Old 04-05-2005, 03:48 PM   #5491
KLANDERMAN's Avatar
Originally posted by nsxshogun
My screws stripped out and I have yet to get them out. I need a way to get them out of im gonna have to buy all new clutch shoes.
I know it sucks! I was able to get them out and used my dremmel to make them flat screws.... if you can get them out, do so, mine work great and now I can tighten them with no worries lol...
KLANDERMAN is offline   Reply With Quote
Old 04-05-2005, 05:16 PM   #5492
nsxshogun's Avatar
Send a message via AIM to nsxshogun
Im gonna try that.
nsxshogun is offline   Reply With Quote
Old 04-05-2005, 05:27 PM   #5493
regg151's Avatar
Send a message via ICQ to regg151 Send a message via AIM to regg151 Send a message via Yahoo to regg151
the extra shim (glow plug washer) goes between the spacer and the bearing or the spacer and the 2nd gear housing?
_______________________________________________________________________
Inferno GT Hyper 21 8 Port Ipanema Tires
Spektrum DX3R
Team CFX Racing, RCNB Race Team, CFX Paintworks.com
regg151 is offline   Reply With Quote
Old 04-05-2005, 05:55 PM   #5494
JAG Racing's Avatar
Send a message via AIM to JAG Racing
You may as well just order you the maintenance set (0.8) as it gives you the shoes and the hardware. You'll spend more time and money trying to repair this mess.
HPI# 87175
JAG Racing is offline   Reply With Quote
Old 04-05-2005, 07:57 PM   #5495
JAG Racing's Avatar
Default Transponder mount location
For you guys running PTs, I found this to be a real good location for a couple of reasons, one being that the wire routing is quick and easy. The other reason is that it is well protected from and collision damage.
Old 04-05-2005, 07:57 PM   #5496
JAG Racing's Avatar
.. another pic
Old 04-05-2005, 07:58 PM   #5497
JAG Racing's Avatar
Default Labeling diff cases
Paint pens work good for easy identification of differentials..
Old 04-05-2005, 10:50 PM   #5498
KLANDERMAN's Avatar
Default Re: Transponder mount location
Great place to wire your transponder!!! BTW are those the titanium screws?
Old 04-05-2005, 10:53 PM   #5499
KLANDERMAN's Avatar
Default Re: Labeling diff cases
Cool! what type of shock are those? Where can I get aluminum shocks for the R-40?
Old 04-06-2005, 06:38 AM   #5500
JAG Racing's Avatar
Yes - It does have the Titanium screw set
The shocks are HPI 72170 ( ~$80/4 shocks ) - I bought them off of E*Bay for around $45.
Old 04-06-2005, 07:33 AM   #5501
Slayer PR's Avatar
Can someone please tell me how the R40's gear chart works ?
The lower gear ratio gives you more speed or the higher ?
Slayer PR is offline   Reply With Quote
Old 04-06-2005, 08:31 AM   #5502
KLANDERMAN's Avatar
I believe lower gear ratio gives you more top end...
If the R-40 is your first nitro car, Then you now that the spur/ pinion combination works awesome, but I you want more speed it's better to try changing the pinion T number than the spur T number, so If you want your car to have more top end and less torque so you don't spin it out on a turn I recommend you go up a tooth on the pinion gears. Your stock ratio is:
First gear: 48+16 = 7.260 ratio
Second gear 45+19 = 5.731
What I did to improve my speed is this:
First gear 48+17 = 6.832
Second gear 45+ 20 = 5.445
Afterwards I moved up to the lightweight 2 speed tranny, which has a greater acceleration.
Old 04-06-2005, 08:34 AM   #5503
KLANDERMAN's Avatar
Yep I saw them at towers, but to me they are more like $100 because of shipping, so I'll have to wait a bit...
thanx JAG
Old 04-06-2005, 08:36 AM   #5504
Slayer PR's Avatar
Thumbs up
Thanks for the info.
Old 04-06-2005, 08:40 AM   #5505
KLANDERMAN's Avatar
Hey you guys, while taking apart my WASP engine .12 turbo I noticed that it has 2 shims above the piston sleeve... If I remove one of thse would I get a more torquier engine or what happens?
I also noticed that my engine is a 3 port, with all that torque fighting against the OS .18tz I could have sworn this was a 5 port engine... oh well lol... I love this hobby!!!
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
