HPI R40 Nitro Car Forum
#4576
Im loving that truck body. After I get my 350 and my lola body i might have to try it out.
#4577
I ran this body on my Yokomo GT4 out at SV Speedway. It gets killed out at the straightaway, but it handles the turns so well. Can't wait to see how this will do on the R40.
#4578
Hey KLANDERMAN can i see some pics of your 350 on your avatar.
#4579
Originally posted by KLANDERMAN
Bundy_Bear: Good luck....
What breaks are U using?
Now the car stops...
Thank you to AMGRacer, FastHarry, BF, & others for assistence with this problem
AMGRacer: Your setup is the bomb! Talk to trackside tomorrow
BB
#4581
Guys,
I had thought i was finally over all of my problems... WRONG! The clutch is slipping now. On further investigation, the adaptor that locks the flywheel onto the pilot shaft is coming loose. I have been told it doesn't need to be loctited as it does it self up when the motor is running. I did however try just a little bit and it still did it.... I am frustrated with it as the car appears to be handling well and i can't get a chance to have a good crack at it
I look forward to hearing your suggestions
BB
BB
#4582
Loctite will fix that. I always use loctite on that part. Make sure you tighten down on real good. If you don't tighten it enought th little bit of loctite won't help.
#4583
Location: Louisville, KY!.. USA!! ....Home of http://www.fastharry.com
hey,look who's back....my main man,treky 11......now here's a guy who not only knows his stuff....he is fast(even faster then me.....)......and shows all comers(and cars) a thing or 3 at our track..(or any track we go to)....welcome back,buddy
#4584
007kel do u have anymore pics of the truck body?
#4585
#4586
I have these right now.
edit: Ooops, attach. didn't work.
#4587
Here's one pic
#4588
350 pictures
Here you go fellas...
Nissan 350 Z fairlady...
#4589
Pictures
This is the other 350z.... The one I have on the avatar...
