Old 03-03-2005, 10:53 AM   #4621
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Originally posted by KLANDERMAN
Just make sure that the CG is as low as possible, maybe 4 1/2mm in the front and 5mm in the rear. the rear toe in at 2.5 to 3 to the inside and get a negative camber from 1 to 2.5
good luck!!
HEH, mine are 9mm all around and -2 camber. Works well goin over bumps and stuff.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 03-03-2005, 11:06 AM   #4622
HarKonnenD's Avatar
Default OS .12 TZ!!!!
http://www.rctech.net/forum/showthre...80#post1423980
IT's COMING!!!!!!! I'mma bag this for sure once I hear the review!
Old 03-03-2005, 11:49 AM   #4623
KLANDERMAN's Avatar
I guess if you drive through bumps it's OK, but mine was 8mm all around and I lowere it to 4 1/2 front/ 5mm rear and it handles way better... Maybe you should try getting another set of coilover shocks and set them to be lowered and try to see which handle better 4 U.
KLANDERMAN is offline   Reply With Quote
Old 03-03-2005, 12:24 PM   #4624
HarKonnenD's Avatar
I only did it for the parking lot, but I will lower it though. Gonna test out them droop screws on this car.
Old 03-03-2005, 01:33 PM   #4625
Rapid Roy's Avatar
Originally posted by Dark_Horse_Yeah
Hi i was just wondering what i can do to my HPI R40 Japanese edition( one with grey chassis) to make it handle on very high grip tracks to make it stop from traction rolling so i can push the car harder in corners is there anything i can do to it. is it setup or something plz reply and tell me
1st, how close is your setup to Hara's. It's posted on HPI's website. That will get you close. The best guide I have seen is from the setup manual that comes with the Serpent 710. Its principles will work on any on road car. I'm going to try and attach the .pdf file. Its kind of large, so we'll see if it works. Pages 32 and 33 are the ones I'm refering to.
edit
file was too large. If any of you can edit down a pdf file, let me know, I'll email you the original.
Rapid Roy is offline   Reply With Quote
Old 03-03-2005, 02:01 PM   #4626
AMGRacer's Avatar
Need a bit more info to answer this one properly. But the first thing that you need to get right is your tires. If you are on a really high bite track you should probably be running up near the 42 to 45 shore region with your tires. Then you need to lower the car as much as possible before it bottoms out too badly. I have run mine as low as 3.5mm on a really smooth high bite track.
AMGRacer is offline   Reply With Quote
Old 03-03-2005, 02:02 PM   #4627
nsxshogun's Avatar
Send a message via AIM to nsxshogun
[email protected] I can host it on my web space.
nsxshogun is offline   Reply With Quote
Old 03-03-2005, 02:08 PM   #4628
KLANDERMAN's Avatar
Where exactly is Hara's R-40 set-up list?
Old 03-03-2005, 05:11 PM   #4629
Rapid Roy's Avatar
Right here
http://www.hpiracing.com/graphics/se...sr40_setup.jpg
Old 03-03-2005, 05:12 PM   #4630
Rapid Roy's Avatar
NSX emailed you the file
Old 03-03-2005, 06:27 PM   #4631
Speedbug's Avatar
Default video
Hi Guys,
Here is some video footage of our racing in Townsville North Queensland, Australia.
The R40 is the one with the headlights.
The file is about 2M.
Speedbug is offline   Reply With Quote
Old 03-03-2005, 08:30 PM   #4632
HarKonnenD's Avatar
Where's the video?
Old 03-03-2005, 09:02 PM   #4633
Speedbug's Avatar
Default The video
Sorry guys, just read the fine print, max file size for attachments is 208kB, once the file is load on our club site, i'll post a link.
Otherwise email me and i'll reply with the attachment (2MB)
Cheers
Old 03-03-2005, 09:54 PM   #4634
Hey yeh that setup of haras is no good because the tracks hara races on arent as grippy as the ones here in australia for example moorebank sydney where the 2001 1/8th worlds were at.
Dark_Horse_Yeah is offline   Reply With Quote
Old 03-03-2005, 10:32 PM   #4635
AMGRacer's Avatar
Dude you are not helping us here at all. Tell us something to work with, what is your setup, what is your car doing, which track at the minimum.
I run on a quite grippy track, Brendale in Brisbane the site of the 2006 worlds and I use a variation of the Hara setup so your statement I feel is not correct. Perhaps Moorebank is grippier I dont know.
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
