Old 03-29-2005, 01:37 PM   #5281
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Send the vid my way Klander. Send it to Gmail.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 03-29-2005, 01:49 PM   #5282
JAG Racing's Avatar
Send a message via AIM to JAG Racing
Originally posted by Tabushi
Sorry to post again, i made a mistake, i didnt read the instructions on the HPI website ... the R40 comes with FRONT & REAR differentials right ?.
Now, wich kind of fluid it uses on the diffs ? ... its diff OIL or GREASE ?. And how hard/easy are they to tune according to the track ?.
The 4 gear conversion worth the extra $$ and weight ?
thanks
PAT
Yes - at least the US R40 comes with F & R diffs.
Grease/oil - depends on track.
Rear - try no oil ( light dab of grease on gears & shaft) to as thick as 30,000 weight silicone.
Front - try 30,000 to 70,000 thick silicone.
I use OFNA Diff Lock Oil ( Silicone ) but there are many out there.
Basically, you want the front diff "tighter" than the rear at all times. Tighter meaning to use a thicker silicone oil.
4 gear conversion - probably not worth the $$ IMO. Although, I just dissasemled my diffs and found the spider gear shafts worn down pretty bad. This indicates that you need to keep the lubrication on these shafts.
JAG Racing is offline   Reply With Quote
Old 03-29-2005, 02:24 PM   #5283
KLANDERMAN's Avatar
Well you guys I had to head back to the office, but got some pics for all of you... this is my car with the LW chassis..
KLANDERMAN is offline   Reply With Quote
Old 03-29-2005, 02:26 PM   #5284
KLANDERMAN's Avatar
I did last night... your e-mail is viper... right?
If not give it to me again, I might be confused or something
check out my LW tranny
Old 03-29-2005, 02:29 PM   #5285
KLANDERMAN's Avatar
This here is a pic of both chassis
stock chassis = 118 grams
LW chassis = 94 grams
It looks bad ass!!!
check it out!
Old 03-29-2005, 02:39 PM   #5286
KLANDERMAN's Avatar
Originally posted by vulso
Klanderman, I wreck my poor Savage in parking lot and hit a pole. Did a 360 and started driving in circles.
How do you like your WASP motor? It's PICCO based right. Do you have trouble tuning it? I saw this on E-bay and it's a modified edition.
http://cgi.ebay.com/ws/eBayISAPI.dll...965954240&rd=1
Hey man my engine is awesome... real easy to tune, it's powerful as hell and I love it for the price, I also use the pipe and header in combination with an OS turbo plug p7 medium... it kick butt
I you wanna try it it's a lot of bang for the buck... check them out at towers mine is the blue one that has 1.45 hp at 37,000, but there is another one for $30 USD more that hits 38,000 with 1.5 hp...
Old 03-29-2005, 02:44 PM   #5287
KLANDERMAN's Avatar
On my track we HAVE to use front diff due to the grip conditions ...
So ... wich parts i have to buy in order to mount a front diff on the R40 ? ... and wich extra parts to mount the front AND rear diff with 4 gears ... ?
thanks ...
Pat
Tabushi: I use 40k to 70k oil in the front, light grease on the rear just to maintain lube...
Now I use the front oneway for tracks with less brake, but for small tracks I use the rear solid axle in the front diff with a high torque servo...
Old 03-29-2005, 02:51 PM   #5288
Rapid Roy's Avatar
thanks
PAT
The US version comes with front and rear diffs. You can use grease in them if you only want to lubricate them. You use the diff oils to tune them to your track. Higher grip tracks will allow you to use thicker diff oils.
The 4 gear diff will work more consistantly and smoothly then the stock 2 gear unit. It also provides you with more mechanical drag so you need to lighten up on the diff oil. You can mix diff oils or partialy fill the diffs to fine tune. The 4 gear diff won't work well on low grip surfaces. As for cost, you can just buy the shafts and gears seperately for not much money.
Rapid Roy is offline   Reply With Quote
Old 03-29-2005, 09:22 PM   #5289
KLANDERMAN's Avatar
well fellas my car is good to go. Now is 44 grams of less weight, maybe tomorrow I will give it a try to test the LW 2 speed...
here is a pic...
Old 03-29-2005, 09:23 PM   #5290
KLANDERMAN's Avatar
here is another pic...
Old 03-29-2005, 09:42 PM   #5291
regg151's Avatar
Send a message via ICQ to regg151 Send a message via AIM to regg151 Send a message via Yahoo to regg151
looks good. bet you can't wait to run it a few laps.
I just put the lt weight chassie on last night and just did the 4 gear mod in the rear. the shaft in the rear diff was badly scored.
I'm closeing her up now so I do some laps tommorow afternoon.
anyone know what size bearings I need for the steering? I gotta replace those silly plastic bushing.
_______________________________________________________________________
Inferno GT Hyper 21 8 Port Ipanema Tires
Spektrum DX3R
Team CFX Racing, RCNB Race Team, CFX Paintworks.com
regg151 is offline   Reply With Quote
Old 03-29-2005, 09:45 PM   #5292
KLANDERMAN's Avatar
Neat man! check it out
http://www2.towerhobbies.com/cgi-bin...?&I=LXFYN4&P=7
This is what you need... I had the bearings laying around and replaced them...
Old 03-29-2005, 09:51 PM   #5293
KLANDERMAN's Avatar
MAN!!! the chassis looks so good That I decided to raise the car to 5.5mm rear and 5.0 front so that I dont scratch it too much lol...
Old 03-29-2005, 10:03 PM   #5294
regg151's Avatar
I must admit I really don't want to bang this chassie up to much it just looks too purtty.
Spektrum DX3R
Old 03-29-2005, 10:09 PM   #5295
KLANDERMAN's Avatar
yep know what you mean... I just took a whole lot of pictures lol...
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
