Old 09-08-2003, 09:11 AM   #376
treky11's Avatar
hey is it me, or is fastharry's signature file WAY too long. I'm tired of looking at 11 lines of his signature and scrolling through extras screens for his signature drivle.
treky11 is offline   Reply With Quote
Old 09-08-2003, 11:09 AM   #377
The Sleeper's Avatar
Originally posted by fastharry
yeah,but you might have hit the other side and cracked the tank
Well believe it or not, I did crack the tank on my R40. Also cracked the upper deck, broke the servo horn and the servo mounting braces!!
The Sleeper is offline   Reply With Quote
Old 09-08-2003, 11:16 AM   #378
Originally posted by treky11
Stop trying to make excuses for the R40's weak points. Accept them and move on.
Good point.
The TC3 had many weak points. First was the bumper. Did anyone break their stock bumper? And then there's the shock towers. Has anyone broke their diff case? You know, where the shock tower bolts on...
Old 09-08-2003, 02:41 PM   #379
Originally posted by The Sleeper
BUT,,, the thing that had alot of people worried about the R40 happened to me. I bet I'm the first victim of the "stuck out in the open" steering servo. Let's just say my prefectly good steering servo is now an unregconizable pile of junk.
I didn't get T-boned. I just hit a concrete barrier while barrel rolling down the straight stretch. The concrete made a direct hit on my servo. When I picked my car up, the servo was hanging by the wires. Mannnn,,,, I did not want to see that. And I was winning the race
I have found that using the Futaba S9550 servo helps this problem. If you are not fimilar with the servo it is the low profile one. It is a good bit shorter than standard servos so this keeps more of it under the upperdeck and less out in the open to get hit.
BallPy is offline   Reply With Quote
Old 09-08-2003, 02:45 PM   #380
1. The Rx box and the way it floats (although I want to know why Hara ran his car differently )
The reason Hara ran the car without the radio box was to lighten the car up. This car is a good bit heavier than most people like. He also l ran a lighter chassis. From what I understand they took weight off anywhere they could.
Old 09-08-2003, 04:35 PM   #381
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 09-09-2003, 10:40 PM   #382
Send a message via AIM to raveupon
treky11 ....how do u like ur .12 os tr turbo...im getting a r40 and im stuck on that or the novarossi ns12 5 port....thanks
raveupon is offline   Reply With Quote
Old 09-09-2003, 10:54 PM   #383
treky11's Avatar
just ran my os turbo for the first time tonite. tough to say right now.
the engine feels very good but was running a bit hotter than i would have liked. around 270. problem is that it was only about 65F degrees out tonite.
i only have about 7 tanks through it right now and its pretty tight so it might be getting a bit hotter because of that.
i can say that it idles like a champ, easy to tune and starts right up no problem.
i am sure the motor will fly in my ntc3 but i am concerned that the r40 might be too heavy for it.
i only paid 145 for the motor and bang for the buck i think its probably the best engine you can get for the price. one more night of running and i will be able to tell.
i have been running a 5 port rb in my ntc3 all season so that is my frame of reference right now.
i still believe os- tr turbo is a great engine but i want to run it once more to be sure. i'm going to play with my clutch settings this weekend and run it again during the day, hopefully it will be a bit warmer and then let you know.
Old 09-10-2003, 12:05 AM   #384
InitialD's Avatar
The OS engine should be torquey engine. With the R40 having high final drive ratios, I don't think you'll have problems.
I would use OS engines if I run on small tight tracks. Not for large open type.
Old 09-10-2003, 12:27 AM   #385
SO FOR PARKING LOT BASING U WOULD RECOMMEND THE OS ..INSTEAD OF THE ROSSI NS12 5 PORT...I WANNA BE AS FAST AS I CAN BE
Old 09-10-2003, 01:32 AM   #386
InitialD's Avatar
Parking lot bashing tracks can be huge too The selection of engine will depend on your track and more importantly the available gearing on the car.
If your car has very high final drive ratios (small pinions, big spurs), then a high revving NS12 engine can do the job nicely. OS engines have more bottom end and you can get away with large pinions / small spurs combo.
Power is nothing without control. You can be fast, but what's the use if you cannot handle it?
Old 09-10-2003, 01:35 AM   #387
cHckbOY5's Avatar
Send a message via AIM to cHckbOY5
i thought the r40 would be too low for parking lots
cHckbOY5 is offline   Reply With Quote
Old 09-10-2003, 01:20 PM   #388
treky11's Avatar
the r40 is ok on a clean level parking lot, for racing in a parking lot. i would not call it a bashing car.
the ride height can be adjusted like any other car but if you need lots of clearance because your running on a very rough lot or not a clean lot you probably will be happier with another car.
Old 09-10-2003, 01:48 PM   #389
puma1824's Avatar
Send a message via AIM to puma1824
Never heard back from you about your shocks...
-Puma
puma1824 is offline   Reply With Quote
Old 09-10-2003, 01:54 PM   #390
treky11's Avatar
I sent the pic 2 nites ago. I'll send again tonite when I get home.
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
