HPI R40 Nitro Car Forum >
Old 04-13-2005, 09:45 AM
  #5701
KLANDERMAN's Avatar
lol... yeah that would be fun... Here is a pic of what I was tryin to tell you, pass them one at a time and you'll be able to have a clean wireing set up, if you are worried about the servo horn messing up the wires, don't they barely touch...
KLANDERMAN is offline
Old 04-13-2005, 09:52 AM
  #5702
k_brian's Avatar
SG is singapore... i got it for 640 singapore dollar. it come with optional items like
1. graphite front shock tower.
2. graphite rear shock tower.
3. gunmetal light weight chassis
4. lightweight upper deck
5. heat sink engine mount
6. steering ungrade set
7. light weight middle shaft
8. light weight 2 speed shaft
9. alum wheel hex hub
10. light weight 2 speed set
11. titanium screw sets.
Few tat we sg ppl change are the spider gear tat come with the kit, shocks and rear stabliser.
k_brian is offline
  #5703
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Originally posted by KLANDERMAN
HARK if you really go 1/8 let me know how expensive it gets and all the tips I need, just in case I wanna go into the 1/8 scene, but if I do go n I'll porbably keep my R-40 and save some $1,500 USD to start in the 1/8 class, although we don't race that category here, just sedans and serpents impact M2 235mm. I would be the only one to have 1/8, which is why I'd like it, I'd probably be the fastest one lol...
Good luck and let me know what you are doing ok.
Well I'm still thinking of that 8th setup. I'd really wanna do it and if I sell my stuff I'll try to keep it around eh...$1000. IMO 8th isn't really expensive unless you break stuff and run so hard the foams wear down. I noticed the foams wear down the most outta the box. I let my dry out a bit and they still held good traction on asphalt, but had much less wear. I have like 4 8th guys telling me to join the crew so hehe I keep getting closer and closer..LOL.
HarKonnenD is offline
Old 04-13-2005, 09:58 AM
  #5704
k_brian's Avatar
klan. Have you guys over at central america saw the OS TZR???
singapore juz have it and the power was awesome. ALmost on par with JP and M.collari.
k_brian is offline
Old 04-13-2005, 10:00 AM
  #5705
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Yeah thats all I can find thats reasonable. Thanks.
-- EDIT: Also in a little bit Ill have those proceed and r40 comparison shots that someone wanted.
Artificial-I is offline
Old 04-13-2005, 10:02 AM
  #5706
KLANDERMAN's Avatar
HARK
Yeah well I guess the peer pressure is getting to you, but I guess if I had friends here into 1/8 i'd probably join the crew, but I don't, so I'll stick to the R-40 for a while. Try not to sell your car, but instead start from scratch with the 1/8...
did you get the video????
Old 04-13-2005, 10:04 AM
  #5707
KLANDERMAN's Avatar
That would be me, I wanted some shots of the proceed... thanx
Old 04-13-2005, 10:07 AM
  #5708
KLANDERMAN's Avatar
Well honestly I dont know if you are reffering to the OS.18tz, a friend of mine has it on a serpent 705 and it is a fast mover, he is thinking of putting it to his serent 235mm, I guess I scared him off when I told him I was getting that engine as well for my R-40
BTW I mostly buy everything from www.towerhobbies.com or fron www.rcmart.com
Old 04-13-2005, 10:14 AM
  #5709
HarKonnenD's Avatar
Yeah I'm gonna get the 8th for sure only because more of em are showin up at the track. Plus for the other places I'm gonna bash/race a fast enough .12 will cost me as much as sport level .21 that will kick it all around. I'll try to keep the R40 and get rid of everything else since I'm not gettin it just yet.
Old 04-13-2005, 10:21 AM
  #5710
k_brian's Avatar
i am refering to the OS tz.12.
You should try one.
k_brian is offline
Old 04-13-2005, 10:23 AM
  #5711
KLANDERMAN's Avatar
nice, let me know if you got the video HARK
Old 04-13-2005, 10:28 AM
  #5712
KLANDERMAN's Avatar
You should try one.
nope, haven't seen it yet... I''ll check at towers to see if it on stock there...
Old 04-13-2005, 10:44 AM
  #5713
HarKonnenD's Avatar
Klander- I got it! Cool beans.
Old 04-13-2005, 10:58 AM
  #5714
KLANDERMAN's Avatar
bashing around is how I lost the clutch weights and the spring on that video jeje. I'm stiil waiting to get those parts tomorrow!!!
Old 04-13-2005, 11:10 AM
  #5715
jt6
jt6's Avatar
You should try one.
I don;t think it will be released in the states until end of May.
jt6 is offline
