Old 01-18-2005, 02:27 PM   #4291
KLANDERMAN's Avatar
Can't say that I have seen them. Mine is fairly new, so I haven't had problems with the belt, but I did with the diff casing. A piece of glass messed it up pretty bad, so I'm replacing it with the aluminum diff case. I hope I made the right decision...
KLANDERMAN is offline   Reply With Quote
Old 01-18-2005, 02:32 PM   #4292
AMGRacer's Avatar
Default Re: belts
Originally posted by goldenboy
speakin about belts being tight....has anyone seen those orange looking fiber belts, ive seen them on g4's, i was just wondering if anyone makes them for the r40, cuz mine stretch really easily and come off, especially the side belt
thanks
I used to use these on my Kyosho. They are made by K Factory. They wont fit the R40.
HPI has some new optional belt for the R40.
AMGRacer is offline   Reply With Quote
Old 01-18-2005, 02:43 PM   #4293
Send a message via AIM to goldenboy
oo...do u know where i can see that new belt
goldenboy is offline   Reply With Quote
Old 01-18-2005, 02:53 PM   #4294
AMGRacer's Avatar
Old 01-18-2005, 06:53 PM   #4295
waht is different about them......are they better?
Old 01-18-2005, 07:30 PM   #4296
JAG Racing's Avatar
Send a message via AIM to JAG Racing
Default Re: belts
thanks
Havent seen the orange ones. My belts last me an entire season of racing and then I replace them just for reliability reasons only. Is is possible you have them adjusted too tight causing them them to stretch?
JAG Racing is offline   Reply With Quote
Old 01-18-2005, 08:16 PM   #4297
i didnt know u could adjust them....unless ur talkin about the belt tensioner.....but how would having it too tight make them stretch
Old 01-18-2005, 08:34 PM   #4298
JAG Racing's Avatar
Yes, the tensioner. The belt goes under severe stress conditions during acceleration. With a little slack, the belt is allowed to "self-tighten" instead of "stretching". The slack is taken up during acceleration. So without the slack, the belt will stretch.
I havent actually performed such stress analyses, its just my intuition. Take it for whats its worth .. I'm not a mechanical engineer... I work with electrons only
Old 01-18-2005, 08:54 PM   #4299
ya i have mine pushed all the way down cuz i thought i would make it stay on better..where do u think i should have it...
Old 01-18-2005, 09:25 PM   #4300
JAG Racing's Avatar
After belt tensioner is set, makes sure the belt has about 1/4 inch of "play" in it.
Alternate - from the botton portion of the "belt loop", lift up on the belt. See if the bottom can touch the upper belt of the loop. Mine comes about 1/8" from the two sides from touching. Did that make any sense?
Old 01-19-2005, 12:47 PM   #4301
i did not understand that...how bout on the slot where u can slide the belt tensioner....where should it be
Old 01-19-2005, 01:34 PM   #4302
Rapid Roy's Avatar
The belt doesn't need to be very tight. As long as it doesn't slip or fall off you are fine. Just remember, if you tighten it too much, you increase the friction and drag so you car won't be as fast.
Rapid Roy is offline   Reply With Quote
Old 01-19-2005, 05:22 PM   #4303
Speedbug's Avatar
Default round one victory
Hi Guys, Strike up another victory for the R40!!!
we had our first race meeting for this season last night which i ran the R40 for the first time. 3 first places and 1 third gave me the overall victory for the night. Thanks for all the good advice on the forum, next thing to try will be a locked front diff.
Can any tell me what is the best stuff to fill the standard diff with to lock it up, i have heard putty is good?
If the locked diff suits the track then i will buy a solid front axel.
Speedbug is offline   Reply With Quote
Old 01-19-2005, 09:14 PM   #4304
Rapid Roy's Avatar
serpent cleaning gum works, so does modeling clay. Its a hassle getting it back out though. You might be better off getting the solid axle. I think it only $13 or so for the aluminum plug that replaces the gears.
Old 01-19-2005, 09:36 PM   #4305
Speedbug's Avatar
Thanks, i'll try the clay and see how it goes.
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
