Old 02-21-2005, 10:10 AM   #4531
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
Originally posted by Bundy_Bear
yep!
Thanks to Robin dropping the orginal into me at work today i can give that a try
BB
P.S:
When can i annoy you for those castor clips?
who's robin?....
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 02-21-2005, 11:06 AM   #4532
JAG Racing's Avatar
Send a message via AIM to JAG Racing
Originally posted by KLANDERMAN
Maybe I can put silly putty on the stock one, or glue the inside to see if it works as a one way and to break with all 4's.
I use the "rear spool" axle in the front instead of the rear and it works great. This gives you the best of both worlds. And no more leaky front case too.
JAG Racing is offline   Reply With Quote
Old 02-21-2005, 11:45 AM   #4533
KLANDERMAN's Avatar
What do you mean the rear spool axle??? do you have a picture of it?
I don't understand?
KLANDERMAN is offline   Reply With Quote
Old 02-21-2005, 12:32 PM   #4534
Jea3's Avatar
I too have used the "rear" spool diff in the front. It does work real good.
Valkariarc.com | HobbytownRacing.com | SuperiorHobbies.com
Jea3 is offline   Reply With Quote
Old 02-21-2005, 12:39 PM   #4535
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
How does the rear spool act in the front? I thought it wouldn't work in the front, hence the name "rear" spool.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 02-21-2005, 01:54 PM   #4536
Rapid Roy's Avatar
I don't understand?
Its also known as a solid axle. Check out HPI's site for a part number. Its a solid aluminum cylinder that replaces the planitary gears in the diff. locking it up. You loose some steering on initial turn in, but it pulls harder comming out of the turn since the inside wheel doesn't spin.
Rapid Roy is offline   Reply With Quote
Old 02-21-2005, 01:55 PM   #4537
Rapid Roy's Avatar
Its just an internal piece. Since the insides of the front and rear diffs are the same, it can be used on both.
Old 02-21-2005, 01:58 PM   #4538
HarKonnenD's Avatar
Ahh IC. I was told not to go with that or the oneway from the LHS guys since it will make the car too loose though. Eh, I'll see what goes on. More interested in a new engine. Probably go with the RB V12 3 port turbo since it's good on bottom end and great on top end. Seems to have a better powerband compared to the Sirio.
Old 02-21-2005, 01:59 PM   #4539
Rapid Roy's Avatar
Default Re: stupid ?
Originally posted by nitroracer20
OK, I dont want to sound like the ultimate noob but I have a question. I bought my car used and I didnt get a manual/tools with it yet(getting them next time I go to the lhs). My question is how do I measure toe in/out, caster etc. Is there an included tool or what?
Thanks Guys
If you set up the car exactly as the manual shows, you should have a great starting point. HPI uses spacers and shims to give you the setup. You can double check with an adjustable triangle or protractor too. If you are going to do any serious racing though, you should get yourself a setup station.
Old 02-21-2005, 02:15 PM   #4540
KLANDERMAN's Avatar
Ok so it's a rear diff case but with out the gears... Like the solid rear axle seen on the serpent's 235...
Now, does hpi make one for the R-40 or do I have to try with an aftermarket brand?
... Thanks for the expalnation...
Old 02-21-2005, 02:31 PM   #4541
JAG Racing's Avatar
Here is the solid axle we are talking about. While it is marketed as a "rear axle" it will physically fit in the front as well. For $16, a worthwhile option.
Old 02-21-2005, 03:03 PM   #4542
Bundy_Bear's Avatar
Originally posted by fastharry
who's robin?....
Fastharry:
He would be better known as BF on these threads
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 02-21-2005, 06:12 PM   #4543
nsxshogun's Avatar
Send a message via AIM to nsxshogun
I was thinking of making a grafite chassis and other parts. I found a site psycho-tek.com that sells grafite by the sheet. would a 3mm sheet be strong enough for a chassis.
nsxshogun is offline   Reply With Quote
Old 02-21-2005, 07:05 PM   #4544
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
the chassis would break from the abuse and speed that they hit the wall and other things
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 02-21-2005, 07:09 PM   #4545
Default differential oil question
Hey Guys,
Easy question this time. I am rebuilding my differentials for race season, and the guy at the hobby shop just threw me some 3,000 and 5,000wt oil. I didnt think to ask what wt oil I should put in the front diff and what I should put in the rear diff. My question is what wt oil should I use in the front and what wt oil should I use in the back.
Thanks Guys
nitroracer20 is offline   Reply With Quote
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
