Old 03-15-2005, 08:08 AM   #4906
KLANDERMAN's Avatar
most be nice to have a track near by... Our old track is being destroyed as we speak to build a soccer field... Now the neares track is about 2 and 1/2 hrs from my house, so we usually practice and bash in a parking lot, but races resume on april, so I guess I'm going to have to drive all the way there to win somo races lol hopefully...
KLANDERMAN is offline   Reply With Quote
Old 03-15-2005, 09:59 AM   #4907
JAG Racing's Avatar
Send a message via AIM to JAG Racing
Default Front Spool - Locked DIff
AMG_Racer -
I am considering going back to the stock differential becuase of the off-power steering loss from going to the spool in the front.
What are you doing to get the off-power steering back?
JAG Racing is offline   Reply With Quote
Old 03-15-2005, 11:03 AM   #4908
Rapid Roy's Avatar
To increase off power steering as you are entering a turn go to a softer front tire or softer front roll bar. Harder rear tires and sifftening the rear roll bar will do the same thing. You can also decrease the rear toe in.
Rapid Roy is offline   Reply With Quote
Old 03-15-2005, 12:22 PM   #4909
KLANDERMAN's Avatar
great, I will try that this weekeend and see what happens
also with the solid axle... would i get my steer back if I use a biffier servo?
Old 03-15-2005, 12:47 PM   #4910
JAG Racing's Avatar
Thanks RR -
I'll try front vs rear toe changes as I already have softest tire compunds on front and the front swaybar is already horizontal.
Also thinking of using 30k rear diff oil. I currently do not use any oil in the rear. I assume that adding rear diff oil will take away rear "steering" which in effect "adds" front steering.
Old 03-15-2005, 01:33 PM   #4911
Rapid Roy's Avatar
JAG you are correct. Here is what I use for reference.
Old 03-15-2005, 01:52 PM   #4912
AMGRacer's Avatar
Default Re: Front Spool - Locked DIff
Originally posted by JAG Racing
AMG_Racer -
Yep you dont get something for nothing unfortunately. The braking and on power steering is really good with the solid but you definately lose off power steering. If I recall rightly you use rubber tires on concrete? Here is what I noticed:
1. The rear diff is critical. Too stiff and it affects off power. I use 0-10K max in the rear on rubber.
2. I use the silver fronts and black rear springs. I use the front swaybar at around 30 degrees. You can use the front swaybar to balance the car.
3. Add around 1 degree toe out.
There are a few more things but these are the main things.
AMGRacer is offline   Reply With Quote
Old 03-15-2005, 01:55 PM   #4913
AMGRacer's Avatar
Thanks RR -
OK I missed this post If you have no diff oil you are getting more grip in the rear off power, possibly too much making the car not want to "rotate". You may need to go to 10-30K rear oil to make the car rotate enough. In my experience this car is quite sensitive to the rear diff oils, I use a different rear diff for each track I go to.
Old 03-15-2005, 02:30 PM   #4914
JAG Racing's Avatar
Thanks Guys - I'll run some trials and let you know how it goes.
I wonder if it makes sense to have a spare diff in the tool box that is already set-up with different oil? Just a thought.
AMG - Yes I usually run on concrete but will be running high-grip asphault this weekend. I'll also try toe out.
Rapid Roy - Handy sheet. So for my situation ( Understeer on "corner entry" I see a level 2 adj for Roll Center. Do I RAISE the upper link arm in this case?
Thanks again for the help.
Old 03-15-2005, 02:37 PM   #4915
KLANDERMAN's Avatar
I use light grease in the rear, should I use 10k oil to make it more stable? I also seenin video footage that at the end of the straights sometimes the car gets lose, is this because of too much toe in in the rear... I use around 2.5 rear toe in.
Old 03-15-2005, 02:56 PM   #4916
AMGRacer's Avatar
I have 4 diffs made up and ready to go with different configurations. It is a very useful tuning aide, especially since the R40 diff is so easy to change.
On high grip asphalt the best bet is almost always a front oneway unless you need to brake hard. The Hara 2004 ROAR setup with some mods works awesome on asphalt.
Old 03-15-2005, 07:25 PM   #4917
billysss's Avatar
Default use foams
foam set up with biased right turning track
front: 37 shore cut: 58mm
rear: 37 shore cut: 59mm
front camber: LEft: 2.5 Right: 2.0
rear camber: left: 3.5 right: 3.0
front blade sway bar: 90 deg.
rear sway bar: none
front toe out: 1 deg
rear toe in: 2 deg
ride height: front: 4.5 rear: 5.0
TRACK: SPEEDZONE HPI R40 2004 Ed.
POSITION: 3rd A-main
got to race...and temporarily forget the mess we're in...
billysss is offline   Reply With Quote
Old 03-16-2005, 08:24 AM   #4918
KLANDERMAN's Avatar
Well my parts are here and now I can put together my car again, since the asccident I hd to take it all apart, I mean set up the camber, toe-in, and the steering arms because when I hit the wall everthing got messed up. Now I can finall put it back together and get ready to try the solid front axle with new 35shore all around tires, no swaybar in the rear and lowered to 3.5mm front and 4mm rear
Old 03-16-2005, 01:21 PM   #4919
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Unfortunately I probably won't be able to test it today. I really wanted to. I'll just rev it to see how the clutch engages and see if the 2speed engages a bit later.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 03-16-2005, 02:12 PM   #4920
HarKonnenD's Avatar
Tested the car and she fired right up. The centax and 2speed adjustment were a success! More acceleration offline and more top end. Gonna try to run the car outside tomorrow. I can't wait!
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
