Old 01-26-2005, 09:18 PM   #4351
billysss's Avatar
Default 2004 r40
just got the 2004 at last. One way front, lots of titaniums. I downloaded hara and thad's set ups and see if this R40 lives to what they say it is. Good luck to me.
got to race...and temporarily forget the mess we're in...
billysss is offline   Reply With Quote
Old 01-26-2005, 09:47 PM   #4352
JAG Racing's Avatar
Send a message via AIM to JAG Racing
Default R40 - OverDrive Calculator
For all of you Excel users, I put together a little spreadsheet that calculates 4WD overdrive ratios for the R40. It assumes both front and rear tire diameters are equal.
Simply edit the pulley sizes and it will recalculate. Enjoy!
JAG Racing is offline   Reply With Quote
Old 01-27-2005, 01:21 AM   #4353
Rapid Roy's Avatar
Originally posted by Speedbug
The tires were the original ones that came with the kit, I have just bought some 40 and 45 shore rears and will give them a go.
I have also taken some toe in out of the rear to run 2mm instead of 3mm. Sacraficed some rear grip but it does seem to make a small difference to the tyres and the handling is still good.
Any thoughts on engine upgrade?
You must be running on a very abrasive surface. I beleive that the kit rears are 40 shore. I ran in a race last month where 35 shore tires were worn down all the way to the rim after one run, but 40's lasted and lasted with just as much grip. Sounds like you are getting things sorted out.
Rapid Roy is offline   Reply With Quote
Old 01-27-2005, 03:13 AM   #4354
AMGRacer's Avatar
Default Re: any suggestions?
Hi Guys, i am running the R40 pretty much standard as per the manual and I am going through a set of rear tires in 4X 4 min races. Is there something i can change in the set up to try to save the rears a bit, the car is handling great and the fronts are still like new.
I have locked up the front diff with modelling clay and the results were great on our tight track, have to buy the solid axel now.
I was thinking of upgrading from an OS.12TR(P)T to something with a bit more sting, maybe a SirioEvo2. Any other suggestions?
The Ozzy R40 comes with 40 shore rears. Going thru the tires that fast is not particularly uncommon on some surfaces. I raced at the Murwillimbah track on the Gold Coast and used 3mm off my rears in a 5 minute race.
There is not a great deal you can do to prevent tire wear.
AMGRacer is offline   Reply With Quote
Old 01-30-2005, 06:54 AM   #4355
back up on top!!
nitroracer20 is offline   Reply With Quote
Old 02-01-2005, 10:01 AM   #4356
KLANDERMAN's Avatar
Why is it that on my hpi super nitro I can hear the 2nd gear shift, but on the R40 I can bearly hear it? I know it shifts because on races I hear the other cars shift and I'm still in front, or at the same speed at the end of the straight?
KLANDERMAN is offline   Reply With Quote
Old 02-01-2005, 10:26 AM   #4357
KLANDERMAN's Avatar
Default Weight problems???
It says on the manual that the R-40 weighs around 1750g, but mine weighs around 2118g with everything including gas, I'm thinkink of buying the front and rear shock mounts (graphite) the front/rear titanium shafts, the LW.08 tranny and the steering brace (graphite) and the LW chasis to see how much weight I can shave off. I use an electronic weight system and in pounds my R40 weihgs 4.9 pounds, while the super nitro with everything including fuel only weighs 4.3 pounds.
HPI should have a super pro kit with all these extras included, cause when you look at it you spend a lot of dough $$$ in the after market.
Old 02-01-2005, 10:27 AM   #4358
InitialD's Avatar
For you R40 guys, apparently Surikarn after the switch to HPI is now running the R40 in the 1/10th scale TC.
Here is some pics from TQ Racing at a recent race in Thailand;
More report here.
Old 02-01-2005, 10:27 AM   #4359
KLANDERMAN's Avatar
I meant 1750grs....
Old 02-01-2005, 12:03 PM   #4360
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
How competitive its the R40 v/s the VoneRRR or the Serpent 710 on stock (just bought !!) configuration !? ...
thanks !!
Pat
Patricio "PATO" Concha
E-Mail : [email protected]
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 02-01-2005, 12:17 PM   #4361
Francis M.'s Avatar
Default Karn & R40
from the report looks like the car was good enough to post the fastest lap. I hope hpi sends him to the U.S. to run nitro events just like hara.
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 02-01-2005, 12:58 PM   #4362
InitialD's Avatar
Default Re: Karn & R40
No doubt, granted he was indeed Surikarn. Also mentioned was he had a lot of problems and spent a lot of time repairing his car in the pits...
Old 02-01-2005, 01:27 PM   #4363
Rapid Roy's Avatar
Default Re: Weight problems???
1st, weigh your car without fuel. That how its done for sanctioned racing. You can also buy the 2004 asian editon with all the lightweight option parts already on it. Even comes with titanium screws.
With your 2 speed, your super nitro uses a finger type clutch which engages really hard. The R40 uses a clutch style that is smoother and more consistant.
Old 02-01-2005, 02:09 PM   #4364
KLANDERMAN's Avatar
Thanks RapidRoy!!! Where can I buy, or see the 2004 asian editon with all the lightweight option parts? Is there a link or something that you can send me?
I race the R-40 mostly against serpent's 705 and 710, but I can hear them change gear while in my case, I can;t here mine change, I've heard it a couple of times, but like you say it's probably smoother than my super nitro. On the other hand myy car with out gas weighs aproximately 2000grs and thats why I need to get all the lightweight components... please advise on the like if you have it
Klanderman
Old 02-01-2005, 02:35 PM   #4365
KLANDERMAN's Avatar
Default Track layouts
does anyone have pictures of track layout for parking lots and and easy way to put them together?
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
