Old 08-18-2004, 08:34 PM   #3646
MRWRX_69's Avatar
Default Re: mugen clutch nut
Originally posted by jscamry
MRWRX- do you have the pt# for the mugen clutch nut? also will that slove slipping? I have purchased a new clutch shoe from mugen the grey shoe, and trimmed down the post and still slipping occurs.
thansk jason
hey man
ill find out for you, but that centax clutch nut is rubbish
MRWRX_69 is offline   Reply With Quote
Old 08-19-2004, 08:41 AM   #3647
X-Garage's Avatar
Have you guys ever tryied this solid axle in the front for making it like spool...or it should be used only for the rear.
X-Garage is offline   Reply With Quote
Old 08-19-2004, 08:44 AM   #3648
X-Garage's Avatar
One more thing...Can I use the same oil in the front and same in the rear?
Old 08-19-2004, 09:04 AM   #3649
Trader Rating: 16 (100%+)
Solid = SPOOL, just different terms that ppl use.....and you want to use it on the FRONT....if you want to use it on the rear, you MUST use 1-way up front on some HIGH BIT, BIG HUGH track...otherwise, use your rear diff and 1-way or diff in front.
With solid front, be prepare to have snapped CVD or twisted CVD, on high trackion track, that will gives you very quick steering, but since there are NO WHERE the extra power on both wheels to go (because it is solid), it will go to the dogbone....many ppl will have snapped or twisted dogbone because of that...so, be aware...
Yes, you can use both same # of grease on both front and rear diff....but I doubt it will work the best, the front WILL NEVER be set the same as the REAR of the car, if the diff is the same, your shock oil/springs, camber/caster, tire shores/diameter.....etc, one of the thing you must have to adjust in order to make your car handles great....
I would not do that, i would always make my front diff tigher then the rear...., I rather use the same oil/springs and tires F and R in stead of the same diff grease
Old 08-19-2004, 09:12 AM   #3650
X-Garage's Avatar
How about #100000 in the front and #30000 in the rear?
I felle like my rea diff is leaking. I can see the diff oil everywhere in the rear.
Old 08-19-2004, 09:14 AM   #3651
X-Garage's Avatar
Oh one more thing! Do you use the spring to pull the brakeback to nutral? because every time i brake that lever not returning back to normal position.
Old 08-19-2004, 10:09 AM   #3652
yes, a return spring should be used on the brake side of the servo. You should also have a spring independent of the throttle/brake servo to return your throttle to idle should you cut a power wire, dump gas on the receiver, or have a battery pack die. Failsafes only work when the receiver is working :/
If your diffs are leaking, just apply a thin bead of Blue RTV to both sides of the gasket and it will stop leaking with no side affects.
Good luck
minigiant is offline   Reply With Quote
Old 08-19-2004, 10:26 AM   #3653
X-Garage's Avatar
What is Blue RTV?
Do you have a picture of your car with return spring? I just can't picture what i should do.
Old 08-19-2004, 01:05 PM   #3654
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
What is Blue RTV?
Its silicone go to a auto part store ask for it . it is also used for sealing water pumps on cars get blue not black or red
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 08-19-2004, 04:25 PM   #3655
Rapid Roy's Avatar
Do any of you have the RC screws on their cars? I'm wondering if the hex is metric or standard. I have been using my metric dirver, but it fits a little loose.
Rapid Roy is offline   Reply With Quote
Old 08-19-2004, 04:32 PM   #3656
20 SMOKE's Avatar
might be torque just a thought
Jamie W
Old 08-19-2004, 04:35 PM   #3657
DOMOisCOOL's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to DOMOisCOOL Send a message via AIM to DOMOisCOOL Send a message via Yahoo to DOMOisCOOL
If they're made specially for that certain car, then the size of the head depends on the car. For example, NTC3 and other Associated cars have Standard US Size Heads, while other cars use metric size.
DOMOisCOOL is offline   Reply With Quote
Old 08-19-2004, 08:08 PM   #3658
Regional Moderator
Darkseid's Avatar
I thought RC Screwz used 2mm hex on all thier screws...
TLR 22...Tamiya F104...
Old 08-20-2004, 04:42 AM   #3659
yeah, mine are all 2mm and yes, they are a sloppy fit with the hex driver....
Old 08-20-2004, 09:31 AM   #3660
Personally, I find those metric screws annoying (again, why use machines screws on plastic parts...?).......now, I have to take extra times to remove those screws (at least 2 times longer)...........and I cannot use electric screws drivers (overheating the plastic....)
I still like the original self tapping screws from HPI, no wonder HPI is selling a whole set of Ti R40 screws for good $60 large one...and I am not sure that is availible in USA, I saw that on Rcmodel site over Hong Kong.
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
