Old 02-21-2005, 07:23 PM   #4546
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
the kit says 50,000 in front dif and grease in the rear you could play with the 1 to 5,000 in the rear but to much may make it loose
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 02-21-2005, 07:38 PM   #4547
should I run 5,000 in both diffs? I was thinking I would just run 3,000 in the rear and 5,000 in the front? Is that right. Or is the oil too thin? Sorry for all the ?s but heres one more. I have the diff apart everthings apart. When I put the diff oil in should I just poar it in and the gasket will keep it sealed, or do I pour it half way or what?
Thanks Guys
nitroracer20 is offline   Reply With Quote
Old 02-21-2005, 07:49 PM   #4548
JAG Racing's Avatar
Send a message via AIM to JAG Racing
Which weight oil/grease in the differential depends on track layout and track-tion.
For low-traction surface ( which I run on ), use just a dab of grease in the rear diff and heavy oil in the front ( like 50,000 - 100,000 ). This heavy of grease tends to make the differential near "lock-up" so you may as well spend the $16 on the solid axle for the front and save some mass.
There is lots of info on this thread earlier on this topic.
JAG Racing is offline   Reply With Quote
Old 02-21-2005, 08:49 PM   #4549
great, thanks for the info.
Old 02-21-2005, 09:21 PM   #4550
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Well I sealed up my diff as I realized the reason why it leaked is that I didnt tighten the screws down far enough. I sealed and retightened everything so I'm waiting to see what it does soon. Gonna have to wait till the snow melts. Hmm...make have to check out this rear axle thing.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 02-21-2005, 09:42 PM   #4551
JAG Racing's Avatar
Wink
Snow? Hhhmmm, we almost hit 83 degrees here today
Old 02-21-2005, 09:46 PM   #4552
HarKonnenD's Avatar
Man, you're the 10th person with perfect weather . We got 6-8 inches of snow, but it's been melting a bit already. However they said we'll get more!! S.O.A.B!!!
Old 02-22-2005, 09:11 AM   #4553
KLANDERMAN's Avatar
Here in Guatemala the weather is always around 70 degrees. People call it the country of eternal spring... perfect weather.
Anyway has anyone ever driven the HPI PROCEED?
I'm thinking of buying one to go postal on all the serpents 235's that run around here pretending to be so fast... Well if anyone has had experience with one let me know.
KLANDERMAN is offline   Reply With Quote
Old 02-22-2005, 11:54 AM   #4554
Rapid Roy's Avatar
Thanks Guys
Whatever you end up doing, make sure that the front is stiffer then the rear. Otherwise the rear end will want to slide out.
Rapid Roy is offline   Reply With Quote
Old 02-22-2005, 04:51 PM   #4555
20 SMOKE's Avatar
Yea snow im down here in FL and it is be u te full
Jamie W
Old 02-23-2005, 05:10 PM   #4556
hey guys,
I finished rebuilding the cars diffs and I realized that the guy had a one way differential in the front. Im pretty sure that this isnt the same thing as the rear spool axle but I just want to clarify. I read on here that the one way makes the car a whole different car to drive. Is this true? I have the old diff if I dont like the one way so Im pretty much set. Thanks for your help guys
Old 02-23-2005, 07:26 PM   #4557
HarKonnenD's Avatar
It sure makes it whole new car alright. You get no front braking. You now have to really go easy on the braking otherwise you'd just spin out. I ran my R40 today and WOW what a difference the .8 module gears and LW shafts make. Don't think I actually want a new engine now. I had to blip the throttle in the basketball court shown in the picture. BTW due to the dust, I slide right into that big puddle near that basketball hoop, but I drove right out of it and it kept tickin. Just had a nice vapor trail behind it due to the water that got on the body and soaked in the foams. Also managed to accomplish burnouts like the 8th onroad in the trilordy video. SWEETNESS! The most fun I've had with the R40.
Old 02-23-2005, 07:27 PM   #4558
HarKonnenD's Avatar
Funny how with the flash makes the background dark and without the flash shows the actual lighting. This picture is wavy, because I slipped. FRIGGIN BLACK ICE!!!
Old 02-23-2005, 07:28 PM   #4559
HarKonnenD's Avatar
Here is the pic with the flash..
Old 02-23-2005, 09:31 PM   #4560
KLANDERMAN's Avatar
hey you guys I'm going to try and attach a small video clip of this cool parking lot her in Guatemala that I found to drive the R-40...
Lets see if it works! HOpe you guys enjoy it!!!
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
