Old 02-19-2005, 05:36 AM   #4501
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
the bearings are the steering upgrade........AMG does a great job in here.......
and D is the man......I'll leave the rest unsaid....
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 02-19-2005, 04:33 PM   #4502
Bundy_Bear's Avatar
The CF plate isn't included, i think it is for ackerman adjustments
BB
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 02-19-2005, 06:50 PM   #4503
Jea3's Avatar
Well, after running my MTX3 all summer, and winning another point series, I've decided to pull out my R40's again.
I've done some more upgrades, but still seem to have a run time problem with the R40.
Same motor, same clutch out of the MTX3 that did so well this past year, but it keeps running 30 seconds short of the 5 minute mark in the R40?
Have they made a new tank, and is it a new part number? My wife is a nurse, and we used medical measurings to find my tank only holding 72cc. Is that last 3cc enough to make that 30 seconds up?
Also seem to still have a push coming into the turns. I'm on tight, but good traction tracks, that are using VHT for traction. I'm still running HPI tires on both my Mugen and R40's, usally 37 shore all the way around.
I have not tried the 40's in the rear yet.
AMG, Harry, any idea's?
R40 is 1 1/2 years old, but little run time. New light weight chassis, .8M, Titanium shafts, fiber towers and side brace, fiber battery cover, Futaba 9451 digital steering servo 120oz .10, and RB x12 motor, no cuts.
4.5mm front with 55 oil, stock black springs
5.0mm rear with 45 oil, stock black springs
2 deg toe in rear
.5 toe out in front
59mm trued tires all the way around
mazda6 bodies, painted by paintin' Pete 2004 Ifmar concorse winner.
Valkariarc.com | HobbytownRacing.com | SuperiorHobbies.com
Jea3 is offline   Reply With Quote
Old 02-19-2005, 07:00 PM   #4504
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
tank # 72527 75 cc
do they check fuel at your track if so you can add more pressure line ( double the lenght ) and you should get a little over 5 min or add more fuel line to
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 02-19-2005, 07:49 PM   #4505
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Nice ride.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 02-19-2005, 07:54 PM   #4506
Bundy_Bear's Avatar
AMGRacer / FastHarry:
Do you know what the differences are between the graphite brake disc and the stock disc?
Also,
What is the part no an were would i buy a new set of castor clips
BB
MissMooRC Racing
Old 02-19-2005, 08:39 PM   #4507
fastharry™'s Avatar
Do you what braking differences the graphite brake disc would make over the stock disc?
Also,
BB
I tried the 3 racing disc......hated it....
here's the link for the clips.....
http://www2.towerhobbies.com/cgi-bin...?&I=LXFKE9&P=7
Old 02-19-2005, 08:47 PM   #4508
fastharry™'s Avatar
2 deg toe in rear
.5 toe out in front
the new tank is the same part #..its got an upper raised lip on the top half..you'll know it when you see it...you might call HPI and say you're racing the car....they might exchange it for you....
as far as tuning,my r40 has the same push....i've grown to adapt to it.....it still turns better than my tc3 ever did...and through chicanes,it is way fast.....
I'd pick up a copy of the xxx tuning guide..
http://www2.towerhobbies.com/cgi-bin...&I=LXEGG9&P=ML
I'd also try the 37's in front.....and then start getting the back to swing around more.....try the 45 in front,and the 55 in back...
here's a couple pics of mine...
those are the proline tmaxx ball cups..
the foward car is teh same car as above..its from last year when I had the OS in it.......now its RB powered...
here..I just took this tonite..I haven't touchd it since the NY hpi challenge....
Old 02-19-2005, 09:49 PM   #4509
HarKonnenD's Avatar
Nice ride fast. BTw do you race at barnstormers?
Old 02-19-2005, 09:57 PM   #4510
Jea3's Avatar
Thanks Harry. I did some more adjustments tonight. We'll see how it goes.
Yes, that motor is not the RB in my pictures either. I was trying that WASP 3 port turbo. Only problem is, they forgot what the Turbo was for.
My RB gets up and kicks it, in a hurry. I was using the Mugen X12 motor, but sold it. That is a fast motor.
I'll call HPI on Monday, and see what they'll do for me.
Old 02-20-2005, 01:09 AM   #4511
Bundy_Bear's Avatar
Fastharry:
Thank you...
Why did you hate the 3Racing graphite disc?
Because at the moment no mater what i do, i have no brakes
BB
MissMooRC Racing
Old 02-20-2005, 04:53 AM   #4512
AMGRacer's Avatar
BB
The CF plate I have is a GPM part but is a direct replacement for the stock item.
AMGRacer is offline   Reply With Quote
Old 02-20-2005, 05:02 AM   #4513
AMGRacer's Avatar
2 deg toe in rear
.5 toe out in front
3cc at your consumption will equal 12 seconds. So it may well be a tank capacity issue to a degree. There is a new tank available. It is possible that the mugen is a little lighter hence more efficient?
I cant say that my car has a push on corner entry, at least not one that bothers me, of course hard to say what you call a push. As one formula 1 commentator noted getting on the brake .2 of a second earlier can make a push into a fast corner. However one noteable difference to your setup that I use is the stiffer rear springs. I almost always run black front and gold rear springs. I almost always use 40/40 shore tires as well. I find with this combo on my tracks I can balance the car with the front swaybar.
Another hint to make the car rotate harder, add shims under the rear camber links on the hubs. Try 2mm first, then .5 to 1mm from there.
Old 02-20-2005, 05:03 AM   #4514
AMGRacer's Avatar
Also,
BB
I have some caster clips you can have.
You can make this car brake ultra hard if you need to. You need a decent brake servo tho.
Old 02-20-2005, 05:47 AM   #4515
fastharry™'s Avatar
Fastharry:
Thank you...
BB
if you think you have no brakes now,try the graphite ..seriously,though,my car has great brakes with a 30 futaba 3010(BTW,a GREAT throttle servo...)....and the car is not known for bad brakes,so you might want to go through the linkage's...
and speaking of linkage.....now that I think about it,you know when I got the best brakes?.....when I put that 3 racing metal brake arm on.........
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
