Old 03-31-2005, 09:36 PM   #5371
JAG Racing's Avatar
Send a message via AIM to JAG Racing
Originally posted by HarKonnenD
Hey jag, any tips how to get this lola body lined up perfectly? Gonna take out the antennae and fuel tank cord out, but I only have red paint for it. I guess I'll leave it for a while and get more paint.
Well, there is the brute-force method or the meticulous method.
There are many tricks probably but for me the best way is to use a set of short body posts so that when you lay the clear body down over the car, the posts are not holding the body up too far off of the ground. If you use a short set of body post, you will be able to lay the body over the top of the car and the body can go near the ground. Then you can use a marker to mark the outside of the body where the body posts will protrude.
Good luck and post some pics!
JAG Racing is offline   Reply With Quote
Old 03-31-2005, 10:20 PM   #5372
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Kool, thnx! I'll post pics soon when I get more paint.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 03-31-2005, 10:50 PM   #5373
KLANDERMAN's Avatar
[QUOTE]Originally posted by HarKonnenD
Hey jag, any tips how to get this lola body lined up perfectly? Gonna take out the antennae and fuel tank cord out, but I only have red paint for it. I guess I'll leave it for a while and get more paint. [/QUOTE
Ok you guys... I think I understand the gear ratio now... I guess raising the spur one T should only have a 2% effect, It should be around the same... Anyway I'll give it a shot tomorrow to see how it handles.
HarkonnenD: how's that lola body turning out???
KLANDERMAN is offline   Reply With Quote
Old 03-31-2005, 11:05 PM   #5374
KLANDERMAN's Avatar
Originally posted by 20 SMOKE
weigh it with the body your still in the mid 1800
You are completely right... my car weighs 1780 grams without the body, my lightweight M3 body weighs 100 grams, so yep I'm back to 1880, but lighter than before... lol
later
Old 03-31-2005, 11:32 PM   #5375
KLANDERMAN's Avatar
Can anyone using the LW tranny tell me good torque- top end combo on the spurs and pinions to try?
Old 04-01-2005, 12:59 AM   #5376
Rapid Roy's Avatar
Originally posted by JAG Racing
FastHarry, AMG, or Rapid Roy - I was looking over my rear link and I noticed that it binds up on the rear sway bar as the rear end is raised. I saw Hara's set-up sheet and he does use the bottom most link mount as you have yours (and mine) set to. You have an upgraded rear sway mount but mine is the stock one.
It doesnt make any sense to me to use this mount position so I will move my rear link up so that it doesnt make contact with the rear sway bar. Do you guys see what I am talking about? Any comments on how you would set this up? If I understand roll center correctly, if I do move this UP, in effect I am RAISING the roll center which will INCREASE the amount of roll in the rear. Comments please.
You can bend open your rear sway bar just a bit. That will move the ends away from the rear link enough so it clears. I hope my explanation makes sense.
Rapid Roy is offline   Reply With Quote
Old 04-01-2005, 06:53 AM   #5377
JAG Racing's Avatar
Thanks RR.
Old 04-01-2005, 08:05 AM   #5378
HarKonnenD's Avatar
Use the stock setup. It's really good. Good top speed and great acceleration if you use the proper washer setup.
Old 04-01-2005, 09:06 AM   #5379
KLANDERMAN's Avatar
I will use the spur/ pinion set up that I have now...
on the clutch set up I have 1 silver, 1 copper, 1 silver, 1 copper and 1 copper more... I hope this works well, I'll give it a try later this afternoon...
Old 04-01-2005, 09:21 AM   #5380
HarKonnenD's Avatar
I used silver/copper/silver/copper in that orde starting from the flange bearing. It works out great!
Old 04-01-2005, 09:25 AM   #5381
KLANDERMAN's Avatar
Yeah that's how I have mine now, I put the extra one because I felt the clutch too slipery... afterwards I noticed that the clutchnut had fallen, so maybe that was the problem, but still I'll try this, if not I''l take 1 copper out...
Old 04-01-2005, 05:11 PM   #5382
HarKonnenD's Avatar
We just ran my friends Rody powered R40 and he too needs more spacers. So far I got my stuff for my lola body. Ill show you guys how it is later on. For now, keep ur pants on and just wait .
Old 04-01-2005, 10:50 PM   #5383
KLANDERMAN's Avatar
On saturday I will do some tests to be ready for the Serpent...
Ihope that this time I get to be infront at the end of the straight lol, but I'll find out tomorrow how my car is moving with those 46 grams off...
Old 04-01-2005, 11:44 PM   #5384
HarKonnenD's Avatar
Default ITS DONE!
I wanted MY R40 to have a paintjob like the onroad I saw in a picture from my local track.
Old 04-01-2005, 11:46 PM   #5385
HarKonnenD's Avatar
Well there seems to be a problem posting pics so I'll try later 2morrow when I get home from work.
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
