Old 08-23-2004, 06:29 PM   #3676
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
i noticed some slop in my arms and tried to add some shim's and it did bind so i took them out you may wan't to check the rite size i don't know if your going to get ride of the play completly.
hey Rookie do you still have those nuts i'm keeping the car
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 08-23-2004, 07:09 PM   #3677
treky11's Avatar
Nigel's car was awesome! We were running good together in the first heat but something let loose in my car and it wasn't the same. He smoked me the rest of the day - and everyone else for that matter.
Anyone that runs out of gas on the track twice and still wins the A main is fast. Good job Nigel.
Are you going to the worlds now?
My R40 is in pieces, first I was flying down the back stretch in the 2nd heat and a car was sitting there dead that no one called - BAM.
Fastharry got it for me - it looked like a broken bumper so I went back out with it, BIG MISTAKE. 5 seconds later it took off - FLAT OUT down the stretch and straight into the board/curb. Can you say twisted. UGLY.
Oh well, it was good to see everyone. Still had a 3rd and two 5th place finishes in the A's.
And in case it wasn't said - FASTHARRY won the Nitro Stock A main in fine style! He held the TQ after round one, qual'd fourth overall and won by about 3 or 4 laps.
And if its true that races are won in the pits - then I deserve all the credit since I pitted him in his races.
treky11 is offline   Reply With Quote
Old 08-23-2004, 07:46 PM   #3678
20 SMOKE's Avatar
has any one found alum front hubs i was told there were some on ebay but could not find them any one know?
Jamie W
Old 08-23-2004, 07:56 PM   #3679
Rapid Roy's Avatar
I'm using 3~2mm shims on each side like the book says. I tried all kinds of combo with the 3 and 1 mm shims, but it didn't help. I guess the plastic thickness is pretty accurate.
Anybody else getting worn universals?
Rapid Roy is offline   Reply With Quote
Old 08-23-2004, 10:13 PM   #3680
NCC
NCC's Avatar
Adlawoo- Thanks! If I can recall I think you were under a red tent?
Treky- Thanks! It's always a pleasure racing with you guys every year. You did well too with three respectable A main finishes. I will go to the Worlds if everything goes well.
Harry- Congrats on your well deserved win! No more SlowHarry name calling again Good job Fastharry!
Rapid Roy- You need to keep the universals lubed. I used to have the same problem until I started using mobil 1 synthetic bearing grease which I got from the auto store and it works very well. Bearing oil will work well too.
NCC is offline   Reply With Quote
Old 08-24-2004, 01:15 AM   #3681
straightsixers's Avatar
Saw Hara today. get the shock towers, shafts and two spd and oneway every thing else in my oppinion isn't worth it
Also, get the alu hex wheel hubs.
Didn't reallyt believe it them previously, but during last weekend's race, busted the wheel and stock hex!! Couldn't finish the race.
I'm getting my today! eventhough it costs quite a bit
straightsixers is offline   Reply With Quote
Old 08-24-2004, 01:04 PM   #3682
Yup...that's me!
adlawoo is offline   Reply With Quote
Old 08-25-2004, 11:04 AM   #3683
Regional Moderator
Darkseid's Avatar
Hey guys, I got a quick question....
What causes the fuel to spash up when you open the cap to re-fuel the car?
I'm asking because I never had this problem before, but now I do. And I've changed a couple things on my car so I don't know what exactly cause this to start happening.
-I went to a new engine
-I shortened my fuel line considerably
Thats about it.... I always had a little bubbling there when the cap was open, not like this!
Anyway....any insight might be appreciated.
TLR 22...Tamiya F104...
Old 08-25-2004, 11:13 AM   #3684
coastaltony's Avatar
Cool, thanks
Meucci pool cue collector
coastaltony is offline   Reply With Quote
Old 08-25-2004, 11:28 AM   #3685
kidDynomite's Avatar
Default bubble trouble
I did the same thing ... shorter fuel line. I then learned that a longer one will prevent foaming. You could also use the large Kyosho fuel filter without the screen with a shorter line. But I just went to a longer (at least 8in) fuel line.
Let me know if this makes a difference.
BTW ... I appreciate your insight on the new OS. Can't wait to get mine.
kidDynomite is offline   Reply With Quote
Old 08-25-2004, 12:12 PM   #3686
Regional Moderator
Darkseid's Avatar
Originally posted by coastaltony
Cool, thanks
Don't forget, one-ways are more of a track layout thing. Its not neccesarily a must have.
Old 08-25-2004, 12:15 PM   #3687
Regional Moderator
Darkseid's Avatar
Default Re: bubble trouble
That was my guess as well, that the shorter fuel line was the culprit.
Heres my impressions of the new O.S.
http://www.rctech.net/forum/showthre...threadid=40966
Just keep scrolling down and you'll see a detailed discription of my first race day with it.
Old 08-25-2004, 12:46 PM   #3688
Default Re: Re: bubble trouble
Thanks, but I've been following the thread from the beginning. Keep up the updates. I may need them when I get my engine in.
Old 08-25-2004, 01:51 PM   #3689
Regional Moderator
Darkseid's Avatar
Default Re: Re: Re: bubble trouble
ooppss, I thought you were asking for my insight, now that I re-read your post, I see that you all ready read it.
...I gotta read those post better...hehehe.
Old 08-25-2004, 01:53 PM   #3690
Regional Moderator
Darkseid's Avatar
Well I just lengthened my fuel line back to what it was before I switched engines. So hopefully that will return me to being able to refuel the car without getting a nitro fuel shower!
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
