Old 09-18-2004, 12:55 AM   #3886
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
Default Re: Re: Re: Re: Re: Thad:
Originally posted by jscamry
Thanks a lot BF!! This maybe a dumb question but thses spacers are for the camber settings? right?
not a dumb question,but no......
fastharry™ is offline   Reply With Quote
Old 09-18-2004, 11:00 AM   #3887
jscamry's Avatar
Send a message via AIM to jscamry Send a message via MSN to jscamry Send a message via Yahoo to jscamry Send a message via Skype™ to jscamry
Default Re: Re: Re: Re: Re: Re: Thad:
thanks fastharry, what are they for then?
thansk J
jscamry is offline   Reply With Quote
Old 09-18-2004, 04:52 PM   #3888
purplepro3's Avatar
Default Question
I am thinking of getting back in the nitro scene (my last nitro was the NRS4-2 with the Racer 2 conversion). Is the R40 2004 Spec worth getting for $350 or should I just get what is available here in the US...for about $100 less? Any input would be appreciated.
purplepro3 is offline   Reply With Quote
Old 09-18-2004, 05:02 PM   #3889
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
the 2004 spec comes with all the hop ups it is alot more the get a standerd kit and up grade
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 09-18-2004, 08:09 PM   #3890
Bandeira's Avatar
Send a message via ICQ to Bandeira
You guys may know this...
What tires was Atsushi using the roar Nats?
thanks in advance...
cheers...
Bandeira is offline   Reply With Quote
Old 09-18-2004, 10:28 PM   #3891
huskerfreak's Avatar
the orion kicks I think 40 up front 42 in the rear
huskerfreak is offline   Reply With Quote
Old 09-18-2004, 10:40 PM   #3892
Thad Garner's Avatar
cheers...
Qualifying
Morning - noon – 42F 42R (cooler track temperatures)
Noon- ... 40F 42R (hotter track temperatures)
Main
42F 42R
R1Wurks - Awesomatix USA
Thad Garner is offline   Reply With Quote
Old 09-19-2004, 08:48 AM   #3893
BF
If you mean, can you use them to raise the camber link arm from the rear knuckle, then yes. If you want to put them around the pivot ball, between the knuckle and the suspension arm then, why bother. I initially went looking for them when I lost a spacer from a rear shock.
BF is offline   Reply With Quote
Old 09-21-2004, 01:09 PM   #3894
Trader Rating: 16 (100%+)
Default Re: Question
Stock (US verions) is good to do some local track racing...but still, you will need some upgrade here and there.....
In order for you to upgrade piece by piece and get equal to the 2004 spec from the stock R40 US spec...you might need to spend easily $200 more (over the $250 R40 kits)...
The 2004 spec is around $350 plus 35 shipping from HK....$385...but overall, 2004 spec will get you a BIG RACE ready R40 (very close to HARA's car) and still, about close to $100 cheaper compare to upgrade from stock R40.
Old 09-21-2004, 01:25 PM   #3895
coastaltony's Avatar
Purple, I have a NEW built never run R40 for sale $175.00
Meucci pool cue collector
coastaltony is offline   Reply With Quote
Old 09-22-2004, 09:14 PM   #3896
JAG Racing's Avatar
Send a message via AIM to JAG Racing
Default R40 Turnbuckle slipping?
Need help!
The rear turnbuckles on my R40 tend to "slip" ( OK, maybe I tag a board every once in a while ). Even when I run a clean race the turnbuckles seem to "change" adjustment. It might be possible the downforce in a severe turn just might cause the thread to " slip " - but don't know for sure.
Anyway, anyone had this problem before? What is the solution?
The R40 kit uses M4 x 20mm turnbuckles. Where can I get the the titanium turnbuckles I see on Hara's car? What is the PN?
Thanks in advance!
John
JAG Racing is offline   Reply With Quote
Old 09-22-2004, 09:31 PM   #3897
AMGRacer's Avatar
Default Re: R40 Turnbuckle slipping?
Originally posted by JAG Racing
Need help!
Thanks in advance!
John
Yes this does happen, usually in a crash. It only happens very rarely on my car. I think if you have had it happen enough the ballcups will strip, try replacing them and see how that goes.
AMGRacer is offline   Reply With Quote
Old 09-22-2004, 09:39 PM   #3898
JAG Racing's Avatar
Default Re: Re: R40 Turnbuckle slipping?
Thanks! I'll try it
Anyone know the part number for the purple titanium turnbuckles for the R40? I assume they are still 4mm ?
Old 09-23-2004, 06:00 AM   #3899
fastharry™'s Avatar
use these ball cups....
http://www2.towerhobbies.com/cgi-bin...00&FVPROFIL=++
along with these spacers from the PRO 4(to raise the ball cup to the proper height)..
http://www2.towerhobbies.com/cgi-bin...?&I=LXGPB3&P=Z
and you'll be fine.......use the stock turnbuckles...they are easier to turn than the PRO 4 or lunsford 4 sided rods...
[IMG][/IMG]
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
Old 09-23-2004, 06:23 AM   #3900
JAG Racing's Avatar
That is alot of help FastHarry! Thanks.
OK, now to sooth my curiosity... Are the titanium turnbuckles on Hara's car from the Pro4 then?
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
