Old 02-02-2005, 12:12 PM   #4381
Rapid Roy's Avatar
Default Re: gearing
Originally posted by bboytab
Guys,
any suggestions on the R40's gearing....i plan to use Hara's 2004 setup from hpi's website....track: has sweeping turns, a bit technical, straight is about 100 ft.
You might try going down one tooth each on the pinions. 100feet is pretty short. I run on a fairly technical track and will be gearing down 1st gear for the next race and leaving 2nd gear stock. Our straight is 150' or so.
Rapid Roy is offline   Reply With Quote
Old 02-03-2005, 08:23 AM   #4382
KLANDERMAN's Avatar
I just bought the pinion gears 17T and 20T for my R40, but I think I should have played with just the first gear. The straight is about 150Ft, I guess I'll try this configuration and let you know if the car is faster, but slower on the starts...
KLANDERMAN is offline   Reply With Quote
Old 02-04-2005, 10:42 PM   #4383
KLANDERMAN's Avatar
Default R40 chasis????
I found the R40 LW chasis at towerhobbies, but it's like $75.00. Does anyone know where I can buy it cheaper?
Let me know...
Old 02-05-2005, 04:47 PM   #4384
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Looks like I may get into 8th scale onroad with help from a friend. Therefore I'm trying to get a lot of stuff sold, including the R40 possibly.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 02-05-2005, 08:21 PM   #4385
HarKonnenD's Avatar
Did some rethinking and checking out my budget. I can afford the 8th, but it will have to be bought at a much later date. However, I can afford to race the R40 and bash the MGT. Therefore to enjoy 8ths feeling, I'll run wider tires in the rear and get the GTP lola body for the R40 instead. Won't handle like one, but looks like a minature version basically. New engine to come is a Sirio Evo 2 and Novarossi pipe.
Old 02-06-2005, 04:50 AM   #4386
AMGRacer's Avatar
Anybody have experience getting a sirio into the R40? I bought a world champ replica EVO 2 and it seems to me it is impossible to get the motor in without removing the handle, and clearancing the fuel tank (cutting it). Anybody offer some advice?
AMGRacer is offline   Reply With Quote
Old 02-06-2005, 04:19 PM   #4387
HarKonnenD's Avatar
I heard of people getting the Sirio Evo 2 in the R40 with no problem, but nothing on the W.C. version.
Old 02-06-2005, 05:51 PM   #4388
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
There is a guy that runs in the state series with a MTX-3 5port lola body in the 835 and runs in the top 5
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 02-06-2005, 06:06 PM   #4389
InitialD's Avatar
I thought it was always a problem regardless of which engine you use on the R40? I know some guys who runs Novarossi engines and still require to take out the handle to be able to access the engine...
Old 02-06-2005, 06:28 PM   #4390
AMGRacer's Avatar
Nope I have had JP, Novarossi, RB and STS all in there no problems. Just twist the carb slightly. This sirio is a bear.
Old 02-06-2005, 07:11 PM   #4391
HarKonnenD's Avatar
What 5 port engine? I don't recall any rules at floyd, but I'll try to buy spare stuff for the car and run the car the car with upgrades.
Old 02-08-2005, 12:07 PM   #4392
bboytab's Avatar
Send a message via Yahoo to bboytab
Default S3050
Guys,
Anybody have used a Futaba Digital S3050 servo? Just wonderin' if this will be enough for my R40's steering needs.
It has 6.5kg-cm or 90.2oz.-in. of torque and speed of .16 sec.
bboytab is offline   Reply With Quote
Old 02-08-2005, 02:17 PM   #4393
HarKonnenD's Avatar
I reckon the hitec 625MG. .15sec at 94oz of torque. Works really good for my cars.
Old 02-09-2005, 09:53 AM   #4394
HarKonnenD's Avatar
I have some upgrades hopefully coming in to the LHS and was wondering which one of these are beneficial.
One way diff ( I hate the way the stock diff leaks no matter what you do)
Solid rear axle- The track I'm gonna race at is fairly large not to mention where I bash at so I'll give it a try
.8module gears- This was said to improve top speed due to the pitch although the weight difference wouldnt matter.
lightwght 2speed shafts- Definately want my ride to do less work so this will help
After that, I'll think about what new engine I will change do if I go about that route. It's Sirio Evo II vs Ns12. Price vs price, power vs power, reliablity vs reliability.
Old 02-09-2005, 10:03 AM   #4395
KLANDERMAN's Avatar
Im having problems with the rear of my r40. It seams that is too loose and I can't control it anymore please help me on the set up!!! Its height is about 8mm front and rear, 2 degrees camber an 2 degrees toe in the rear I recon... should I lower the CG?
Should I get a solid rear diff? I already ordered the LW shafts,the shock towersand the fron one way diff, so it should work better this weekend...
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
