Old 08-25-2004, 01:56 PM   #3691
Trader Rating: 16 (100%+)
Originally posted by 20 SMOKE
i noticed some slop in my arms and tried to add some shim's and it did bind so i took them out you may wan't to check the rite size i don't know if your going to get ride of the play completly.
hey Rookie do you still have those nuts i'm keeping the car
I do not have them on hand now (I only have 2 sets for myself)..and I am trying to locate my friend on the track but he didn't show up for race lately....I will keep trying to get him to send me more so I can send them to you guys...sorry about the wait.
Old 08-25-2004, 02:04 PM   #3692
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
That works i need two a friend bought my other car
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 08-25-2004, 02:09 PM   #3693
kidDynomite's Avatar
Hey Rookie, you talking about FatAlbert? I think he hooked up with a girl (he needs some lovin). Anyways, couldn't you use the shims you have and shave the plastic down to prevent binding? Or am I totally off base from your discussion?
kidDynomite is offline   Reply With Quote
Old 08-25-2004, 02:29 PM   #3694
No...different guy, this friend of mine actually machined those NUTS with reverse thread so you can use both at both end without worrying the cup will get pushed in.....
I am not quite sure exactly WHERE are you talking about..? We were talking about the rear upper camber linkage modification.
Old 08-25-2004, 02:36 PM   #3695
20 smoke....I still have your name on the list, i will let you know when I get enough on my hand...
After sold out both of your R40...what are you up to now? mugen, V1RRRRRRRRRRRRRRRRRRRR or 710?
Or you just got yourself the 2004 spec....
1 thing I still cannot get myself a 0.8 system onto my R40....there are no parts for that gear box.....no extra clutch, no extra spur gears...
Old 08-25-2004, 02:46 PM   #3696
I though 20 Smoke was talking about shimming the arms because of play. Anyways, he's keeping the R40.
Old 08-25-2004, 02:50 PM   #3697
I don't have any (at least not rediculously hugh) play in my R40 arms...if you have a arm that has a lot of play, shimming is NOT the solution, it is time to replace the mount and the arm.....
Old 08-25-2004, 03:16 PM   #3698
20 SMOKE's Avatar
I was geting a mugen that is the most popular car here in florida we have a stete series that brings over 100 racers every time and club races that is close to 50 so it would be a little hard to sell so i'm going to give the r40 a chance and give it hell. the rear arm play i measured the rear bulk head on three different one's and all where different there is only about 1/2 to 1 mm or so of play so i' don't care
Jamie W
Old 08-25-2004, 03:20 PM   #3699
20 SMOKE's Avatar
Dosen't hpi have the .8 on ther site here in US dosn't tower have it. I got mine before it was released i got lucky but i do wan't gearing. has any one checked a mugen gear if it has the same mounting holes for the two spd it will work a .8 gear is a .8 gear dosn't matter who makes it
Jamie W
Old 08-25-2004, 04:03 PM   #3700
i might not get the right info from tower, but I am also not sure the CLUTCH shoes of the 0.8 is the same as the 1.0 one...if not, I am sure TOWER doesn't sell the 0.8 one....
Old 08-25-2004, 05:32 PM   #3701
treky11's Avatar
Tower sells the .8 2 speed - whole kit and they also have all the spur and clutch bell gears.
LXHBL0 HPI Threaded Pinion Gear 29Tx16mm
HPIC7820 HPI Threaded Pinion Gear 25Tx16mm
HPIC7822 HPI Threaded Pinion Gear 27Tx16mm
HPIC7811 HPI Threaded Pinion Gear 21Tx12mm
LXHBK7 HPI Threaded Pinion Gear 26Tx16mm
HPIC7844 HPI Spur Gear 54T
HPIC7843 HPI Spur Gear 53T
HPIC7842 HPI Spur Gear 52T
HPIC7835 HPI Spur Gear 60T
HPIC7834 HPI Spur Gear 59T
HPIC7833 HPI Spur Gear 58T
HPIC7823 HPI Threaded Pinion Gear 28Tx16mm
HPIC7810 HPI Threaded Pinion Gear 20Tx12mm
I know, i got all my gears from them and they have the whole kit too - http://www2.towerhobbies.com/cgi-bin...?&I=LXGWX1&P=7
treky11 is offline   Reply With Quote
Old 08-25-2004, 08:37 PM   #3702
Hey 20, Unfortunately it does matter who makes it. Its not as universal a piece as most electric car's spurs. The Mugen gears also has three mounting tabs on their spurs as well but they are slightly bigger ... so they won't fit the 2 speed housing. I believe the new shoes are lighter, new material, but as far as the same size of the 1.0, sorry I'm not so sure.
Old 08-26-2004, 09:46 AM   #3703
20 SMOKE's Avatar
I know what your talking about that rite
Jamie W
Old 08-26-2004, 12:02 PM   #3704
Thanks...I think i need to learn how to use SEARCH ENGINE on Tower.....
However, still, no clutch shoes for 0.8 gear box....at least, if your shoes wear out, what are you going to do...?
Old 08-26-2004, 01:17 PM   #3705
tranced's Avatar
what type of rear body mount posts can be used on the carbon fiber rear shock towers? i see that hara had used them for the 03 nats, any takers?
tranced is offline   Reply With Quote
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
