Old 02-28-2005, 09:20 PM   #4606
AMGRacer's Avatar
Originally posted by HarKonnenD
Funny. My clutch nut never seems to move and I don't use any threadlock.
Yep I realise not all do this, but just something to be aware of. If it does not move then you are lucky
AMGRacer is offline   Reply With Quote
Old 02-28-2005, 10:40 PM   #4607
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Most definately. Heh. Anyone running the lola bodies on their R40s? I've seen the body in my LHS and would like to try one, but I think it would be nice if I had a rear floating mount. Do the stock body mounts work fine or best to get the other one? If anything I may just stick to TC bodies, but just wanted to know.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 03-01-2005, 05:30 AM   #4608
nsxshogun's Avatar
Send a message via AIM to nsxshogun
I want to try one also. Does the r40 even have a floating body mount set?
nsxshogun is offline   Reply With Quote
Old 03-02-2005, 01:03 AM   #4609
Bundy_Bear's Avatar
Originally posted by AMGRacer
Did some testing of my brand new 2004 kit today. Got some interesting results.
1. I have had 3 HPI flywheels now and every one of them has had a pin come loose. You should always give each pin a bash before using it.
2. I forgot that I changed to the Mugen clutchnut on my old clutch. When using the HPI one the clutch nut self adjusts, not a good thing. Either change to a mugen one or put some loctite on the HPI one. Mine adjusted itself twice, so much so that it undid the clutch nut.
Seems like I had the same problem a few others have had. After doing the above mine is fine now.
AMGracer: I jinxed you
BB
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 03-02-2005, 07:12 AM   #4610
HarKonnenD's Avatar
AMG-2004 kit as in the one with all the HPI upgrades on it?
Old 03-02-2005, 07:57 AM   #4611
KLANDERMAN's Avatar
I have tried a variety of tires on my R-40, but I still can't tell which are better for the surface (parking lot). What's the best configuration for parking lot action?
KLANDERMAN is offline   Reply With Quote
Old 03-02-2005, 11:09 AM   #4612
Rapid Roy's Avatar
You need to use a stopwatch and time your practice laps. Do 10 laps or so with each set of tires. I'm not really consistant enough to get a good reading with a stop watch so I just use whatever gives me the best control.
Rapid Roy is offline   Reply With Quote
Old 03-02-2005, 11:15 AM   #4613
KLANDERMAN's Avatar
ok I'll try that... I bought a personal lap timer that comes with a transponder, so I will try this weekend
thank Rapid roy
Old 03-02-2005, 02:57 PM   #4614
AMGRacer's Avatar
Roger.
Old 03-02-2005, 02:59 PM   #4615
AMGRacer's Avatar
BB
You bastard Gonna do some more testing today see if I can keep it consistent.............
Old 03-02-2005, 03:09 PM   #4616
Bundy_Bear's Avatar
Any word on those prices yet
MissMooRC Racing
Old 03-02-2005, 09:32 PM   #4617
Hi i was just wondering what i can do to my HPI R40 Japanese edition( one with grey chassis) to make it handle on very high grip tracks to make it stop from traction rolling so i can push the car harder in corners is there anything i can do to it. is it setup or something plz reply and tell me
Dark_Horse_Yeah is offline   Reply With Quote
Old 03-02-2005, 11:35 PM   #4618
Speedbug's Avatar
Default Race Car Set-up
Hi guys, check this out, it's something I found on the web.
Hope it helps
Speedbug is offline   Reply With Quote
Old 03-03-2005, 12:40 AM   #4619
hey yeh that doesnt really help me much i just want the car so i can drive it hard into corners so it doesnt traction roll on really high grippy tracks
Old 03-03-2005, 08:36 AM   #4620
KLANDERMAN's Avatar
Just make sure that the CG is as low as possible, maybe 4 1/2mm in the front and 5mm in the rear. the rear toe in at 2.5 to 3 to the inside and get a negative camber from 1 to 2.5
good luck!!
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
