Old 11-18-2004, 04:42 PM   #4066
Sow&Steady's Avatar
Default BRCA 2005 Rules
If you intend to race in the BRCA Nationals next year, the 2005 Rules Amendments for 235mm, Scale Rubber and 200mm Scale Touring classes is now available at 3hobby.com for download.
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 11-19-2004, 12:59 AM   #4067
i got a new r40 and i think all of the hop ups besides the .8 gear set for it but my question is will all the light weight stuff i put on it make a big differance? im still puting it together so i dont know what stock feels like. i know its a couple ounces lighter then the stock kit now but will it matter ?
cain921 is offline   Reply With Quote
Old 11-20-2004, 07:20 PM   #4068
JAG Racing's Avatar
Send a message via AIM to JAG Racing
Check pages 131 - 135 of this thread for discussions on this topic.
In a nut-shell, if you are a beginner to intermediate driver; NO. If you are an excellent driver looking to get that last nth degree of improvement; possibly.
Best bang-for-your buck on lightweight upgrades (IMO) are (1) AAA battery pack($23 -- 25 grams) and (2) lightweigth 2-sp($55 -- 20 grams), and (3) light-weigth chassis($75 -- 20 grams), (4)Aluminum body shocks($60 -- actually heavier than stock plastic case shocks).
JAG Racing is offline   Reply With Quote
Old 11-23-2004, 04:29 PM   #4069
Regional Moderator
Darkseid's Avatar
One thing to remember about adding all the lightweight stuff is the problem with fixing what aint broke. I added the stuff after running my car for a good portion of the season. It took me several races, at the end of my season, to re-learn the way I needed to drive the car. Suddenly a car that was 'hefty' and stable through the corners was now a car that was 'light' and darty through the corners. The driving experience...
Different
Not worse mind you...
Just Different.
If I had it to do over again, I would have either added all the stuff before the season, or waited to do it at the end of the season.
TLR 22...Tamiya F104...
Old 11-24-2004, 05:53 AM   #4070
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
That is true......
When I first drove the R40 after 2 seasons with the Tc3,I thought what a great car this is,.. more responsive,better low speed steering,as stable as the tc3.......
After my car was completely lightened,I drove a stock,except for shock towers(which gave it the same geometry as mine), r40....this car had the same set up as mine....only mine was way lighter....I couldn't even drive the car I hated it so much.....it was slow,unresponsive,and a pig through the chicane......
Now we all know thats not true.....but compared to a lightened car,thats the impression I got.......shows you how much a cars character can be changed....
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 11-24-2004, 10:43 AM   #4071
are you sure that the two cars had the same droop, clutchengagement, steeringackermann, tyres, diff oil, springs, shockoil/piston, rideheight, right tweaked? i think this makes the big diffrence in carhandling if you compare two cars that are the same model.
Mange is offline   Reply With Quote
Old 11-29-2004, 02:33 AM   #4072
Rapid Roy's Avatar
I know this was asked before, but does anybody have a good rubber tire setup? I had to switch the rubber last race because the traction was so low and I used the same setup for foam tire.
Rapid Roy is offline   Reply With Quote
Old 11-29-2004, 02:49 AM   #4073
AMGRacer's Avatar
I have "a" rubber tire setup, but I cant guarantee it is "good".
AMGRacer is offline   Reply With Quote
Old 11-29-2004, 08:39 AM   #4074
JAG Racing's Avatar
Roy,
I assume you are running on concrete surface. The best by a long shot is BSR tires ( capped radial tires; NETs ). The next best thing that I have found is the Take-Offs (27, 32, 37 compounds) using the HPI Blue Med/Firm 24mm inserts.
Good Luck
Old 11-29-2004, 11:51 AM   #4075
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Post
Man I don't know whether to get an MT, or to get upgrades for the R40 and my 8th scale buggy. Hhmmm...decisions decisions.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 11-29-2004, 03:36 PM   #4076
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Default R40 4 Sale
I'm selling one of my cars $175
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 11-30-2004, 09:06 AM   #4077
I need some advise on the 2 speed clutch shoe for the R40...it seems that after several runs the 2 set screws that hold down the 2 metal ball get loose. have any of you guys had such incidents happening....do you guys think that it is advisable to glue the set screw down to prevent it from coming loose again. cheers mate.
paradiso is offline   Reply With Quote
Old 11-30-2004, 11:13 AM   #4078
JAG Racing's Avatar
I have not seen this before. You shouldnt have to use glue. I have had a few "issues" with the lightweigth 2-speed parts that were related to improper parts packaging.
I would recommend calling HPI Support and ask them for a 2-speed rebuild kit. This would give you the new shoes and set screws you need.
Good Luck!
Old 11-30-2004, 02:46 PM   #4079
AMGRacer's Avatar
I assume you have the lightweight 2 speed. Mine does exactly the same thing. Drop a bit of loctite in there of teflon tape.
Old 11-30-2004, 04:42 PM   #4080
Rapid Roy's Avatar
Sorry for the delay, been sick. I should have been more specific with my question about setups for rubber tire. For those that run rubber and foam, how different are your setups. The only difference I usually have is in the camber. I reduce the camber by 1/2 degree front anc rear. Anybody else do anything more drastic then that. I'm just talking about a baseline setup so I know every track surface is different as is each drivers preferences and driving style
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
