Old 01-05-2005, 01:49 PM   #4216
007kel's Avatar
Send a message via AIM to 007kel Send a message via Yahoo to 007kel
Originally posted by fastharry
hey AMG.....How much fun is the Drift package?...how about a small review?...I figure,maybe I'll convert the EVO 3 I won the Challenge with to a drift car....
Fastharry, sorry if I'm cutting in on this conversation. But I shoot vids for frequency-rc.com. And we were out at the JGTC in California Speedway, so we got a look at the HPI drift package. If you're interested, there's a vid we did on our site on the JGTC. It shows the drift package on a RS4 3 Evo in action.
KO PROPO HELIOS...yeah that's what I have left after leaving RC.
www.foundrycc.com
Instagram: 7kel
007kel is offline   Reply With Quote
Old 01-05-2005, 02:58 PM   #4217
AMGRacer's Avatar
I think the fun of a drift package comes from whether you personally enjoy drift or not. A few buddies of mine got bored with it in 20 minutes or so. I personally really dig it, like I said personal choice.
The package itself is pretty darn good. You get a new chassis plate and top deck plates which moves the motor really far forward basically unloading the rear wheels a lot. You get 26mm front and 30mm rubber tires that are quite hard. Also you get new driveshafts and a different exhaust manifold. My set also came with a veilside RX7 body.
I converted a SS with the .12R motor. It takes a little work on the chassis to get the car to drift well, there are instructions with the kit but they are all in Japanese. The tires are actually fairly grippy and with my SS in racing trim with the conversion it actually did not drift particularly well. Once I locked up the rear diff with some putty then the games began Now I can hold long lurid drifts through the sweepers. As a final note I set mine up so that the pipe stinger exits the rear of the car via a piece of fishtank pipe giving the impression of tire smoke on throttle. Way cool.
Here is a HPI video:
http://www.hpiracing.co.jp/contents/movies/stage_d.wmv
AMGRacer is offline   Reply With Quote
Old 01-05-2005, 03:40 PM   #4218
JAG Racing's Avatar
Send a message via AIM to JAG Racing
Originally posted by nsxshogun
Yea I have the one-way and I like the off power steering. But I haven't been the the track to test it yet. Ill probally try to pick up the solid axle and try that out. What about locking my diffs? Wouldnt that be the same as a solid axle.
Yea - pretty much. I have used 50k - 100k OFNA Diff lock oil in my front to lock it up. This weekend I will be testing the solid front. One advantage to the solid is the weight savings ( in the 10 - 15 gram range )
JAG Racing is offline   Reply With Quote
Old 01-05-2005, 03:43 PM   #4219
AMGRacer's Avatar
The solid rocks on a small tight track, you will love it
Old 01-05-2005, 06:26 PM   #4220
Speedbug's Avatar
Thumbs up G'day
Hi Guys, just thought i'd say g'day. i have been racing in townsville Nth Qld Australia for the past 8 months in electric and nitro classes, and this year have chosen an R40 as my weapon for anihilating the opposition. Still learning heaps about the car with every run, which by the way is a stock car straight out of the box running an OS12TR-P-(T) engine and JR XS3 radio with additional a.b.s. fail safe module. Thanks for all the interesting tips in the forum, still working my way through them all but will hopefully join in on the forums soon. Cheers, Speedbug
Speedbug is offline   Reply With Quote
Old 01-05-2005, 07:02 PM   #4221
InitialD's Avatar
It would give the same characteristics. But note that a real solid axle will always be lighter and have less rotation of mass than diffs that are locked.
Old 01-05-2005, 07:24 PM   #4222
nsxshogun's Avatar
Send a message via AIM to nsxshogun
Ok I thought It was the same but how do I lock it?
nsxshogun is offline   Reply With Quote
Old 01-05-2005, 08:58 PM   #4223
JAG Racing's Avatar
You never truely lock it. But when you fill the differential case with such thick oil, it is virtually inoperative as a differential - quassi-lock
The diff lock oil will cost about $10 and the spool will cost about $16. You may as well get the spool and take the weight savings. Since the spool requires no oil, NO LEAKS either!
Old 01-05-2005, 09:26 PM   #4224
Speedbug's Avatar
if you use a lock diff for a short tight track, what changes do you need to make to steering geometry as a starting point, toe-in, toe-out or neutral?
Old 01-05-2005, 11:50 PM   #4225
Regional Moderator
kumpol's Avatar
where to buy a real solid axle ???
I just have the aluminum thing to lock the diff...is that it?
kumpol is offline   Reply With Quote
Old 01-06-2005, 04:48 AM   #4226
nsxshogun's Avatar
You can get them from towerhobbies or anywhere else that sells r40 parts. I now need to raise my front ride hieght. I have both grafite towers and the rear is nice and high. But I can never seem the raise the front. Whats a good way to do that?
Old 01-06-2005, 06:17 AM   #4227
JAG Racing's Avatar
I would suggest just changing one thing at a time. After you install the locked front diff., run the car. Then make changes from there. You might be satisfied with only that change.
Old 01-06-2005, 06:18 AM   #4228
JAG Racing's Avatar
That's it! You are just placing the planetary gear set with the solid aluminim cylynder piece.
Old 01-06-2005, 06:21 AM   #4229
JAG Racing's Avatar
By adjusting the front shock springs (comress the spring more). If this doesnt work, then some of your droop/chassis stop adjustments are the limiting factor. Also - are you using the stock shocks? Make sure they extend fully.
Old 01-06-2005, 01:01 PM   #4230
nsxshogun's Avatar
Yes currently im using stock shocks. I just got finished rebulding the shocks so they word fine. Ill check the droop and settings though.
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
