Old 04-11-2005, 06:22 PM   #5641
KLANDERMAN's Avatar
Im having trouble with my gas tank lid, on both gas tanks...
Some of the gas gets out behind the gas lid, does anyone know hoe to fix this...
KLANDERMAN is offline   Reply With Quote
Old 04-11-2005, 06:26 PM   #5642
KLANDERMAN's Avatar
Hey you guys my serpent buddy ordered me a lola body, I think it gets here on friday, so I will definately paint some this coming weekend, ill post some pics when I get it, in the mean time Im trying to figure out why the gas lid is leaking!!!
Old 04-11-2005, 07:02 PM   #5643
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
How long is your fuel tubing from the pipe to the gas tank. If its really short this could be causing too much pressure....or pulsing.
Could be a clogged fuel filter from the tank towards the engine....causing build up of pressure.
But you would notice the car running real lean....needed the needle probably turned real rich.
Sometimes its the tank. I hate it, but just about everyone I know has swapped out basically good tanks just to check if it was the problem. Do this last resort.
Artificial-I is offline   Reply With Quote
Old 04-11-2005, 10:23 PM   #5644
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Gonna check the LHS to see if my Integy parts came in. I'll give you all some feedback on em.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 04-11-2005, 10:25 PM   #5645
KLANDERMAN's Avatar
here is a pic of my gas tank
Old 04-11-2005, 10:27 PM   #5646
KLANDERMAN's Avatar
I thinkk the fuel line is ok, but maybe I shoulb have a longer one, here is another closer look. I took the gas tank and shook it really hard and it leaked a couple of drops above the retainer spring... check it out,,,
Old 04-11-2005, 10:30 PM   #5647
KLANDERMAN's Avatar
here is a pic of my new rear gold shocks, thanx to AMGs recomendation, they handle great, I still dont use the rear swaybar...
Old 04-11-2005, 10:38 PM   #5648
MRWRX_69's Avatar
hey dude
ok with your feul tank the r40 hav the same prob as the old mtx3 feul tank lid, with my old r40 wat i did was made the line from exhauast way longer to help, and it did
thanks
MRWRX_69 is offline   Reply With Quote
Old 04-12-2005, 06:53 AM   #5649
Default R40 clutch spring problem
my R40 clutch spring giving me problem.car almost not moving even at full throttle. open up the clutch bell the spring is moving closer to the flywheel. restrore it to original position 0.5-0.8 mm according to manual. after a few run still the same thing happen again. Pls help !
regards,
azizi
zoloft is offline   Reply With Quote
Old 04-12-2005, 06:54 AM   #5650
MRWRX_69's Avatar
it is ur clutch nut
u need to put alot of thread lock or get the mugen clutch nut
it will be fixed no prob if u buy mugen one
Old 04-12-2005, 07:10 AM   #5651
thanks for the advice. will try later
Old 04-12-2005, 07:26 AM   #5652
Moderator
Yeah not only that with sometimes too short of a line the pulsing also makes the fuel foam. You can always try revving the car in front of you and seeing if this is causing the top to loose a little gas.
Watch for any of these signs. I normally try to make the fuel line the same on both sides and give a good amount of room.
A good example of fuel tubing length and use is haras R40.
http://www.superhonda.com/forum/showthread.php?t=218514
Just about everything on his car is there. As well as some nice chassis shots. Im going to be mimicking his car as much as possible.
Either that or will be buying the 2004 edition kit soon.
Old 04-12-2005, 08:08 AM   #5653
Default R40
here got some pic of my R40...
NovaKing is offline   Reply With Quote
Old 04-12-2005, 08:10 AM   #5654
Default R40
others pic.
Old 04-12-2005, 08:13 AM   #5655
Default R40
last pic...
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
