Old 09-13-2004, 06:40 PM   #3841
does anyone know where i can find the gearing charts for the
japanese version R40
thx
lou
look is offline   Reply With Quote
Old 09-13-2004, 10:05 PM   #3842
straightsixers's Avatar
Default Back and Front Belts
Any of you guys having problems with the current short belts from HPI?
They seem to strip and wear faster than other makes. I change each every 20-25 tanks!!!
Understand that HPI Japan is aware and are working on a new urethane or kevlar belt which should be out this month, similar to Mugen's i was told.
Is it available anywhere yet and anyone tried it yet?
straightsixers is offline   Reply With Quote
Old 09-13-2004, 10:06 PM   #3843
BundyMan's Avatar
Maybe instead of changing belts, you should change the car to a Mugen MTX3
BundyMan is offline   Reply With Quote
Old 09-13-2004, 10:13 PM   #3844
AMGRacer's Avatar
Default Re: Back and Front Belts
Here are pics of the urethane belts:
They are not released yet but soon.
However I must note that my car was purchased in January and I have run 3-4 gallons of fuel on the original belts. So I personally have not found that my belts have stripped or worn.
AMGRacer is offline   Reply With Quote
Old 09-13-2004, 10:15 PM   #3845
AMGRacer's Avatar
Gee you are hilarious. Shame that the Mugen came in BEHIND the R40 in 2003 and 2004 ROAR nats. Perhaps you need to change the Mugen for the R40?
Old 09-13-2004, 10:15 PM   #3846
Default Look who's here??
Learn to drive straight before you speak, boy!!
Old 09-13-2004, 10:25 PM   #3847
Maybe you should learn to drive straight before you talk straight bundyman!!
Old 09-13-2004, 10:27 PM   #3848
jscamry's Avatar
Send a message via AIM to jscamry Send a message via MSN to jscamry Send a message via Yahoo to jscamry Send a message via Skype™ to jscamry
Default Re: Side Brace
Originally posted by 20 SMOKE
Here you go jason
Who make that side brace?
~Jason
jscamry is offline   Reply With Quote
Old 09-13-2004, 10:31 PM   #3849
Default Belts and Pulleys
AMG, yeah thanks for the pix.
I guess it's the darn stones off the track here...
But really compared to others mine seems to wear faster and takes the pulley too!!
Wonder if using the alu pulleys would make sense?
Old 09-13-2004, 10:42 PM   #3850
AMGRacer's Avatar
Default Re: Belts and Pulleys
Yep I believe you. I think I might just be lucky for some reason, I cant really explain it. But if Japan has come up with the new belts there obviously seems to be some sort of issue.
The pulleys definately seem to be a little softer than my old Kyosho V1R pulleys thats for sure.
Old 09-13-2004, 11:39 PM   #3851
Thad Garner,
What do the rebound numbers on Hara's setup sheet mean? Are those numbers off a hudy droop gauge measured off the ball stud mount? And what exactly is 0mm bump stop?
boom is offline   Reply With Quote
Old 09-14-2004, 08:47 AM   #3852
BF
Originally posted by boom
Thad Garner,
I'm also wondering what this measurement means. It can be viewed in a number of ways. This also applies to the 90degree front sway bar setting. I would consider zero to be upright but the setup sheet shows 90degrees to be upright?
I also heard that there are now no HPI distributors in Australia. Looks like extra business for Tower.
BF is offline   Reply With Quote
Old 09-14-2004, 11:38 AM   #3853
Trader Rating: 16 (100%+)
Default Re: Re: Belts and Pulleys
I have to 2nd that, the original R40 belts are NOT the best I can find or experienced.........however, I am still using the original 3 belts, they are all worn out, stretched longer then used to be, but still...............they are usable, just doesn't look that good and you are see those liner coming out from the side of the belt..
Once we have the updated belt in state, I will replace them all, afterall, R40 is not the easiest car to replace belts, not to mention, all 3 at once, it will take hours....
Old 09-14-2004, 01:59 PM   #3854
Thad Garner's Avatar
Thad Garner,
0mm bump stop basically means that we didnít use the set screw to limit the up travel of the suspension, only the down travel (droop/rebound stop) see attached picture.
R1Wurks - Awesomatix USA
Thad Garner is offline   Reply With Quote
Old 09-14-2004, 03:15 PM   #3855
AMGRacer's Avatar
Default Re: Re: Re: Belts and Pulleys
You serious? The 3 belt change should take 20 minutes tops!
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
