Old 03-09-2005, 12:24 PM   #4711
KLANDERMAN's Avatar
Hey you guys I took my R-40 for a spin and hit a post on the side with the tuned pipe. Now it is all bent. Is there a way to fix it or am I going to have to bye another one?
It's pretty bent, I think I'll order a couple just in case
KLANDERMAN is offline   Reply With Quote
Old 03-09-2005, 01:18 PM   #4712
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Some say fill up the pipe with water, plug up the other end and then put it in the freezer. Try it and if this doesn't work get a new pipe. I set my R40 up with the new gear. Anyone run the adjuster nut tighter than stock to get better acceleration? One person said he ran it looser than stock and the acceleration is better. I ran mine and from the start it seems the engine revs a bit on the ground before going. Gonna try tightening it and running it for a bit sometime later on. BTW the stock foams look way better than my GRP foams
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 03-09-2005, 02:28 PM   #4713
KLANDERMAN's Avatar
so All I have to do is put water in it to see if it expands or something?
ok I'll try that later. I wonder if instead of water I put coke to see if the gasse make it expand?
I use the nut a bit tighter and it works great.
Old 03-09-2005, 03:06 PM   #4714
lets see a pic of the pipe.
I have a question. On my car, What is a good spring combo. Right now Im using the silver/chrome springs and I feel they are too soft for my liking. What would be a good combo for a medium to high traction surface with moderately tight turns?
nitroracer20 is offline   Reply With Quote
Old 03-09-2005, 03:32 PM   #4715
KLANDERMAN's Avatar
sorry tried fixing the pipe and put some soda in it to see if it expands in the freezer.
When it comes to suspension setup, I use the stock shocks and they work great
Old 03-09-2005, 03:45 PM   #4716
KLANDERMAN's Avatar
nitroracer20:
ride height is also important, what's your ride height, camber front/rear and toe in front/ rear?
Old 03-09-2005, 03:58 PM   #4717
ok, I diudnt get any instruction manual when I got my car to find camber/toe in but I will try to tell you. I know my rear is toes in mabe 1 or 2 degrees, front is no toe in. Camber(if this is measured by inserting the clips ontothe pivit ball arm location, then I am pretty sure I am at 1 degree camber front and either the same in the rear or at 2degrees. Ride height, I am at 5 in the front and 6mm in the rear.
Any suggestions for a medium bite track with medium tight turns?
Thanks for your help guys
P.S. If you could explain in depth about how to measure toe in/out, camber/caster etc and with what tools, that would be amazing.
Old 03-09-2005, 05:21 PM   #4718
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
[QUOTE]Originally posted by KLANDERMAN
[B]Yeah... Fla would be a good place to live.
Thats rite
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 03-09-2005, 05:29 PM   #4719
20 SMOKE's Avatar
They make degree gauges Associated has one you will be able to get front camber rear camber and rear toe with but no front toe or buy a set up station and do it all. is the track bumpy with good surface and how fast can you go through the corners then we can go from there
Jamie W
Old 03-09-2005, 05:39 PM   #4720
KLANDERMAN's Avatar
If it's not a bumpy track, I would try 4mm front and 5mm rear try to put the rear toe in to 2.5, no toe in in the front and if you cant go fast through the turns, use 2.5 camber in the front and rear to help you go through the corners a lot fa
Old 03-09-2005, 06:21 PM   #4721
hey,
What do you think is a better value, sa set up station or the associated tools?
Old 03-09-2005, 06:26 PM   #4722
KLANDERMAN's Avatar
if you are a serious racer, one that's going to compete all the time and want your car to perform to it's best, I'd go with the set up station, otherwise get the camber and toe in tool for $7.00 from duratrax at towerhobbies. other tools you will need are to see the ride height front and rear, but that's about it, the station has everything and is more professional, but it's gonna cost you like $250 bucks.
your choice...
Old 03-09-2005, 06:35 PM   #4723
20 SMOKE's Avatar
integy set up stationhttp://www.integy.com
Jamie W
Old 03-09-2005, 06:37 PM   #4724
KLANDERMAN's Avatar
haven't seen it...
Old 03-09-2005, 06:42 PM   #4725
20 SMOKE's Avatar
under tools $129
Jamie W
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
