Old 03-19-2005, 08:25 PM   #4996
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
The one way bearing should be included with the 2speed unit both stock and the light weight upgrade. It should also be preinstalled; you shouldn't have to fit it in yourself. They use some kind of adhesive so it's xtremely hard to remove. The other side isn't flanged inwards so if it were to move it would slide out either end if not glued in properly. I'd say scrap the whole stock 2speed unit, for the LW 2speed unit. Also, get the LW shafts to go with it.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 03-19-2005, 09:56 PM   #4997
AMGRacer's Avatar
Originally posted by gonz
Yupp ... that sounds like it .....
In the manual book there's only part number #87082 (2 Speed Hub) that I can see.....
from the picture I didn't see the 1 way bearing in it .... and also till the rest of the manual book there's no 1 way bearing part mentioned for this 2 speed section.....
do you know what is the part # number for this 1 way bearing ? ..... what is the size ???
Beside that ... seems like I'm having problem of taking out the bearing from the hub ... it tied very hard ....
do you have any trick on how to open or take off the bearing.?? ....
Thanks Bro....
good to have reply from the expert ......
ps: If I buy the Lightweight 2 Speed Transmision set option part ... is it include the bearing ?...
Yes 87082 is that part I meant. The oneway bearing inside this part is press fit and likely glued in there as well. In any event it is very difficult to get out. You just buy this part for $7.69 from tower and replace the whole gear mount. I would also recommend you replace 87085 as well at the same time, some time the oneway slips due to this part being worn, and it will provide a nice smooth surface for the new oneway to run against.
Yes the lightweight 2 speed has a new bearing mount.
AMGRacer is offline   Reply With Quote
Old 03-20-2005, 06:59 AM   #4998
hey guys,
I got my new radio yesterday at the hobby shop. The jr xs3. It has great functions and thew channels can be changed very easily. I recomend it. I come home to another suprise too. I got my ths pipe in the mail. Its a beaut! I am picking my starter box up on next wed or sat and hopefully I will drive on sunday.
Later guys
nitroracer20 is offline   Reply With Quote
Old 03-20-2005, 07:59 AM   #4999
nsxshogun's Avatar
Send a message via AIM to nsxshogun
Try the black ofna starter box it comes with everything you need for about 80$.
nsxshogun is offline   Reply With Quote
Old 03-20-2005, 03:55 PM   #5000
HarKonnenD's Avatar
That Ofna black box works great. I love it.
Old 03-20-2005, 04:22 PM   #5001
KLANDERMAN's Avatar
hey you guys did some testing today and my car worked great... can't wait to get my 2 speed LW...
Hey Gonz your problem is that your oneway bearing is toasted...
I get parts from japan at www.rcmart.com they have the part you are looking for... it's about $10 USD chec it out under parts, then go to HPI R-40 under three racing
If I was U I would get the LW .8 2 speed instead... I just got mine, but I haven't tried it
good luck
Klanderman
KLANDERMAN is offline   Reply With Quote
Old 03-20-2005, 04:27 PM   #5002
KLANDERMAN's Avatar
dannybcaitlyn
Hey man I'm also looking for that part, if you get it, let me know
ok...
Old 03-20-2005, 04:35 PM   #5003
KLANDERMAN's Avatar
Gonz... I noticed that tower has the part too, but when I got my R 40 kit it did't have the oneway bearing... I had to order the part from Japan to make sure i'd get it, the part you are looking for is 87081 at tower, but the picture doesn't have the oneway, so make sure you call and ask to see if it comes with it...
Old 03-20-2005, 05:02 PM   #5004
AMGRacer's Avatar
87081 is the wrong part, thats the 2nd speed housing.
Old 03-20-2005, 07:18 PM   #5005
JAG Racing's Avatar
Send a message via AIM to JAG Racing
Originally posted by nitroracer20
hey guys,
Later guys
I have the same radio - If you don't have the Pro, you really need the RS310 compact receiver ( instead of the RS300 ) as if fits in the Rx case. The RS300 is a rreeaall tight fit.
JAG Racing is offline   Reply With Quote
Old 03-20-2005, 08:18 PM   #5006
gonz's Avatar
Send a message via Yahoo to gonz
good luck
Klanderman
yes... I made up my mind to buy the LW 2 speed already...
btw... thanks for the website info.... is it Hongkong or Japan ...
if i see it looks like Hongkong .... nvm.. the important things is RCMART can do shipping to my country .....
gonz is offline   Reply With Quote
Old 03-20-2005, 08:22 PM   #5007
gonz's Avatar
thanks again for your advice...
Old 03-20-2005, 08:57 PM   #5008
KLANDERMAN's Avatar
Gonz I beleive it's hong kong sorry... the part I was talking about is the 87082. Mine didn't come with the oneway, but I guess It doesn't matter as you are going to get the LW 2 speed
Old 03-20-2005, 09:00 PM   #5009
KLANDERMAN's Avatar
Has anyone ever toasted the flange bearing that goes in the clutch engagement with part number B019? I just took the clutchbell off and pieces of it came off... I had to special order them, as I didn't have a spare one... this sucks!!!
Old 03-20-2005, 09:05 PM   #5010
KLANDERMAN's Avatar
Here is a pick of what's left of the flange ball bearing I ripped
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
