Old 03-31-2005, 01:47 PM   #5356
KLANDERMAN's Avatar
hey you guys I just noticed that the LW tranny comes with spurs 53T and 59T and 21T and 27Tpinions, but on the towers list it says that it should come with 54T and 60T and the gears I counted 22T and 28T, so thats what I ordered as replacement parts to have in stock... The problem is that a pebble kinda hit the corner of my 59 spur, so I replaced both spurs, but instead now I have 54T and 60T spurs with 21T and 27T pinions... How is this going to affect my speed? Has anyone tried this set up?
KLANDERMAN is offline   Reply With Quote
Old 03-31-2005, 01:53 PM   #5357
regg151's Avatar
Send a message via ICQ to regg151 Send a message via AIM to regg151 Send a message via Yahoo to regg151
should give you a bit more top end
but seeing as it's only a one tooth change on the spur I doubt it will be very noticable.
_______________________________________________________________________
Inferno GT Hyper 21 8 Port Ipanema Tires
Spektrum DX3R
Team CFX Racing, RCNB Race Team, CFX Paintworks.com
regg151 is offline   Reply With Quote
Old 03-31-2005, 01:54 PM   #5358
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Since you dropped a tooth on the pinions you're gonna get a lil more acceleration offline.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 03-31-2005, 01:57 PM   #5359
regg151's Avatar
Hark you my wanna re-read his post he went up a tooth on both spurs pinions stayed the same.
Klan where did you get your lw tranny from?
Spektrum DX3R
Old 03-31-2005, 01:58 PM   #5360
KLANDERMAN's Avatar
Thanks you guys... Im really nervous now because my Serpent buddy has been going thru the LW process lol...
Old 03-31-2005, 02:00 PM   #5361
KLANDERMAN's Avatar
I got it from towers why?
Old 03-31-2005, 02:03 PM   #5362
KLANDERMAN's Avatar
So if I go up a tooth on the spurs I get acceleration and if I go up a tooth on the pinion I get top end... is thi right?
Old 03-31-2005, 02:09 PM   #5363
HarKonnenD's Avatar
small pinion+large spur=more acceleration
large pinion+smaller spur=more top end speed
Old 03-31-2005, 02:18 PM   #5364
KLANDERMAN's Avatar
mmm so I was better with what I had earlier?
Old 03-31-2005, 02:22 PM   #5365
regg151's Avatar
you went up one tooth on the spur you will get more top end in the order of 1mph or so.
the 1 tooth difference won't be all that noticable although you may have to adjust your shift point.
Spektrum DX3R
Old 03-31-2005, 02:26 PM   #5366
KLANDERMAN's Avatar
thanks you guys, I'll try it tomorrow to see how it handles ok
Old 03-31-2005, 08:27 PM   #5367
JAG Racing's Avatar
Send a message via AIM to JAG Racing
Originally posted by fastharry
use PRO LINE tmaxx ends and balls.....use the varying washers from the pro 4 to change roll underneath the rod balls...I used the 23mm lunsford buckles....the stock HPI 20 mm were fine...
FastHarry, AMG, or Rapid Roy - I was looking over my rear link and I noticed that it binds up on the rear sway bar as the rear end is raised. I saw Hara's set-up sheet and he does use the bottom most link mount as you have yours (and mine) set to. You have an upgraded rear sway mount but mine is the stock one.
It doesnt make any sense to me to use this mount position so I will move my rear link up so that it doesnt make contact with the rear sway bar. Do you guys see what I am talking about? Any comments on how you would set this up? If I understand roll center correctly, if I do move this UP, in effect I am RAISING the roll center which will INCREASE the amount of roll in the rear. Comments please.
JAG Racing is offline   Reply With Quote
Old 03-31-2005, 08:32 PM   #5368
HarKonnenD's Avatar
Klander- Up or down a tooth on the pinion overall will make more of a difference in the gear ratio compared to the spur gear.
Old 03-31-2005, 08:54 PM   #5369
JAG Racing's Avatar
Yep - A one tooth increase in a 20T gear is a 5% change, while a one tooth change in a 60T spur is a < 2% change.
Old 03-31-2005, 09:29 PM   #5370
HarKonnenD's Avatar
Hey jag, any tips how to get this lola body lined up perfectly? Gonna take out the antennae and fuel tank cord out, but I only have red paint for it. I guess I'll leave it for a while and get more paint.
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
