Old 03-09-2005, 06:47 PM   #4726
KLANDERMAN's Avatar
go for it... send me the link
KLANDERMAN is offline   Reply With Quote
Old 03-09-2005, 06:49 PM   #4727
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
Originally posted by nitroracer20
ok, I diudnt get any instruction manual when I got my car to find camber/toe in but I will try to tell you. I know my rear is toes in mabe 1 or 2 degrees, front is no toe in. Camber(if this is measured by inserting the clips ontothe pivit ball arm location, then I am pretty sure I am at 1 degree camber front and either the same in the rear or at 2degrees. Ride height, I am at 5 in the front and 6mm in the rear.
Any suggestions for a medium bite track with medium tight turns?
Thanks for your help guys
P.S. If you could explain in depth about how to measure toe in/out, camber/caster etc and with what tools, that would be amazing.
do yourself a big favor...
one,go to HPI's site and download the manual for the r40....
second,look at the links on the left....go to the FAQ section,and read up......if you know whats in that section,and apply it with practice,you'll smoke 70% on the track on knowledge alone...
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 03-09-2005, 06:58 PM   #4728
which faq? I know about engines etc. I am just new to adjustable set up. It is something my rs4 3 didnt have.
Thanks for the help.
Probably going to stick w/ the rmp gauges or the duratrax one.
nitroracer20 is offline   Reply With Quote
Old 03-09-2005, 07:11 PM   #4729
KLANDERMAN's Avatar
Thumbs up
I read what fastharry was talking about... he's trying to save you some money...It is important to learn about how to balance your car in order to win races.
I usually race for fun on weekends, but nevertheless I try to keep my car balanced and ready for the competition.
What you can do is use atsushi hara's set up sheet, or download the r-40 manual to know how to set it up.
good luck
let me know if you need anything else
Old 03-10-2005, 10:01 AM   #4730
KLANDERMAN's Avatar
hey you guys!! the soda worked! the pipe is expanding, its not completely round, but I guess I can always used it as a spare part, or used in case of emergencies. I'm going to lieave another day in the freezer to see what happens
Old 03-10-2005, 10:31 AM   #4731
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Cool! Hey how did your friend's serpent hold up to the .18TZ? I'm hearing it's better in belt driven cars than shaft. The R40 is currently being worked on as I'm home again due to no access to get to college. The Mugen is fast enough, but I just wanted to know.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 03-10-2005, 10:37 AM   #4732
KLANDERMAN's Avatar
well what can I say, the .18 is fast as hell, but the car is hard to control, so hard that my friend had 2 car wrecks in which he broke pieces, while I just got hit and my pipe went boom! I ordered another one and it's already here, along with a new gas tank and an M3 body which I'm going to paint pearl black
Old 03-10-2005, 10:41 AM   #4733
KLANDERMAN's Avatar
HarKonnenD I did e-mail you the video clip of my R-40 against the serpent with the .18tz
Old 03-10-2005, 10:52 AM   #4734
HarKonnenD's Avatar
Yeah I saw it. I was just wondering how did it hold up. In the past I thought of a Sirio motor, but it's that they say the Sirios run better with a shorter gear ratio since they have a lot of top end. How much of a shorter ratio I don't know. Well I fixed a problem with my R40. I realized that I had TOO much toe in. The rear wheels are straight and when I push the car, the rear doesn't wiggle that much as it use too. I'm use to driving with no toe in or a little. I need more of them spacers for the PB's though. The car is just awesome. I'd regret it if I sold it!
Old 03-10-2005, 10:57 AM   #4735
KLANDERMAN's Avatar
awesome, I use 2.5 toe in in the rear, but if you like it with no toe in, I guess is how you drive. I f I was to get another engine I would stick with team orion. It's fast, reliable and easy to tune
Old 03-10-2005, 11:14 AM   #4736
KLANDERMAN's Avatar
HarKonnenD do you have like an indoor space to use your R-40?
Old 03-10-2005, 11:21 AM   #4737
HarKonnenD's Avatar
Yeah on my other car I had about -0.5 toe in and it was fine. The R40 when I checked had more than -3 toe in! I'll try the neutral setting later on when I can get outside. I love the way my car looks now with the new foams.
Old 03-10-2005, 11:23 AM   #4738
HarKonnenD's Avatar
BTW, it's hard to get Orion stuff here. I like the bodies though. I have my old BMW body that came with the NEO tnt for a beater once I make new body mounting holes with my new reamer .
Old 03-10-2005, 11:28 AM   #4739
KLANDERMAN's Avatar
cool... I'll go and pick up my stuff at the post office after lunch. Then I will start to see if pearl black is what I want on the bimmer body.
Old 03-10-2005, 08:27 PM   #4740
BOWTIE1's Avatar
Send a message via AIM to BOWTIE1 Send a message via Yahoo to BOWTIE1
ok hi all just a fast q, is the r40way better then the rs4? in racing and whats the best motor for the r40? i am new to onroad should i get solid axles? or leace them diff and is a front one way good for it also ? thanks
BOWTIE1 is offline   Reply With Quote
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
