Old 12-17-2004, 11:12 PM   #4156
Rapid Roy's Avatar
The .8 gearing is taller, but those that are running the .8 say that the included .8 gears pull as hard as the ones on the stock 2 speed.
Rapid Roy is offline   Reply With Quote
Old 12-18-2004, 09:59 AM   #4157
I have a question about a lighter chassis for the r40. What is a good one to use? HPI offers their own but i found a couple of others. 3Racing makes one, if you go to www.3racing.com.hk you will see it. Also alot of people on ebay sell one, It doesnt specify a brand but here is what that one looks like Click here. Any suggestions?
Maxx is offline   Reply With Quote
Old 12-18-2004, 10:32 AM   #4158
JAG Racing's Avatar
Send a message via AIM to JAG Racing
MAXX - Check out page 137 of this thread...
JAG Racing is offline   Reply With Quote
Old 12-20-2004, 09:32 AM   #4159
BF
I keep popping front knuckles. I do this by hitting things but that is not the point . The point is the knuckle cariers crack and you can't see the cracks. But it's the cracks in the cariers that let the balls free.
I'm not buying anymore front knuckle sets until they make a graphite set.
Just do it.
BF is offline   Reply With Quote
Old 12-20-2004, 09:44 AM   #4160
Chewdogg's Avatar
I use a thin layer of 2 part epoxy on the top and bottom of the knuckles(where the crack usually forms). It reinforces them a little. The knuckles will still break it just takes a little more force to break them.
The R40 was my first car so I broke a ton of knuckles learning to drive this car.
Chewdogg is offline   Reply With Quote
Old 12-20-2004, 10:06 AM   #4161
Registered User
OB42TC3's Avatar
Has anyone got hold of the new belts yet?? Where?
OB42TC3 is offline   Reply With Quote
Old 12-20-2004, 01:28 PM   #4162
JAG Racing's Avatar
Originally posted by fastharry
Trust me..the 2004 kit exist's..I have 2 unbuilt kits....they also include the lw motor mounts and ti screws....
RCMODEL.com has them....You can't blame the guy for giving you that answer.....He's not required to know another countrys product....I can tell you I'm a Miele vacuum and appliance dealer in NJ.......I could care less what Miele vacs they sell in germany.....
Harry - What is the weigth on the 04 Spec car? Can you please describe if weight is race-ready or not. thanks.
My R40 (raceready by my definition anyway) is 1895 grams. My other totally stock car is at 1975 grams. I have the lightweight shafts, lightweight battery, light-weight 2-spd, and graphite shock towers, and Alum. shocks. I realize I can save 20 grams with the lw chassis which would get me to 1875. Do you know how much weight savings the titanium screw kit provides?
Please suggest a R40 diet for me to get to 1800 grams.
Thanks in advance!
Old 12-20-2004, 01:50 PM   #4163
JAG Racing's Avatar
Default Re: Re: Re: Re: 4WD overdrive settings
Originally posted by AMGRacer
The pivot balls I am talking about are here:
http://www.gpmracing.com.hk/car/page/r40_1.jpg
I am not saying that they are brilliant, but they are lighter (I weighed them) and they have lasted around 5-6 months so far.
AMG,
How much did one of the Titanium pivot Balls weight? I weighted the stock one at about 3.5 grams per. How about any of the other titanium options on the link? Do you have any of them? Weights?
Thanks,
Old 12-20-2004, 01:53 PM   #4164
007kel's Avatar
Send a message via AIM to 007kel Send a message via Yahoo to 007kel
Default Thrust Bearing
Hey, would anyone know if a thrust bearing from a Mugen MTX3 work on a R40 clutch? I want to run tonight at the track, and I'm coming short on resources. The track will most likely have the mugen parts over the R40.
KO PROPO HELIOS...yeah that's what I have left after leaving RC.
www.foundrycc.com
Instagram: 7kel
007kel is offline   Reply With Quote
Old 12-20-2004, 02:23 PM   #4165
AMGRacer's Avatar
The 3Racing chassis is almost the same weight as the stock item. Only the Hara chassis and the HPI lightweight chassis are significantly lighter than the stock chassis from what I have found.
AMGRacer is offline   Reply With Quote
Old 12-20-2004, 02:27 PM   #4166
AMGRacer's Avatar
Just do it.
Where you racing at man, I have not seen you for a while. At wynnum if you hit those ropes while going quickly you can pull out the hubs, happened to me a few times. However it is because the rope grabs the wheels/axles unlike many other track borders which dont grab as much.
I have a feeling that a graphite set would be even more brittle, probably would not help greatly. If it is a chronic problem you can get alloy ones from a few sources.
Old 12-20-2004, 02:30 PM   #4167
AMGRacer's Avatar
Thanks in advance!
Are you running rubber tires and a front oneway? I can get my car down to 1730g ready to run using foams and a oneway with the 2004 spec car and the lightweight battery. With rubber tires and a front diff it gets up over 1800g.
Old 12-20-2004, 03:20 PM   #4168
JAG Racing's Avatar
AMG - I run BSR capped radials which weigh about the same as a foam ( 25g per tire/wheel ). I am forced to run front diff at my track. Wonder if I can buy the rear spool and use it in the front?
Do you run rear diff or spool? What am I missing?
Old 12-20-2004, 04:58 PM   #4169
AMGRacer's Avatar
I will recheck all my weights tonight, been running rubber spec for a while now. You can make the front diff into a spool.
Old 12-20-2004, 07:46 PM   #4170
nsxshogun's Avatar
Send a message via AIM to nsxshogun
I gotsa problem. When my car is sitting still it hardly turns to the right and when I turn it left the wheels don't center untill I turn the whell to the right. I think somethings binding somewhere.
nsxshogun is offline   Reply With Quote
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
