Old 04-20-2005, 05:27 PM   #6031
nsxshogun's Avatar
Send a message via AIM to nsxshogun
Fastharry how much would you sell the NTC3 for? I can pay by paypal. Hit me with an email on [email protected] or AIM me at kidld3.
nsxshogun is offline   Reply With Quote
Old 04-20-2005, 06:29 PM   #6032
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Default WEEEEE!!!!
We'll I'm back from the run and I brought my R40 and HB bug with me. The R40 engine nut did slip a bit so I went to ran the buggy. Honestly my friends RB was running a lil rich and his clutch slipped offline a little. However once it kicked in he flat out blew me away. I did give him a good run, but guys, DEFINATELY invest into the RB Rody or the NS12s. Anything else slower won't even compare. My MT12 surely wouldn't catch any ROdy or NS engine. It was totally sick. I was like who needs 8th onroad when you have something this insane. My heatsink though is a brighter color than his and has std plug with alum heatsink. His as a turbo plug and composite carb. One thing that disappointed was when I went back to starting the R40, I had to dismantel much of the car in the lot to use threadlock on that nut and then put it back together. The other thing was the needle settings were TOTALLY OFF. I had to richen it quickly, because it was set for race ready running. I did get it to start, but the clutch may be affecting it as it revved and didnt stop. Regardless I got it started and that matters so now I'm gonna do more work on it and run it tomorrow probably.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 04-20-2005, 06:55 PM   #6033
HarKonnenD's Avatar
Forgot to post the rest.
Old 04-20-2005, 06:56 PM   #6034
HarKonnenD's Avatar
got severalmore. My friend has the airplane starter. I may go and get that instead of the starter box. They work a lot better, because you can hit the flywheel with it and get even the toughest engines started.
Old 04-20-2005, 07:01 PM   #6035
HarKonnenD's Avatar
Another shot. You can see the fume/fuel spray on the ground.
Old 04-20-2005, 07:02 PM   #6036
gibbous's Avatar
Default mine
Here we go...if you can pick it out amongst the mess!
gibbous is offline   Reply With Quote
Old 04-20-2005, 07:03 PM   #6037
gibbous's Avatar
Just enough clearance above the pulley! My next motor will definitely be a rear exhaust!
Old 04-20-2005, 07:04 PM   #6038
gibbous's Avatar
Slightly different front view....
Old 04-20-2005, 07:09 PM   #6039
HarKonnenD's Avatar
more..He was sliding out a bit with his setup. Hopefully when I get my car dialed in I can help him.
Old 04-20-2005, 07:12 PM   #6040
HarKonnenD's Avatar
Great man. Glad you got it in there. Surely now you can run that engine till its shot. BTW, USE THREADLOCK! No more torquing for me. Threadlock is a must.
Old 04-20-2005, 07:15 PM   #6041
regg151's Avatar
Send a message via ICQ to regg151 Send a message via AIM to regg151 Send a message via Yahoo to regg151
Originally posted by HarKonnenD
Wow, where did you get it from? MY Picco .26 never had anything in it. My starter box turns the Rody over pretty easily I just gotta hit it kinda hard thats all or make sure it's not at TDC and it cranks it. It's a std plug also so it won't be sensative to weather changes like a turbo plug. Another trick is to make sure the wheel is off to the side and not directly on top.
well I got one of the first batch of picco 26's that had a bunch of random producrion issues.
mine came with O-rings with the extra flashing still on and I found some metal dust inside the crankcase.
I cleaned it out with denatured alcohol and rebuilt it and I have put over 13 gallons thru it so far and it's still going strong.
_______________________________________________________________________
Inferno GT Hyper 21 8 Port Ipanema Tires
Spektrum DX3R
Team CFX Racing, RCNB Race Team, CFX Paintworks.com
regg151 is offline   Reply With Quote
Old 04-20-2005, 07:33 PM   #6042
HarKonnenD's Avatar
I've got the newer Picco .26 . No probs with mine. BTW, the Rody will be INSANE man. I think you should probably put the MT12 off the side and get something a bit faster. It's great for bashing even. When I saw his run, I said since this is gonna be my last .12, I might as well spend $$ to rebuild stuff and so on rather than swap the MT12 in to mess with. It's a pain to do that. I guess I'll sell the MT12.
Old 04-20-2005, 08:18 PM   #6043
HarKonnenD's Avatar
Default DRAG RACE
Although it's not shown this is how it went down. MY Picco .26 powered HB lightning with 15T CB vs my friends R40 with Rody V12 Roar legal and stock LW 2speed. Since his 2speed was a lil screwed he ran first gear the whole time. However, his ride was flat out FFASSTTTTT. Was like screw first gear, because it was insane. I beat him offline, because he was slipping a bit and still kinda sliding around, but soon his engine kicked in and flat out blew me away on late mid through top end. The picco has lots of torque, but not much top end really. I'm gonna try new diff oils to help my ride. Meanwhile, I wanna get the R40 running, because I want to experience this RB Rody madness. I'm gonna work on the R40 with all types of settings and get it running great.
Old 04-20-2005, 10:30 PM   #6044
KLANDERMAN's Avatar
Hey HARK that's great!!! I hope you get to meet that chick again and blow her out of the water... jajaja So the experience so far is unbelievable... I might have to see if a friend of mine brings me that engine, for now Im working on a new project. I want to see if I can get that .18 OS and put it in a super nitro, my question is do you guys thing that I can get the centax to work on that car???
KLANDERMAN is offline   Reply With Quote
Old 04-20-2005, 10:33 PM   #6045
JAG Racing's Avatar
Send a message via AIM to JAG Racing
Man this thread is getting out of control.
JAG Racing is offline   Reply With Quote
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
