatar
Send a message via AIM to JAG Racing
I use a AE starter box with a single motor and it works flawless. The key is "battery capacity". Use a gel cell and forget the battery sticks.
JAG Racing is offline   Reply With Quote
Old 04-21-2005, 10:29 PM   #6077
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
I have a 12v battery. Am I doing something wrong?
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 04-21-2005, 10:30 PM   #6078
HarKonnenD's Avatar
BTW, I have a dual motor box. It turned the engine over, but at TDC the motors won't turn it over. The single motor starter kicks it over from any position. Maybe a 12V motor box is better? Does the xtra RPM really matter? I guess it must.
Old 04-21-2005, 10:40 PM   #6079
JAG Racing's Avatar
Both configurations provide 12V, but the current capacity is more if using a large gel-cell. Typical gell cells rate around 12V @ 7 Amps while two 6 Volts sticks in series configuration are rated around 12 V with much less current
gel cell --- http://www.lightninghobby.com/viewit...dproduct=25793
What battery configuration do you use?
Old 04-21-2005, 10:52 PM   #6080
HarKonnenD's Avatar
Mine is 12v cell with 7amps. It doesn't say gel cell though. Anyway I tried the trustly ol box and I realized it was me. I just had to push it down firm enough to let the motors do it's job. The new problem now is how many amps to charge my 12v battery at? I have an Integy 16x4 charger and it's adjustable: .5A, 1A, 2.5A, 4.0A, 5A and max. My friend suggest 1amp, but I wanna make sure this is ok. I'd hate to ruin my box battery or $140 charger.
Old 04-21-2005, 11:00 PM   #6081
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Are carbon graphite arms available for the R40 yet? Also any other carbon graphite parts available?
What are some worthwhile hopups besides the lw hpi stuff.
Also whos stuff is better for graphite 3racing , gpm or kawahara. I want to get the graphite front bumper and battery cover.
Artificial-I is offline   Reply With Quote
Old 04-21-2005, 11:03 PM   #6082
JAG Racing's Avatar
A slower charge is always better than a rapid charge as heat builds up as you increase the current on charge.
So at 7Ah ( meaning your battery can source 7 Amps for one hour ( theoretically anyway ), you can charge at a number of different current rates you have available such as:
0.5 A for 14 hours
1.0 A for 7 hours
2.5 A for ~ 3 hours
You see the math here? Just keep (amps x time) to equal 7Ahours.
Since slower is better, I would suggest the 0.5 at 14 hours but 1A for 7 hours is OK as your friend suggested too.
Old 04-21-2005, 11:03 PM   #6083
KLANDERMAN's Avatar
A HARK Ive always used the airplane starter and it works like a charm!!!
KLANDERMAN is offline   Reply With Quote
Old 04-21-2005, 11:08 PM   #6084
HarKonnenD's Avatar
0.5 A for 14 hours
1.0 A for 7 hours
2.5 A for ~ 3 hours
Sounds good. This is my charger here. http://integy.automated-shops.com/cg...36105565217.95
It says it can charge 12v but it says 12v packs..10cells-12v. So can I go ahead and try it?
Klander- Kewl. For now I'll work with the box though.
Old 04-21-2005, 11:09 PM   #6085
JAG Racing's Avatar
Just don't ask me to be your pitman
Old 04-21-2005, 11:11 PM   #6086
HarKonnenD's Avatar
LOL. Why, will you get laughed at or something? I heard from when NEO raced the ATTACK 235mm and Saber 8th at some Nationals and Salven happened to walk by to take a look at the cars and he said "Clone", shook his head and walked away.
Old 04-21-2005, 11:16 PM   #6087
JAG Racing's Avatar
Yep - Set it for 1A and go for it. I didnt read that it was a "auto" charger that shuts off when peak voltage is reached so just try timing it for 1A at 7 hours and monitor the current readings.
Old 04-21-2005, 11:19 PM   #6088
HarKonnenD's Avatar
Ok kewl. Thnx for the info. I set everything up to go charge it. BRB while I try it out. I let you know if it blows up the apt and I'm homeless.
Old 04-21-2005, 11:21 PM   #6089
JAG Racing's Avatar
Well, at least hang on to the battery - it will make a good pocket warmer on the streets.
P.S - I can send you a brand new 32" x 32" cardboard box. It doesnt have many of the comforts as your apt though.
Old 04-21-2005, 11:37 PM   #6090
HarKonnenD's Avatar
LOL!
Well it's charging now. I think I been watching it a bit too much. Been staring directly at it for eh..2 long. I shoulda brought it down here in the living room so I can see it. Eh, it's not 2 far though. I just wanna see how it works and then try to break in the Rody.
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
