Old 07-28-2004, 01:04 PM   #3556
Regional Moderator
Darkseid's Avatar
Yep, Hitec and Futaba are negative shift, everybody else is on positive shift.
TLR 22...Tamiya F104...
Old 07-28-2004, 02:40 PM   #3557
rod_b's Avatar
Send a message via AIM to rod_b
So does that mean I can use a KO radio with JR or Airtronics receivers? I asked this before because I like the Helios and wanna get rid of my JR R1 but don't want to spend a fortune switching out all my receivers...not to mention they are all synthesized.
rod_b is offline   Reply With Quote
Old 07-28-2004, 03:12 PM   #3558
StoneMan's Avatar
I've been trying to download the R40 set-up sheets from HPIRACING but only the top 1/4 page shows and I get an error report. Three computers later and still no luck.
Does anyone have one?
Or a link that works
Maybe you can email to [email protected]
Andy
StoneMan is offline   Reply With Quote
Old 07-28-2004, 04:21 PM   #3559
Regional Moderator
Darkseid's Avatar
Andy
You've got mail!
Hope it works for you.
Old 07-29-2004, 12:07 AM   #3560
straightsixers's Avatar
Default Radio Syst Concerns
Thanks Guys for all the valuable thoughts. Very insightful.
Have decided to go for the 3pk with HRS system.
BTW, its funny, back here in Malaysia/Singapore the LHS sells the radios as a package in the original box which includes the gun, extension adaptor and screws, the servos (S9451 x 2), receiver (HRS or PCM), a pair of servo horns and bolts, a receiver swith with Y-connectors and manual. This is the standard package. And besides, Both PCM and HRS packages are going for the same price.
Still need to know whether you guys have problems with 2nd gear engagement on the R40?
Thanks.
straightsixers is offline   Reply With Quote
Old 07-29-2004, 05:31 AM   #3561
Exe
Exe's Avatar
Send a message via ICQ to Exe Send a message via Yahoo to Exe
Default Re: Radio Syst Concerns
Thanks.
i did buy 3pk hrs from rc-mushroom for 270 + two digital 9451 servos for 95 each.. tower list them cheaper... waiting to arrive my stuff in a day or two
Exe is offline   Reply With Quote
Old 07-29-2004, 09:13 AM   #3562
BF
Default Camber Link Spacers
Although the manual doesn't show a spacer between the shock tower and the camber link on the back of the car, Hara's setup sheet on HPI shows a 3mm spacer and the photos of his car clearly show it.
Considering his setup uses a 2mm rear spacer on the lower hingpin, I would have thought a 2mm camber link spacer would be the go, but thats beside the point.
Does anyone else use a spacer here?
BF is offline   Reply With Quote
Old 07-29-2004, 09:34 AM   #3563
Trader Rating: 16 (100%+)
Originally posted by DOMOisCOOL
No, since Futaba and Hitec use different shift (I think it was negative), than JR/AIR/KO.
Oh damn....my mistake then, 1 more thing to learn today...........
Old 07-29-2004, 10:16 AM   #3564
Registered User
OB42TC3's Avatar
Default Re: Camber Link Spacers
Really? I thought his Nats setup and most of the other HPI driver setups have used the stock 0 position.
Personally I have found the +2 position adds a lot of stability on bumps.
OB42TC3 is offline   Reply With Quote
Old 07-30-2004, 05:36 AM   #3565
StoneMan's Avatar
Darkseid - Thanks for the fax
Old 07-30-2004, 07:11 AM   #3566
Chewdogg's Avatar
Fellas,
Anyone got any pics of an R40 without the receiver box. Besides the pics of Hara's car at the 2003 nats.
fastntc3 you got pm......
Chewdogg is offline   Reply With Quote
Old 07-30-2004, 12:40 PM   #3567
Regional Moderator
Darkseid's Avatar
No problem...
Old 07-30-2004, 01:53 PM   #3568
treky11's Avatar
http://rctech.net/forum/showthread.p...threadid=46465
I started a thread for the NY HPI challenge for anyone interested/attending.
treky11 is offline   Reply With Quote
Old 07-30-2004, 10:14 PM   #3569
AMGRacer's Avatar
Well I had my first run on concrete with the R40. I had only ever raced on this track once before in the middle of summer so I had no idea where to start with a setup. I guessed a setup and went from there. My MT12 decided to crap out at the start of the first heat as well.
You can read about the race meet here. http://www.bayside-rc.com/home/html/...article&sid=42 I was running in open gas and my name is Alan Beven.
All in all with the limited track time I had I was pretty happy with the car on rubber. I went with a front diff as well on this track as brakes are pretty much required on the tight layout.
AMGRacer is offline   Reply With Quote
Old 07-30-2004, 11:33 PM   #3570
NCC
NCC's Avatar
Congrats on second place finish. I would like to have seen the battle.
NCC is offline   Reply With Quote
New on Nitro and this forum Emaxx rider Rookie Zone 8 02-06-2008 07:21 AM
HPI Nitro MT 2 Forum Tom P Electric Off-Road 5 07-19-2004 06:26 PM
New Nitro R/C Forum Dantherc10man Web Links 0 08-09-2003 07:39 AM
Nitro car forum Rose Money Singapore R/C Racers 47 07-04-2002 08:49 PM
Nitro Forum ART2 Singapore R/C Racers 41 05-16-2002 10:51 AM
