Old 03-11-2005, 12:32 PM   #4771
KLANDERMAN's Avatar
My R-40 weighs exactly 1946 grams with the body on...
titanium shafts front and rear
graphite towers, belt brace and steering brace
aluminum pulleys front and rear
KLANDERMAN is offline   Reply With Quote
Old 03-11-2005, 12:36 PM   #4772
KLANDERMAN's Avatar
cool let's see a picture
Q. so what extras do you have on yours?
Old 03-11-2005, 08:54 PM   #4773
BOWTIE1's Avatar
Send a message via AIM to BOWTIE1 Send a message via Yahoo to BOWTIE1
what stock r40 weigh? i get mine pron thurs or friday and i decied on the os tr how i did right and a front 1 way i was going to get solid rear axle but no1 said if its good or bad ....
BOWTIE1 is offline   Reply With Quote
Old 03-11-2005, 08:58 PM   #4774
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Don't get either. The car will be too loose. Try the rear solid axle in the front though. Some swear by it sayin it pulls better in the turns.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 03-11-2005, 09:01 PM   #4775
BOWTIE1's Avatar
so the front 1 way make the car lose?
Old 03-11-2005, 09:16 PM   #4776
Default R40 durability
Guys, will you help me on this. I was told that R40's plastic
parts are brittle. They break easily. Specially the front
arms. Is this true? Any comments?
Karaan is offline   Reply With Quote
Old 03-11-2005, 09:24 PM   #4777
BOWTIE1's Avatar
frederic depends on what ya hit
Old 03-11-2005, 09:51 PM   #4778
HarKonnenD's Avatar
The front one way diff locks under acceleration, but when braking will keep spinning. Therefore you only have braking in the rear. It helps in cornering speed on those large turns, but not the tight turns. The R40 is really sturdy. I've had some crashes, but didn't break a thing. Infact with my high ground clearance, the chassis isn't even scratched yet. LOL!
Old 03-11-2005, 10:06 PM   #4779
BOWTIE1's Avatar
ok kool well that is about right the car is comming with a one way ill take it out or drill it like i seen in a few other post and make it a solid axel lol or put the diff back in it ... can some 1 help me with a set up for tight track ?
Old 03-11-2005, 10:08 PM   #4780
BOWTIE1's Avatar
KLANDERMAN
how that wasp run up vs the rb and mt 12's and the ostr?
Old 03-12-2005, 12:33 AM   #4781
KLANDERMAN's Avatar
It's fast, I have raced mostly against serpent's, 705's and 710's and all of them carry the Rb engines or the new OS .18tz 5 port, but I'm happy with my WASP. On straights is tough and in corners it works great. I have not seen many people with team orion engines, but they are easy to tune, so I recommend it!!!
here is a pic of my new M3 body... I will try it on sunday and compare it with the 350z in aerodinamics...
Old 03-12-2005, 12:34 AM   #4782
KLANDERMAN's Avatar
On the solid axle, normal diff case and the oneway, I have tried the normal diff case but need a high torque servo to turn under throttle. The one way works great on tight turns, but you have to slow down way too soon, other cars can get you before the turn, and on sunday I will try the solid rear axle in the front and will let you know of the outcome ok...
here is the picture
Old 03-12-2005, 12:36 AM   #4783
KLANDERMAN's Avatar
the wasp can handle those engines, i have a video clip kicking some serpents butt and he has the .18TZ with dyno tested 2.28 BHP against my WASP engine with only 1.45 BHP
Old 03-12-2005, 12:41 AM   #4784
KLANDERMAN's Avatar
Talking R40 durability
frederic: If you hit anothercar, a wall, or anything at high speeds, even the aluminum will bend, so it depends on it's durability.
I have had many crashes with other cars and we mostly just spin, but when I got hit on the side, my pipe got bent, so I had to get a new one. One time I hit the sidewalk and had to replace the bumper, the suspension mounts and the front graphite tower, but like everyone say... it depend what you hit to see it's durability, but when it comes to performance, speed and fun, the R-40 tops them all
Old 03-12-2005, 12:47 AM   #4785
KLANDERMAN's Avatar
BOWTIE1
First of all how long is the straight of the track your setting for?
is it bumpy?
are the turns really tight that you have to use the breaks?
are you using the original set up clutchbell 16T + 19T with the spurs at 48 and 45?
are you gonna use the oneway or the regular diffcase?
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
