Old 03-29-2005, 10:30 PM   #5296
KLANDERMAN's Avatar
Well I tought I had lost 44 grams, but it turns out I lost 46 because before my cars weight was 1826, now it,s 1780grams...
Check out the scale...
NEAT!!!
KLANDERMAN is offline   Reply With Quote
Old 03-29-2005, 10:35 PM   #5297
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
yeah, it's [email protected]
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 03-29-2005, 10:43 PM   #5298
regg151's Avatar
Send a message via ICQ to regg151 Send a message via AIM to regg151 Send a message via Yahoo to regg151
NEAT!!!
sounds like you had about 2 grams of dirt build up.
_______________________________________________________________________
Inferno GT Hyper 21 8 Port Ipanema Tires
Spektrum DX3R
Team CFX Racing, RCNB Race Team, CFX Paintworks.com
regg151 is offline   Reply With Quote
Old 03-29-2005, 10:48 PM   #5299
regg151's Avatar
It's amazing how many nooks and cranies are on this car for dirt to hide in. I felt like half the surface of the parking lot was hidden away while swapping out the chassie
Spektrum DX3R
Old 03-29-2005, 10:50 PM   #5300
nsxshogun's Avatar
Send a message via AIM to nsxshogun
Samehere I changed my chassis and it was filthy.
nsxshogun is offline   Reply With Quote
Old 03-29-2005, 11:01 PM   #5301
KLANDERMAN's Avatar
Yeah the chassis was filthy lol I guess does 2 grams where hidding from the brush lol...
Old 03-30-2005, 05:26 AM   #5302
HarKonnenD's Avatar
Hey maintainance boy, ya missed a spot! LOL
What a crash. Sounded like the car went "WhooHEERRRUHH". I'm probably gonna be able to run my car against my friends R40 with Rody so I'll see what he got and maybe I'll use my digicam if I can bring it for a vid. However the digi only has picture. No sound
Old 03-30-2005, 09:30 AM   #5303
regg151's Avatar
did anyone ever find a soloution to stop the rear links from compressing?
I recall someone getting some nuts machined to fit but was there any other way?
Spektrum DX3R
Old 03-30-2005, 09:56 AM   #5304
gibbous's Avatar
Hey guys,
What's the deal with .12 motors being more expensive than .18s? Is smaller really that much harder to manufactuer?, or are hobby shops cashing in on what the clubs use the most? Do any of your clubs see going to a .18 class?
gibbous is offline   Reply With Quote
Old 03-30-2005, 10:21 AM   #5305
HarKonnenD's Avatar
Regg- I dunno how you only used 2 shims and the car worked better. I tried that and the car revved a bit before moving. I installed 2 silver with 2 copper shims and the car now hauls offline. Gonna run it outside in the larger parkinglot soon now.
Old 03-30-2005, 10:23 AM   #5306
HarKonnenD's Avatar
Default ATTEN LW 2SPEED NEW OWNERS!!!!
This I noted from the start. Using the stock setup the LW 2speed on first gear wobbled a bit due to a little xtra slack. That spacer included is NOT ENOUGH! There is a small amount of space between the E clip on the 2speed side. For a simple fix, use the washer for glowplugs and install it on the shaft over the included spacer. This will eliminate that wobble. It never caused me a problem before, but now with the clutch engaging properly offline, the gears started shaving a tiny bit. Now, it's perfect!
Old 03-30-2005, 11:43 AM   #5307
KLANDERMAN's Avatar
Default Re: ATTEN LW 2SPEED NEW OWNERS!!!!
Inoticed that problem. but tought it was normal, thanx for the tip I will fix it now... I hope my LW 2 speed works well because of those screws I messed up...
Old 03-30-2005, 01:11 PM   #5308
KLANDERMAN's Avatar
well you guys the LW 2 speed was a success!!! I feel the car so quick now... I still need to work on the shift point because it was shifting way too soon. I did a couple of passe in front of my house, byt still scratched my chassis!!!! I cant believe the bumps my street has... here is a pic...
Old 03-30-2005, 01:13 PM   #5309
KLANDERMAN's Avatar
I tried using that glow plug washer, but it was too thick, so I used another one a bit less thick and It was perfect... Still thanx HarkonneD...
Old 03-30-2005, 01:18 PM   #5310
regg151's Avatar
don't feel bad about your chassie I had my ride height set at 7mm front and 10mm rear and still managed to scratch mine.
i'm still waiting for my lw 2speed to show up should be a few more days.
It was a blast to get this car running again after sitting for so long, engine fired up on the second try, nothing like the sound of a nitro engine firing up.
Spektrum DX3R
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
